***ECUFlash Now For Base Lancers!***
You will be hearing from me often in the next 2-3 weeks on this.
I downloaded evoscan and i will start to log tomorrow.
I kinda wanna ditch the fmu in favor of a set fpr and my 326cc injectors... this is for 5 psi.
I am hoping that I did this right...
Can someone please help me with a def file? 88250013 is the ID of the ECU.
06 Lancer ES Manual Trans.
Its to large to post here, even zipped (133K).
PM me and I will email the file (my FTP server is down right now).
Here is what I was able to define for you. The values in the 2006 hex were a bit harder to decipher than previous years. I was able to find like 90-95% of the data. The crucial areas were found, however - fuel, ignition, maf, idle, etc. If anyone is able to further define this ROM please post the completed definition file. Thanks!
wouldnt all the base Lancers share the same Ecu and programing?
i mean their all 4g94, Oz, Ls, Es, and what not and not what.
Im wanting to do this on my 06 Lancer Es Auto, what would i need in order to do this?
Also, there's the obvious difference between the ECU of a manual transmission and an automatic.
You need the Tactrix cable and a copy of EVOScan software.
Yes they may all have the same engine, but the similarities end there. There are several "flavors" or series of ECUs in all the Lancers. They all do the same things, but think of them as all coming from different factories, so they've been stamped with different codes. Same ECUs, just different identifying codes.
The ECU ID should be displayed when you pull your ROM... but if you missed it, it should also be written in the ROM file. Like senate mentioned, post it up for further analysis.
ok the file is too big so maybe i can email it. my email is dnlr3@aim.com
email me and i will reply with attachment. thanks
