Evo 8 ECU Swap Works!!!
Old Nov 26, 2009 | 08:43 PM
  #151
link62's Avatar
Originally Posted by Demon_ni2
well ive been thinkin about this for a while now.. debating on if it needs to be part of my new build. but no one has done it yet on an a/t..
same here i think you should get one and see if you can have epm getting working for u so you can help us other a/t with it
Old Nov 26, 2009 | 08:58 PM
  #152
Demon_ni2's Avatar
haha.. thanks for nominating me to do it. and tuning is all touringbubble, epm is metal fabrication shop
Old Nov 26, 2009 | 09:07 PM
  #153
link62's Avatar
haha yea well if you can get touring to do it that be a big leap for us a/t and i have a feeling you got a better chance with what u been having up ur sleeve
Old Nov 27, 2009 | 01:01 AM
  #154
4g94T's Avatar
It's possible, you'll have to run dual ECUs.
The original ECU will just be controlling the tranny
Old Nov 27, 2009 | 08:54 AM
  #155
senate6268's Avatar
That's pretty much the gist of it. It will involve some serious re-wiring as you will have two ECU harnesses spidered into the main harness. If you have a factory service manual, some extra ECU harness connectors and some patience it will work out OK. The trick is to figure out which input/output wires will be needed on the ECU and the PCM.
Better off just to swap to a manual transmission for power levels above 250whp. The amount of work that would be needed to hold 300whp+ on these transmissions (initially meant for under 120whp) would not be worth the money. You'd be better off taking $1200 and shipping your manual Lancer trans off to TRE (what I'm doing) for a stage 2 rebuild and a damn-near bulletproof trans that can handle whatever the 4G94 will ask it to throw down.
Old Nov 28, 2009 | 11:02 AM
  #156
steven121's Avatar
Is this for an auto? Because I thought that if you just get the evo 8 ecu everything would ok for a manual?
Old Nov 28, 2009 | 01:38 PM
  #157
senate6268's Avatar
Yes, that post was regarding the ECU swap for an auto Lancer. It is pretty much plug-and-play for manual Lancers.
Old Nov 28, 2009 | 07:22 PM
  #158
Demon_ni2's Avatar
haha.. well i got alot up my sleeves senate.. and a built auto trans is for testing to see how far it will go with some real upgrades.
Old Nov 28, 2009 | 07:47 PM
  #159
senate6268's Avatar
The amount of $$$ it would cost to make a Lancer auto trans hold that kind of power would be more than the value of some people's Lancers and, IMO, a complete waste of time, effort and money. And in the end, there's a pretty good chance that the power won't even hold past 300whp.
Old Dec 16, 2009 | 10:52 PM
  #160
vityenyka05's Avatar
so i got a question.. if i have a 02 lancer oz, and i got an evo 8 ecu, ... what do i do.. because plugs are the same?? has anyone tried it out.. ??
Old Dec 17, 2009 | 05:40 PM
  #161
senate6268's Avatar
Yes. That is what this whole thread is about. You can swap an Evo ECU into a 4G94 Lancer with minimal work.
Old Dec 19, 2009 | 08:34 AM
  #162
i understand that senate6268... ur the man.. this is crazy.. i wish i can aim you or something.. i got a few questions
Old Dec 19, 2009 | 10:29 PM
  #163
03lances's Avatar
I second that lol, Senates been a major part of keeping me on the right path ever since I started my thread and got serious about boosting my car
Old Dec 21, 2009 | 05:51 PM
  #164
OZ Rally's Avatar
Just picked up an EVO 8 ECU and hope to install it this weekend.
Hopefully it solves my problem of running rich then lean.
Old Dec 23, 2009 | 01:02 PM
  #165
senate6268's Avatar
You should take a look at your open and closed loop load tables and make sure they are switching at the right RPM, load and throttle % for your setup.
