Green_Bandit's 16g build thread
Old Nov 1, 2011 | 10:41 PM
  #181
steven121's Avatar
is this code for autos only? I kind of skimmed through the thread but is this a fix to the lean issue when starting?
Old Nov 1, 2011 | 11:36 PM
  #182
RoadSpike's Avatar
Yes auto's only evo roms don't have a lean when boosting issue.
I assume when you mean lean when starting you mean when its running.
The tables that keep the idle rich when its a cold engine are in 3 parts.
Maf compensation vs coolant temp is a general all around enrichment
Post cranking enrichment is just after starting to keep a nice rich idle while the o2 sensor warms up.
Post cranking enrichment decay is how long it enriches while the o2 sensor comes to life.
At least thats how i understand it there were a few threads by mr fred on evo's and fuel control which probably explain it in more detail.
Old Nov 2, 2011 | 03:33 PM
  #183
slatermvp's Avatar
RS - just an FYI on my xml this is what it said on the load and fuel limit cut:
<table name="Set to 9 to remove load limit" category="Miscellaneous" address="245da" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 9 to remove fuel limit" category="Miscellaneous" address="246dc" type="1D" level="1" scaling="Hex16"/>
the address is different than the one you posted above.
Old Nov 2, 2011 | 03:35 PM
  #184
RoadSpike's Avatar
Yes those are mean to be enabled when testing the ones i posted meaning with a value of 0x9
Old Nov 2, 2011 | 03:45 PM
  #185
slatermvp's Avatar
ok so I don't need to change anything else just copy and paste. Getting ready to leave work so I'll be able to test this out.
Old Nov 2, 2011 | 03:47 PM
  #186
slatermvp's Avatar
sorry I just don't understand the 0x9 and where it is in the xml or in ecuflash
Old Nov 2, 2011 | 04:20 PM
  #187
RoadSpike's Avatar
its a value in hex since its under 10 its the same as 9 as you would enter it in ecuflash
for example 10 is 0xA and 15 is 0xF get it?
Old Nov 2, 2011 | 07:40 PM
  #188
slatermvp's Avatar
gotcha its just a number representing the value in ecuflash.
so I do this then right:
put this into the xml file
<table name="Set to 9 to remove fuel limit #2" category="Miscellaneous" address="246E4" type="1D" level="1" scaling="Hex16"/>
then go into ecuflash and under the word hex(value) put in 0xDA41 (replacing the 0009 that is there now on the "set to remove fuel limit" table) or is this going to make another table and I need to put 0xDA41 in that new table as the value??
Old Nov 2, 2011 | 10:44 PM
  #189
HornstarBU's Avatar
For these 3 new tests, there will be 3 new tables with just one value in them. They will be under the "miscellaneous" group with names like fuel path 1, 2, or 3.
Add the lines he posted into your xml file, close it, save it, then open ecuflash and then your rom. Adjust the tables 1with at a time as long as the starting value roadspike posted matches.
Old Nov 3, 2011 | 07:23 AM
  #190
slatermvp's Avatar
Ok I have it in my rom and its ready to go, one last question:
The value in ecuflash for the path #3 (the one I put in the xml to try first) is the stock value that RS said. He said stock values should be 0x9, do I change the value in ecuflash to 0x9 or just leave it the way it comes up for that table.
Old Nov 3, 2011 | 07:27 AM
  #191
HornstarBU's Avatar
What he means is, the stock value is listed as "Stock Value = *****", and he wants you to verify that the stock value he lists matches what you have. Once that is confirmed, then change the value to 0x9, then see if the fuel limit is removed by driving (carefully).
Path 1
Stock Value = 0x8B3B
<table name="Fuel Path Test 1" category="Miscellaneous" address="24668" type="1D" level="1" scaling="Hex16"/>
Path 2
Stock Value = 0x8935
<table name="Fuel Path Test 2" category="Miscellaneous" address="24674" type="1D" level="1" scaling="Hex16"/>
Path 3
Stock Value = 0x8903
<table name="Fuel Path Test 3" category="Miscellaneous" address="2467C" type="1D" level="1" scaling="Hex16"/>
You can add all three of the lines to your rom at once, and then just change the value for each one as you test....it'll llook like this in your xml
Code:
Old Nov 3, 2011 | 08:06 AM
  #192
slatermvp's Avatar
oh oh ok...I gotcha now. Thanks alot. I got enough highway to test all three on the way home so I'll let you guys know.
Old Nov 3, 2011 | 09:07 AM
  #193
RoadSpike's Avatar
What they do is disable fuel paths leaving the others there.
If you don't see a difference I think its probably best to leave it disabled and continuing to disable them until you have all 3 disabled. This will leave the 4th and default fuel path as the only option.
Old Nov 3, 2011 | 04:07 PM
  #194
slatermvp's Avatar
Originally Posted by RoadSpike
Would like to test see if this does something its the only other place manipulating fuel.
Stock value is 0xDA41 set to 0x9.
the stock value that came up for this one didn't match up so I took the table off the rom.
I'm leaving work now and will do the first path first and see if that works.
Old Nov 3, 2011 | 04:48 PM
  #195
RoadSpike's Avatar
Ok thanks for letting me know i'll look at the address when i get home and see if i can't fix it up.
