Jake's 06 ES Lancer Build
Old Mar 19, 2015 | 09:03 AM
  #331
marcouxa1's Avatar
Originally Posted by jakermeister
02modlanceroz I have a question. What map sensor are you running for SD? I see a 3 bar, 4 bar, and 7 bar. I think most people are using the 4 bar and the 7 would just be over kill for us. I'm thinking about getting one so I can log boost. I'm not sure my prosport gauge is correct. It could be off by a pound or two.
Just hook up a vacuum pump to your gauge and see if the reading is identical?
Old Mar 19, 2015 | 10:05 AM
  #332
jakermeister's Avatar
I don't have a compressor though. Logging boost can also be quite useful as well. In the future I may decide to go SD. I hear you have less idle issues in the cold and if I ever blew a coupler off I don't have to worry and fix it immediately.
Old Mar 19, 2015 | 10:07 AM
  #333
Also another update. It seems my 1.3u cable came in early! So I may mess with the car after work.
Old Mar 19, 2015 | 01:55 PM
  #334
marcouxa1's Avatar
Great! flash my rom in with the 440 injectors and record a video for me!
Old Mar 19, 2015 | 02:47 PM
  #335
02modlanceroz's Avatar
I'm running a 4 bar, if you need, let me know and I'll check to see what the values need to be for the omni 4 bar for logging boost in evoscan
Old Mar 19, 2015 | 03:32 PM
  #336
02 that's what I thought. I found the values for them in merlins tuning guide. I'm sure they're also here on evom as well. I'll work on the fuel injectors when I get home. Hopefully I can put them in before sun down. I have a gopro I can use for videos but don't like the waterproof case. It takes a bit of the sounds away. I'll try to get a regular case soon for videos.
Old Mar 19, 2015 | 04:46 PM
  #337
Dang it I forgot my injectors at work. I thought I was going to have time to put the new o-rings and and gaskets on. I'll flash my rom with the periphery changes though.
Old Mar 19, 2015 | 09:27 PM
  #338
347-dis's Avatar
is that a evo battery tray?
Old Mar 19, 2015 | 10:27 PM
  #339
It is but I don't think it's installed like everyone else's. In the future I want to relocate my battery to my trunk but don't currently have the correct battery to do it.
Old Mar 20, 2015 | 07:09 AM
  #340
marcouxa1's Avatar
I logged my car yesturday and it runs in open loop at idle. When i change the load table in the open loop table the car runs in the 16-17 and i cant figure out how to make it run richer or leaner....anyone has had this problem b4?
Old Mar 20, 2015 | 09:39 AM
  #341
Open loop goes by the maps in the fuel. Closed loop goes by the feedback the o2 sensors are giving back to try and get the car close to a 14.7 afr. Try using the map tracer and change the area it's getting the lean mixture from.
Old Mar 20, 2015 | 06:54 PM
  #342
marcouxa1's Avatar
I know how the closed and open loop work i just didnt understand why it wasnt running near 14-15
Old Mar 20, 2015 | 07:22 PM
  #343
It could be the problem I have? The car runs fine in open loop then when the car gets warmed up and goes into closed loop it goes lean on me. I may just cut my closed loop off at the 20-30 load? I've read about people just having there car run closed loop just at the 10 load.
Old Mar 20, 2015 | 07:42 PM
  #344
You can also wire in from a wideband out into the ecu pin in for the o2 sensor readout. If it's .5 volt I believe off the top of my head. Then it won't try to adjust the afr and you can adjust it in your table
Old Mar 20, 2015 | 08:10 PM
  #345
I read just a bit about that but wasn't sure how to do it. Is it setup like the "how to log your wideband" in evoscan? There's a couple of ways to log and I'm using the r32 cable method.
