Jake's 06 ES Lancer Build
Old Mar 22, 2015 | 03:27 PM
  #361
marcouxa1's Avatar
Originally Posted by jakermeister
Marcauxa1 I'm running at 18 afr at idle and cruise still. I'm going to try and mess with latencys today.
Thats weird because we are many with close to the same rom and never had any problems with the cruising afr :/
Old Mar 22, 2015 | 03:33 PM
  #362
jakermeister's Avatar
Yeah I'm thinking I may have a leak some where? On another note I was backing out of my drive way and put a dent in one of my lower intercooler pipes. it did manage to put a small leak in it so I'll have to get it fixed. I'll be pulling that pipe in a bit. I need to call up a welder. My brother can't do aluminum.
Old Mar 22, 2015 | 04:29 PM
  #363
02modlanceroz's Avatar
361 cc/min
4.69 | 3.144
7.03 | 2.112
9.38 | 1.200
11.72 | .792
14.06 | .720
16.41 | .672
18.68 | .408
Old Mar 22, 2015 | 04:42 PM
  #364
Aaron from English racing did a remote tune for me. At the time, not many people had a speed density setup and I drastically changed my setup. So it was easier since he already did a couple. But for whatever reason, I wasn't able to log fuel trims, he said he disabled them and it didn't matter. But I have no clue how or why he did it. But my car does run like a champ, only thing I had to adjust was things involving how my car started since I didn't have a MAF input.
Old Mar 22, 2015 | 04:50 PM
  #365
Originally Posted by Evodreamer28
I'm in the Lehigh valley.
Is that in Allentown? If so, you're about 4.5 hrs from me. But TPG is one of the best in my area. Also, PRL is decent. Closest people I could think of by you would be CBRD that's probably 2hrs from you and I'm not sure if they will do custom work there or not.
Old Mar 22, 2015 | 05:01 PM
  #366
Thanks 02. O just pulled my intercooler pipe. It's a decent size hole. The car will be done a few more days. I'll get pics in about a hour.
Old Mar 22, 2015 | 05:26 PM
  #367
I didn't realize my pipe sat so low and backing out of my driveway I punched a hole in my hot side of my piping. I got a bit close to my mailbox which has a bit more of a drop. I'll be dropping it off to get fixed tomorrow.
Old Mar 22, 2015 | 05:46 PM
  #368
Omg, that's a damn bummer. If it's not one thing it's another..
On a positive note, just married my cobb AP to the evo x today. Wow, what a difference. I still have to get a wideband for it so I can log AFRs. But it really puts you in the seat, I maxed out 25-27 psi on my log with stock boost controller. So pumped!
Old Mar 22, 2015 | 06:00 PM
  #369
Nice! Yeah its been one problem after the other. I'm hoping to have the car running by Friday. I'm pretty sure that tiny hole was giving me a bit of a wacky idle. It was fluctuating a bit so I decided to spray some soapy water on the dent and it bubbled up. :/
Old Mar 24, 2015 | 01:59 PM
  #370
How's the car coming? Get your dent/hole fixed yet?
Old Mar 24, 2015 | 04:54 PM
  #371
I dropped the pipe off yesterday. I'm hoping to get a call tomorrow? I just got my hallman boost controller in so I'm going to install it in a bit. I just got home.
Old Mar 24, 2015 | 07:04 PM
  #372
Well I think I found what was throwing my idle off. I forgot to cap this nipple on the evo intake pipe. (Dooh) I'm just waiting on my intake pipe to get fixed.
Old Mar 24, 2015 | 07:41 PM
  #373
marcouxa1's Avatar
That is probably where your cruising/idle lean afr for sure!
Old Mar 24, 2015 | 08:03 PM
  #374
Yeah!!!!!! I was adjusting the injector scaling up and down and couldn't figure out what the problem was. I'm sure this was the cause. Just waiting on a call to come pick my pipe up.
Old Mar 26, 2015 | 01:22 PM
  #375
marcouxa1's Avatar
I just found that my manifold is cracked AGAIN.....i was wondering where my clacking sound was coming from and used soap and water on my cold manifold and bubles came from everywhere around my runners -.- i will have to get that welded again!!!
