***ECUFlash Now For Base Lancers!***
Old Dec 7, 2007 | 05:21 PM
  #856
kungfugirl's Avatar
Originally Posted by Newfoundlancer
Update:
One of the guys on OpenECU.org helped me get a definition file going and now I'm able to edit my map perfectly.
Z_Lancer: Maybe you'd like to add this information to the first post:
- Video illustrating how to copy your cars ROM onto a laptop (ignore the emailing to jester tuning part) http://www.youtube.com/watch?v=AigoMPNtqAA
- Here's a link to a thread over on OpenECU.org that has all the current ROMs and their associated XML files. The first 2 posts in that thread have the download links, but I think you need to be registered before they become available. My current ROM and XML has not been added yet, but the author of the posting is the guy that made the definition file for me, so it should be there eventually. http://forums.openecu.org/viewtopic.php?t=925
Here are my current stock fuel and ignition maps:
this is what mine looks like. the graphs values seem off.
Old Dec 7, 2007 | 05:50 PM
  #857
lancerrally45's Avatar
yeah they are, but the boxes are cash money
Old Dec 7, 2007 | 06:44 PM
  #858
kungfugirl's Avatar
the boxes are in fact money, but whats up with the values in the top and side.
Old Dec 7, 2007 | 07:13 PM
  #859
Redlancer's Avatar
Delete my posting please...
Old Dec 8, 2007 | 02:41 AM
  #860
kungfugirl's Avatar
bump for help
Old Dec 8, 2007 | 09:39 AM
  #861
senate6268's Avatar
Originally Posted by kungfugirl
bump for help
I just re-opened your ROM and took a screenshot:
http://www.box.net/shared/xz20v52zz4
Old Dec 8, 2007 | 06:37 PM
  #862
TouringBubble's Avatar
You RPM and Load values need to have the endian changed. You are using ECUFlash 1.3+ I assume?
Right click an item in the lest on the left and select "Edit Map."
Click the "Scalings" button
Edit the Load and RPM scalings and change the Endian option ... I'm not sure if you need big or little, but you only have 2 options =)
This is a local issue, so it may be right on other machines and still display wrong on yours.
Old Dec 9, 2007 | 12:27 AM
  #863
kungfugirl's Avatar
can i just use 1.29a and not have any issues, since it seems this is correlated to my new version
Old Dec 9, 2007 | 12:33 AM
  #864
kungfugirl's Avatar
Why would my program display the values differently,
I got into the scalings and i am looking at the long list of adjustable scaling, i suppose i would click the main "load" section as well as "afr" but what am i changing, i dont know why of all people mine is so effed.
BTW can someone please help me with completing the definition! TY guys for help.
Old Dec 9, 2007 | 07:10 AM
  #865
Yes, 1.29 will correct the issue you have.
The problem is that the earlier version of ECUFlash actually had the endian wrong for several of the scaling values. In 1.31 or so this issue was fixed, but the scalings were not updated so they display all funky in newer versions.
To fix it ...
Once you get to that list of scalings, select "Load" and then click the "Edit" button at the bottom. The window that opens will have a drop down menu labeled "Endian." Just change that value ... there are only 2 options, "Little" and "Big."
Old Dec 9, 2007 | 10:58 AM
  #866
kungfugirl's Avatar
ok, just FYI the load needs to be small endian and the rpm needs to be big!
Old Dec 9, 2007 | 10:59 AM
  #867
kungfugirl's Avatar
TY guys, can anyone finish the defenition SOON. thanks guys, i am rolling now!
Old Dec 10, 2007 | 02:47 AM
  #868
kungfugirl's Avatar
Just downloaded evoscan, hope i can use this program without too much fuss!
Old Dec 10, 2007 | 12:58 PM
  #869
senate6268's Avatar
Done
File Type: zip
Old Dec 10, 2007 | 06:37 PM
  #870
kungfugirl's Avatar
Originally Posted by senate6268
Done
YOU DA MAN!
