Free Horsepower/Mods?
Old Aug 8, 2006 | 09:50 AM
  #106
crypto's Avatar
Former Vendor
oh wait. i re-read it. now i know what your talkin about.
i still havent got my steering fixed. when i get the timing belt done i will have them look at it.
Old Aug 14, 2006 | 02:16 PM
  #107
lancerman360's Avatar
The reason I ask is cause my steering went out a while ago. Just wondering what was going on. I thing its the powersteering sensor thats bad.
Old Jan 18, 2007 | 03:51 PM
  #108
02OZR's Avatar
Question help?
I know, i'm bring to life a dead thread, but i really cant seem to figure out how i missed this. lol
Coolant/throttle body Bypass mod.
Can anyone post a pic of this done on their 4g94? I couldnt find one.
Tho i did find one on the evo ( https://www.evolutionm.net/forums/at...2&d=1135371373 ).
I'm trying not to mess up a simple task.
Thanks!
Old Jan 18, 2007 | 04:43 PM
  #109
I will take a pic when i get the chance. Its really easy to do.
Old Jan 18, 2007 | 04:45 PM
  #110
crypto's Avatar
Former Vendor
here is a rough mspaint of what is to be done.
red is where the current hoses are.
blue is where you need to re-locate on of the hoses, or buy a small strip of new hose.
take the hose that comes from the engine into the TB and pull it out, then pull out the hose from the silver pipe that runs right below the TB, then plug the hose from the engine into the silver pipe. Then just throw away the unused piece of hose. Carefull you don't get coolant everywhere, and also keep some coolant hose spare incase one of them tears (this happened to me)
hope that helps
Old Jan 18, 2007 | 06:32 PM
  #111
02OZR's Avatar
Perfect, thats what i was about to do. Just wanted to make sure. Thanks alot. I owe ya.
Old Jan 18, 2007 | 07:46 PM
  #112
crypto's Avatar
Former Vendor
happy to help mate
glad to put see my profession as a graphic designer can extend beyond my job
Old Jan 23, 2007 | 05:38 PM
  #113
Disruptorzero's Avatar
I did this mod yesterday, bad idea to try this in the winter time. Not that it's given me problems with starting and/or driving, but it's just so much harder to do in the cold. I'm guessing the hoses must've constricted or something, because I couldn't pull them off no matter how hard I tried. I ended up cutting them, which is no problem cause the hose running from the block to the throttle body is more than long enough even when cut down. It's a slight improvement, nothing to drool over but I'm hopeful that it will help make further intake mods more noticible. When the weather gets better, I'll continue work on perfecting my short ram and adding a heat shield and possibly some air ducting. I just need to get some better couplers for the pipe, cause the ones it came with get all deformed at operating temps(I have my suspicions as to weather they are really meant for automotive use). Also, a question on moving/repositioning the battery. Say I wanted to set it sideways, would I just rotate it 90 degrees on the stock tray, or would I have to alter the tray somehow. By the way when spring hits, I might try to design a tray that fits where the airbox used to be, and fabricate it from steel. It'd be heavy, but efftective.
Old Mar 29, 2014 | 06:23 AM
  #114
Murder Snake's Avatar
new to this and appolgize for resurrecting an old thread....anybody have a pic of the coolant by pass, tb mod? thanx. found this looking for cold air intake info.
Old Mar 30, 2014 | 09:14 AM
  #115
Archlegan's Avatar
https://i.imgur.com/B74K75F.jpg
Old Mar 30, 2014 | 10:35 AM
  #116
Originally Posted by Archlegan
Thx! None of the pics would open for me on this thread prior to the one you just posted.
I assume both of those plugged are the ones from the tb we are dealing with. when I look under the hood, hopefully it will be obvious where the hoses that are left go. thanx again.
wes03evo
Southeast Region
Mar 3, 2016 10:21 AM
TheWesMan
53
Jul 16, 2011 09:22 PM
vegasboy301
Jun 26, 2008 08:12 AM
Wes_M3
28
Nov 13, 2007 11:13 PM
richevo26
Nov 29, 2005 08:45 PM
