One more 16g thread - few questions
Old Oct 11, 2011 | 07:21 PM
  #571
03lances's Avatar
Originally Posted by HornstarBU
My car has never driven so well since before the Turbo...I can not put it into words. But...I will try.
I never noticed how bad it had gotten, but going from a stop to 1st was very rocky. AFR would swing rich or lean, and make rattle noises as the rpms dipped or jumped around. When I switched gears it would jerk pretty bad, didn't feel smooth at all. When WOT, I saw a fair amount of shift knock....all of that seems gone now. Literally, it shifts like butter, idles like a champ, just rocks my world!
Here's what I did: Put evo settings back in the idle section, and flashed the ROM. Then, I set the BISS calibration mode in evoscan, and the car died. I turned the BISS screw out 1 full turn, then started the car again, and set BISS mode....died again. 1 more full turn out, and the car didn't die this time, but sat at 300 rpm. I jumped out, went to the engine, and turned it 4 more full turns and listened to the idle climb steadily to about 950 or so. I tightened it back down 1.5 turns, and it sat right at what I thought was 750 rpm.
Turned off BISS mode and went for a quick drive, literally drove like a champ right away. Shifts were the first thing I noticed just working so well. Next I noticed the idle was pretty high. My ISCV trim was at 9 before I started this adjustment, it fell to about 6 within a couple minutes, but still idled high. After about 4-5 minutes of driving and stopping at stop signs and what not, it had dropped to about ...-1 or so, and was hitting target idle exactly. It was the evo setting, so I turned back to just my target idle settings, but left stepper and ISCV and all that. It loved that as well, idled perfectly at 702 or whatever, turned the A/C on, it flip flopped between them roughly at first, until the ISCV trim for A/C on got lined out, and then it was just perfect.
I'm sorry for droning on there so bad, but this was so freakin huge as far as the cars drivability goes. I wanted to just stay out all night driving...but I had to stop, dinner and all that jazz.
Also, bought a new boost gauge (AEM analog) since my glowshift is a real piece of junk. There is something electrically wrong with the sender, and rather than replace it...I'm just stepping up to a good quality one.
Interesting... I went ahead today and re connected my throttle body coolant lines and just ran the turbo in a linear fashion. Probably a dumb question but where is this biss adjustment mode is evoscan? Probably staring right at it but I seem to be missing it.
Old Oct 11, 2011 | 07:28 PM
  #572
ryancb's Avatar
Speed Adj Screw Mode i believe?
Old Oct 11, 2011 | 07:30 PM
  #573
HornstarBU's Avatar
Yeah, that's the one, and the actual screw that I adjusted is on the top near the back, underneath a rubber plug. Once SAS mode is enabled, loosening the screw increases idle.
Old Oct 11, 2011 | 07:34 PM
  #574
03lances's Avatar
Lol I kept looking through the top menus trying to find it. I knew where the acutal screw was but not this adj. mode
Old Oct 11, 2011 | 07:38 PM
  #575
ryancb's Avatar
ill let you try it first 03 PS any update on tomorrow (cant find my cell)
Old Oct 11, 2011 | 07:44 PM
  #576
03lances's Avatar
Yeah I sent you a mssg but yeah cant get it without phone lol. My buddy wussed out like I predicted so its a go for tomorrow.
  #577
HornstarBU's Avatar
Don't necessarily have to change anything, but just set it in neutral, all accessories off, and activate the mode when sitting still....see what it does, whether the car dies or what...I am seriously curious if everyone elses is way out of whack.
Old Oct 11, 2011 | 07:46 PM
  #578
03lances's Avatar
So Hornstar let me see if I have this. The end result for you was 4 1/2 turns out on the biss then evo ISC settings and lancer target idle settings? Basically
Old Oct 11, 2011 | 07:48 PM
  #579
03lances's Avatar
I am testing this out shortly Ill post my results. Might have to run to the store first.
Old Oct 11, 2011 | 11:21 PM
  #580
03lances's Avatar
Well I gave this a shot. I activated the mode before changing anything and idle did not change all I got was a CEL lol. As soon as I deactivate then my cel goes off. I flashed in stock evo isc tables and stock evo target idle values and car would start and abruply die. I gave the biss two turns out and tried again. It started and idled barely. Gave it another turn and seemed better, activated the sas mode and idle didnt change. I was sitting at about 10 steps, I gave it another 1/2 turn and brought me to about 7 steps. Did one more full turn and brought me to right about 0 steps. Idle seemed a little high still so put lancer values in the bottom 3 cells of the target idle.
I think I need to adjust some more, at this point Im not sure if it has helped or not. Still getting dips one after another after another :-/. Idle seems to be at like 1100 and dips although more rapid and shallow. Before it would dip randomly and drop to like 400 rpms. Now its pretty constant and dips to maybe 700? then goes back up to 1000-1100. Bout to take a trip to english over this crap lol.
Should I drop the biss back down a turn or so to give the steps some room? Not sure what to do honestly at this point all just confuses me esp not knowing for sure if these table are even labelled correctly.
Old Oct 11, 2011 | 11:40 PM
  #581
link62's Avatar
The cel means that sas mode is activated
Old Oct 12, 2011 | 06:25 AM
  #582
HornstarBU's Avatar
Yes, cel for SAS mode on, scared me at first too.
As far as adjustment, what you want to do is get it to, when SAS mode is on, is to idle at 700rpm +/- 50 either way. Then, after you change that, the idle will be off when you turn SAS mode back off, because the car has "ISCV Trims". Put these items in EvoScan and you will see what I am talking about.
Code:
        <DataListItem DataLog="N" Color="" Display="ISCV Trim AC off" LogReference="ISCVTrim1" RequestID="08" Eval="100*(x-144)/255" Unit="% demand" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-16" GaugeMax="16" ChartMin="-16" ChartMax="16" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ISCV Trim AC on" LogReference="ISCVTrim2" RequestID="0A" Eval="100*(x-144)/255" Unit="% demand" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-16" GaugeMax="16" ChartMin="-16" ChartMax="16" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Oct 12, 2011 | 12:01 PM
  #583
Green_Bandit's Avatar
Good job man! Grats on the win!
Old Oct 12, 2011 | 09:28 PM
  #584
03lances's Avatar
Code:
So I put this into evoscan. Have not had a chance to log it yet as I went up to RyanCB's to continue tuning on his car. I redid the biss this morning before I left then unhooked the battery and let it relearn. Have the biss 3 turns out right now. I put in a bottle of injector cleaner in today so I am going to run the tank out before trying this again and logging those ISC trims. Dips persist but I am confident I am going to get this figured out. Another thing I will mention is my CEL cam on today not too long after getting to Ryans. I am sure its idle related but for some reason evoscan would not connect for the DTC. Got home a little bit ago and have not hooked my scanner up yet to see what the deal is.
I tell you what though 14 psi I am getting some torque steer in 4th at about 90mph!!!!! Makes me grin and grip hard at the same time lol kinda scary.
Old Oct 13, 2011 | 12:00 AM
  #585
burner67's Avatar
hey are you guys running more of an evo timing in the lower loads or stock lancer. i already know what u are running horn..
