Green_Bandit's 16g build thread
In the XML for the rom, and I got it out of the big maps stuff in RoadSpike's thread, so in theory it should already be in your ROM/XML combo...be careful if you add it, I'd just get new XML and ROM from that thread (not the SD one obviously)
Just as a hint for all you future rom hackers out there both the 02-04 and 05-06 roms are IDENTICAL. Meaning anything in one xml will work in the other I just changed up the flashing method so the last ecu will work with the rom.
Remember to remove both the load and fuel limits on the rom when playing with it.
Yeah, I'm using your auto big maps. I've scowered the rom hoping I'm just over looked it but it's not there. I'll play with it some more tomorrow and see how it goes.
Green you are using one of my roms right? It should be in the xml if not I definitely apologize.
There should be a copy of those settings in the xml for one of the roms either SD or not.
If the above is true, you might ought to grab the newer XML file from the forum post in the lancer ecu tuning forum where RS posted all of that....and maybe double check that your rommetadata folder is actually where you have the XML file as well.
Ok, #1, I guess some how I did have an older ROM I dont know how seeing as I deleted the whole thing and re-installed it using new ROMs and all but hey...
#2 So now I see the fuel and load limits under miscellaneous and they are both at 0900
BUT, Im still going to 14's in boost. This is getting aggravating...
I havent scaled them down.
As far as my load tables I have open loop load to 1500-2500 @30 then after that set to 0. Then open loop throttle at 2500 at 35% then 0 anything after.
Im just going to throw in these 440's get the latencies right and use that as a band-aid. Thats what Demon and Touring Bubble said they had to do.
If it works, do it!
It is odd though that the 232 injectors work just fine in the evo rom, but go lean in the lancer roms. That's the single most annoying thing I've seen altogether, if it weren't for that, you could actually use the stock rom pretty well.
I wonder if this is due to the injector latency base being way different in an evo rom than a lancer rom. Maybe setting the injector latency base to the evo settings will stop them from going lean?
Its under "miscellaneous".
