Green_Bandit's 16g build thread
Old May 14, 2011 | 08:27 PM
Green_Bandit's Avatar
I said two days that thing will be on and me and a buddy did it in 1!
Im going to go into quite a bit more detail by kind of making this a how to and laying out facts but right now I'm dead tired and have some of the minor things to wrap up in the morning like running the O2 sensor, fitting the down pipe and stuff like that. But you better believe that hunk of metal is strapped on and fluids are back in the car!
For now just a few images to get going...
Later
Old May 14, 2011 | 08:29 PM
Old May 14, 2011 | 08:31 PM
Parts list and where to get them...
This is the option I took for extending the O2
Forge Waste gate
http://www.maperformance.com/forge-a...-evo-viii.html
Where I bought the forge Waste gate for Under $200 WITH the 5-10 pound spring installed. You can also get it with the 10-15 pound spring in it for the same price
Wide band and other gauges came from here
http://prosportgauges.com/wideband-a...ratio-kit.aspx
Evoscan cable and software can be found here
http://www.evoscan.com/evoscan-gps-o...flashing-cable
Link to ECUflash 1.29a
RoadSpikes Big maps link
Parent files
How to wire AEM to ECU
Downpipe springs
http://www.streettunedmotorsports.co...olt_spring.htm
But I bought mine off of a member on Evom. Also upon further inspection your local exhaust shop should have them
oil return fittings and steel return hose.
http://www.treadstoneperformance.com...s+%26+Fittings
Fair pricing and quick shipping. Just try to order everything at once because minimum shipping charge is $11.00 even if you order a one inch flange
Oil feed Well I had one made. 4an line with 4an ends with one end at a 90 degree angle. If you want to know where I went email "Greg @ GO-AUTOWORKS.COM" GREAT customer service and quick shipping.
Oil return flange on the turbo just run a search of http://shop.ebay.com/i.html?_from=R4...All-Categories
What you need is a 10 an fitting. Should be around $11.00.
If they don’t come with the bolts you need to go some place like Tractor Supply Co and get a pack of Hd cap screws. 1.00 x 20 They fit perfect
O2 housing
If you don’t want a stock one I went with this. http://cgi.ebay.com/ebaymotors/GODSP...ht_3519wt_1009
Good price. It’s a little thin but more open that the stocker. Otherwise look here on Evom
Down Pipe
Do a search here for a stocker. Should be able to get it around $60-80 shipped depending
Doughnut gasket for the down pipe is $20 at Advance Auto Parts
Last edited by Green_Bandit; May 22, 2011 at 12:46 AM. Reason: Added some stuff...
Old May 15, 2011 | 05:11 AM
slatermvp's Avatar
I thought the O2 sensor extender didn't work for ya??
Old May 16, 2011 | 10:11 AM
The one I ordered didnt but they have others. The one they have for mitsubishi defiantly doesnt look like the right one. For anyone looking at those I'd call them first and try to get more information. I couldnt because I received mine with just a few days left till the build
Old May 16, 2011 | 10:18 AM
Jogenmaru's Avatar
looking good! My build starts on the 10th of next month. Going to be referring to everyones build for mine. I like the powder coated piping. And which o2 housing is that? its not a megan is it? im sure megan is 3 bolt dp flange.
Old May 16, 2011 | 02:21 PM
The brand is god speed. Off of ebay. About 30 bucks. Nothing to write home about but better than stock.
I'm getting acquainted with ecuflash but mitsulogger has me off a bit. What exactly am I looking for with it? I'm logging and all but do I chart it with the graph option or watch the play back? What am I missing, there has to be something I'm missing.
Old May 16, 2011 | 09:36 PM
syntax182's Avatar
Damn, 1 day, that's quick, ha ha. Some good info, thanks man, can't wait to see more.
Old May 16, 2011 | 09:40 PM
RoadSpike's Avatar
I would really look at buying evoscan its much easier to setup and use than mitsulogger. Which isn't a bad tool but its more geared toward someone that knows about the ECU rather than someone that doesn't.
Old May 17, 2011 | 06:58 AM
Jogenmaru's Avatar
Later
this I am not liking though. the upper intercooler piping coming from the im is being pressed down by the strut bar. You do anything to combat that? I have a strut bar but its ebay and not rrm. So Im not sure if I will run into the same issue or not.
Old May 17, 2011 | 10:36 AM
Yeah, Friday not we drained the oil and took off the stock manifold. Saturday we bolted it up and all that other good stuff. Sunday cut and welded the exhaust, extended the o2, and connected some gauges and stuff. Granted though I already had my pan welded and ready to go and intercooler mounted. Im not going to front like I was superman flying around getting everything done but one weekend is all it should take if you have everything. I was turning it over about 3:30 sunday afternoon.
Ahh, why do I keep saying Mitsulogger?! I have Evoscan. I found out some more and looks like Ill be viewing most of the data in excel which I can see better since its all compiled.
Road spike, I flashed the auto big maps to my ecu but it looks as if one of my starting points is going to be pulling timing about 8 degrees around 80-110 load since I have about 10 counts of knock around 3300 rpm. Sound like a good analysis?
Yeah, it pinches a bit. Nothing too bad though, it does help my hood to close. Not really much I can do about it. I hope yours fits better. I wont lose any sleep over that little pinch.
Old May 17, 2011 | 10:45 AM
Some more reference pics for you guys
I already had the RRM test pipe so I ended up chopping that up instead of making something new.
started about 12 inches...
Ended up shortening it to about 5 & 1/2
My oil feed. For anyone getting these fittings I had the 45 degree one but while putting it on there the 90 would be easier to work with. Not saying the 45 is jacked up in any way because mine is on there solid and straight but the 90 will give you less hassle
The oil line cam out to be about an inch shorter than this
The oil pan, we hondabonded the hell out of it.
Here is the little notch youre going to have to pry to get the pan off
You can see it a little better here...
Old May 18, 2011 | 02:39 PM
RoadSpike's Avatar
To be frank I'd suspect more rattling parts and noise than actual knock in that area.
Log your knock voltage and see if on the deceleration your getting big voltage spikes. If so you got stuff rattling enough to make it believe there is real knock.
Old May 18, 2011 | 04:38 PM
Demon_ni2's Avatar
and FYI.. that was WAY to much grey silicon on ur oil pan.. If it globs into the oil pan, u could clog the oil pump.. u need a thin line, about half of what u put on there, and u spread it out slightly with a wet finger.(wet finger so it doesnt stick to you as much)
Old May 18, 2011 | 04:43 PM
corndog17's Avatar
Jesus thats alot of icing on your cake! mmm
