Jake's 06 ES Lancer Build
Old Mar 26, 2015 | 03:15 PM
  #376
jakermeister's Avatar
That sucks man. What material are you using?
Old Mar 26, 2015 | 04:30 PM
  #377
marcouxa1's Avatar
Its stainless steel....i dont weld myself il have to get it welded again
Old Mar 26, 2015 | 06:12 PM
  #378
Maybe you should try some mild steel? My manifold is made from mild steel and feels solid. It is pretty heavy though. In the future I might put a bracket on but the manifold looks and feels so well built. Senate mentioned this place and it seems really good. This is where I got my copper gasket from. It fit perfectly. They make the 4g94 flange in stainless and mild steel.
http://www.mandrel-bends.com/catalog...d776e8&x=0&y=0
Old Mar 27, 2015 | 11:42 PM
  #379
Evodreamer28's Avatar
Originally Posted by marcouxa1
Its stainless steel....I don't weld myself I'll have to get it welded again
I'd say one of three things:
Sub-par stainless
Bad welds
Breaking from weight
I work with medical grade stainless on a daily basis especially tubing and I can tell you that the stuff is pretty durable and when welded properly will not crack/break under some pretty extreme conditions. Granted most are not going to spend that kind of money but you get what you pay for unfortunately. I feel like most of the cheaper manifolds are made with Chinese stainless anymore. The stuff doesn't hold up well and is highly magnetic.
Old Mar 28, 2015 | 07:07 AM
  #380
marcouxa1's Avatar
Sub-par stainless
Bad welds
My manifold is a dc sports i paid over 450$ for that thing hoping it was going to last a good long time but NOPE....
Old Mar 28, 2015 | 11:19 AM
  #381
I say go with a custom manifold. Turning a 4g6x manifold into a 4g9x manifold puts stress on it. You already have a starting point. Have them jig up the old manifold and make a custom one. The jig will ensure you have the same turbo placement for the exhaust.
Another update, my intercooler pipe won't be done till sometime next week. The girlfriend and I are also expecting a baby on Thursday. So next week will be a bit hectic for me but I'll do my best to keep you guys updated.
Old Mar 29, 2015 | 07:14 PM
  #382
Yes unfortunately DC sports is over priced with cheap quality material.
Old Mar 31, 2015 | 05:44 PM
  #383
update : I got my intercooler pipe back and put on. I'm still having that darn lean problem!!! :/ I'm not sure what it can be. It's lean at idle and cruising so I'm positive it's still a closed loop problem. I have my own loop set to about 40% which is a band aid fix for cruising. Any thoughts?
Old Mar 31, 2015 | 06:05 PM
  #384
02modlanceroz's Avatar
Are you running his exact rom the way he has it set?
Old Mar 31, 2015 | 06:28 PM
  #385
Have you done any logging on it yet? What MAF you running? If you want, post your current rom and I'll take a look when I get home. Post a log if you have one too
Old Mar 31, 2015 | 06:42 PM
  #386
Yes I've tried marcauxa1's rom and that runs even more lean. Especially with the lean spool enabled. I've went back to the rom I'm messing with now. It does seem a bit better with the intake nipple capped. It may be a injector thing now. I still need to tune the injectors.
Old Mar 31, 2015 | 06:44 PM
  #387
Looking the log over now. I'm running the evo maf. Maybe I should try the lancer maf and see if that cures anything? I may try that tomorrow.
Old Mar 31, 2015 | 07:32 PM
  #388
marcouxa1's Avatar
Il send you my current rom tommorow...i have no lean idle nor cruising problems at all with it right now....its runnimg in open loop at idle like a few people did with their setup a few years ago and it works fine for me!
Old Mar 31, 2015 | 07:36 PM
  #389
marcouxa1's Avatar
You said your injectors were derty before you installed them right? Did you clean them a little bit with carb cleaner or something before putting them in or not at all?
Old Mar 31, 2015 | 07:50 PM
  #390
I cleaned them. I'm not sure what it can be. Maybe I need a better ground for my wideband? I was reading it could be that. But I've tried a higher injector scaling and lower injector scaling and nothing seems to richen if up at all. I think I'll check for exhaust leaks tomorrow morning and see if I find anything.
