***ECUFlash Now For Base Lancers!***
Old Dec 6, 2007 | 05:36 PM
  #841
deadpirate's Avatar
haha
Old Dec 6, 2007 | 06:15 PM
  #842
kungfugirl's Avatar
bump for help with defenition file, i guess ill check tommorow.
Old Dec 6, 2007 | 06:27 PM
  #843
Redlancer's Avatar
The rom ID is 88540011... I don't have this definition in my list for the base Lancer. Maybe an other one can help you.
Originally Posted by kungfugirl
Ok i hosted my rom.
http://www.filefactory.com/file/6aef1b/
someone help me get a definition! thanks.
Old Dec 6, 2007 | 06:30 PM
  #844
senate6268's Avatar
Yup. That's the ID. See below for a partially completed file:
https://www.evolutionm.net/forums/sh...&postcount=852
Old Dec 6, 2007 | 07:08 PM
  #845
kungfugirl's Avatar
ok ill take that and insert it into my def file. thanks for your help. I hope someone else can get me another. TY.
Old Dec 6, 2007 | 07:14 PM
  #846
kungfugirl's Avatar
guys i put that in the file with my other defenition looking files, and then tried to load my .hex file and it just pops up the thing that says it can't read it.
Old Dec 6, 2007 | 07:55 PM
  #847
senate6268's Avatar
Did you place the .xml file in the rommetdata\mitsubishi\lancer folder? I just downloaded the zip file I posted and extracted the file into the folder, overwrote my existing file and was able to open your ROM and read the data.
Old Dec 6, 2007 | 10:25 PM
  #848
kungfugirl's Avatar
so i just place it in the file, along with the other defenition files and then i should just be able to open ecuflash and my rom will just pop up when i open it??
Old Dec 6, 2007 | 10:37 PM
  #849
kungfugirl's Avatar
what version of ecuflash are u using?
Old Dec 6, 2007 | 10:46 PM
  #850
kungfugirl's Avatar
well initially i didnt extract it, now I unzipped it and it worked now but it says.
[22:44:00.353] scanning for metadata models in C:/Users/doubledcindy/Desktop/EcuFlash/rommetadata
[22:44:00.826] 220 ROM metadata models scanned.
[22:44:13.792] 81900006 (0 tables) inheriting lanceratbase (0 tables)
[22:44:13.792] 88540011 (9 tables) inheriting 81900006 (0 tables)
[22:44:13.798] 262144 byte image read.
Old Dec 6, 2007 | 11:02 PM
  #851
kungfugirl's Avatar
Ok well i made the tables that i couldn't see before visible but they are light and not accessible. When i click them, it says they are incomplete and i need to get the full definition. Please help when you can. Much appreciated.
Old Dec 7, 2007 | 09:03 AM
  #852
senate6268's Avatar
I've made some changes and added some more to the definition, but it is still not 100% complete. I'm getting 5 minutes here and there to work on it. The more important values - fuel and ignition are now defined.
File Type: zip
Old Dec 7, 2007 | 11:59 AM
  #853
kungfugirl's Avatar
TY^ I'll try and see what happens.
Old Dec 7, 2007 | 12:04 PM
  #854
kungfugirl's Avatar
This one looks great, some things are missing, but the ignition and fuel maps are now up and everything is listed. Senate, this is very much appreciated.
Couple issues, my load values are all weird. And my maps all seem small in size, and i cant see all the values in the load boxes or rpm. Not sure if this would be fixed by simply completing the def file, just wanted to let you know.
Old Dec 7, 2007 | 12:45 PM
  #855
senate6268's Avatar
The def file isn't complete. I just wanted to get you the fuel and ignition areas for now. Nothing else really matters for tuning. Injector scaling should be there and the rev limit as well. I'll hash out the rest little by little. You can tune your ECU with what you have now.
