Going turbo but got some questions
Old Dec 17, 2010 | 07:02 PM
  #46
Mitsu.kid.02's Avatar
Originally Posted by 03lances
Yes it does and make sure you get the block and pan surfaces realllllly clean before installing the gasket/rtv cause you do not want to have to pull that puppy back out
+1 i cleaned my pan REALLY good, and made sure the surfaces were nice and dry, although the black RTV gasket is made for oil applications and if there is a little bit of oil on there it shouldnt be too bad.
Old Dec 21, 2010 | 09:00 PM
  #47
slatermvp's Avatar
Has anyone used a stock evo exhaust manifold and piggybacked the 4g94 flange onto it. I know it has been done with aftermarket ones but just wanted to see if anyone had used the stock evo one. I plan on using a speedcorps or a RRM one but just wanted to know.
Old Dec 21, 2010 | 09:04 PM
  #48
steven121's Avatar
just go speed corps its alot easier
are you looking for a downpipe? I can sell you mine really cheap about to go full 3"
Old Dec 21, 2010 | 09:24 PM
  #49
slatermvp's Avatar
yeah, i need one. om me.
Old Dec 22, 2010 | 08:20 AM
  #50
cedes14bamg's Avatar
i have a stock evo exhaust manifold with a 4g94 flange weld over, looks good. For anyone that did this i recommend you heat your headers in the oven for at least 3 hours at 450f to take off all the stress from the weld. And the bad side of it is that yes it is now a warped header, really hard to not make it bend while you weld, what to do is have it machined. Or just some gasket made for warped headers. Mine are warped of maybe 2mm you cant notice until you put a level on it. What to do is also to retight the bolts after a run with the car so that you can tight it more and try to get it straighten.
and the bolt holes mostly all align but 2 , so you just resize them.
I personnaly dont think it was too complicated and it was quite a budget
Old Dec 22, 2010 | 11:16 AM
  #51
slatermvp's Avatar
can you send me pics to slater5mvp@yahoo.com so I can see what it looks like...
Old Dec 22, 2010 | 07:19 PM
  #52
yes of course, right now i only got pics of the header how it was before. but ill take new pics of how it looks right now and ill show you, probably tomorow
Old Dec 22, 2010 | 07:27 PM
  #53
slatermvp's Avatar
thanks bro
Old Dec 22, 2010 | 08:47 PM
  #54
np
Old Dec 22, 2010 | 09:06 PM
  #55
03lances's Avatar
Finally found them lol. Here are some pics of white knights welded manifold
Originally Posted by White_KnightOZ
Not the prettiest thing in the world, but it'll get the job done.
Still need to dremel out the runners to match better, and get a drill press to get those holes through. But ya, thats it.
Old Dec 23, 2010 | 08:48 AM
  #56
slatermvp's Avatar
yeah I saw his but I haven't seen it done with a stock evo one, like cedes. I am really interested in seeing how it looks under the hood.
Old Dec 23, 2010 | 05:42 PM
  #57
[/PHP]http://img821.imageshack.us/i/img0174y.jpg/
PHP Code:
http://img204.imageshack.us/i/img0176hb.jpg/
PHP Code:
http://img132.imageshack.us/i/img0178jj.jpg/
PHP Code:
http://img18.imageshack.us/i/img0179pm.jpg/
PHP Code:
http://img691.imageshack.us/i/img0183wa.jpg/[PHP]
Old Dec 23, 2010 | 06:27 PM
  #58
slatermvp's Avatar
is that a stock manifold??
Old Dec 23, 2010 | 09:00 PM
  #59
Thats not a stock factory 4g63 exhaust mani, this is:
Old Dec 25, 2010 | 10:32 PM
  #60
okay maybe it doesnt look stock, but keep in mind that me its an evo3 turbo
i dont see any brand name on my header haha
maybe i got a custom header...
