Yet another thread about Turboing a 03 lancer.
thanks, I just today bought brand new tires, I have been rollin a donut since my install lol. I got some Yokohama AVS ES100 205/40/ZR17 and yes I put in a stage 2 rrm clutch when I did my turbo install
Question I am getting a little leaning issues at WOT around 4k-5k range 90 load around 12.5-12.8, everything before and everything after is fine and I almost have my fuel map maxed out in that area. Also since I now FINALLY have that donut off my car I am on the hunt for a 399 maf, when I get one I will then also install my evo 8 ecu. My question here is am I safe to assume that since I will be using a stock evo maf with all stock evo IC and intake piping that I will not have to touch the maf scaling or smoothing tables? Although.... crap just realize im going to have rescale my injectors again... damn
i would assume so. i got both the ecu and maf coming in the mail. yes the injectors will have to be redone in ecu flash but as for the maf thing i dont see a problem in that.
josh
josh
Lol I don't wanna hve to change the maf scaling around twice so just waiting until my maf arrives then gonna slap em both in. Side note any of you turbo guys get traction in 2nd? Doesn't matter if its bone dry as soon as I hit 3k rpms anything over half throttle and my tires just boil instantly. Now I'm not complaining lol does this just come with the territory? Or might I have other issues? My tires have under 50 mi in them btw
Ok guys so I got my “mint” condition maf today and the honeycomb is damaged. So is it bad to pull it out? Or is it hard to try and straighten them out? Or I might risk damaging the turbo if chunks come off. or should I just run it as is?
any way i look at it tho is that if it says mint and it aint mint then its someones fault for screwing up and id be wanting a refund or something.
josh
Ya I am going to mssg him about it. I don't think I will worry about a refund but I understand now why he kept ignoring my request for pics. I will post a pic after work to show yall. Its not the entire honeycomb so not sure if I can just cut the bad section out or not?
