Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Apr 30, 2010 | 11:08 AM
  #136
RoadSpike's Avatar
Originally Posted by link62
email sent
Ok talk about crazy wierd the id on the car changed from the def file you gave me here's you xml.
Old Apr 30, 2010 | 11:16 AM
  #137
RoadSpike's Avatar
Now that I've taken another look at it you have always had a 81870017 rom id so the xml I have for you is incorrect in many spots. I need your origional 81870017 xml. That or you can just copy the maps into it if you want yourself
Old Apr 30, 2010 | 11:30 AM
  #138
ClixT's Avatar
agreed. he doesnt have an 81870015 one its 81870017 lol
what a weird rom lol
Old Apr 30, 2010 | 11:33 AM
  #139
link62's Avatar
lol well that what senate put for his master def file "81870015 - 2003 ES, AT" but ill give the new one a try and ill send you the 17 one
but i do remember that senate never had a 17 one and when i used the 15 it would create the 17 one after using te 15 to inherit from
Old Apr 30, 2010 | 11:34 AM
  #140
ClixT's Avatar
i gave up lol. but i got ur 512kb rom working great.
UPDATE: im just stupid and ecuflash is not reading our ecus as an evo :fail: lol
Old Apr 30, 2010 | 11:36 AM
  #141
link62's Avatar
Originally Posted by clixt
i gave up lol. But i got ur 512kb rom working great.
update: Im just stupid and ecuflash is not reading our ecus as an evo :fail: Lol
lool
Old Apr 30, 2010 | 11:43 AM
  #142
link62's Avatar
sweet it worked i just need to set all the endian from little to big cause my x and y axis are messed up but it works now i can see the tranny map
Old Apr 30, 2010 | 11:46 AM
  #143
RoadSpike's Avatar
Lol yeah i just noticed that myself everything is fine except it was the old style of xml.
File Type: zip
Old Apr 30, 2010 | 11:49 AM
  #144
link62's Avatar
ok ill try this one out
Old Apr 30, 2010 | 12:05 PM
  #145
link62's Avatar
ok with new one everything normal so now im not sure what to change in the tranny map cause i dont want to make a drastic change it and it go boom and i see that it has the maps for 5th gear?
Old Apr 30, 2010 | 12:15 PM
  #146
RoadSpike's Avatar
I think the guys that did the mapping for the evo gta didn't label them properly where these maps are based on.
Couple things to try is decreasing the shfit time to 20 msec and see if it goes into gear faster.
And you can try adding a shift pressure just don't go crazy with it. Try adding like 30% to the pressure and see if its shifts into gear harder. Just drive slow because its going to be trail and error on how firm the shifts will become.
Old Apr 30, 2010 | 12:32 PM
  #147
link62's Avatar
ok ill give it a try
Old Apr 30, 2010 | 12:33 PM
  #148
ClixT's Avatar
ok, i finally figured out the root of our problem.
you need to have two def files separate(hence why it worked when i put the modded xml in the evo folder).
so heres what i did:
made a folder inside the lancer rommetadata, put the modded xmls inside it.
its also more organize that way.
Old Apr 30, 2010 | 12:59 PM
  #149
4g94T's Avatar
make it shift like an ISF!
Old Apr 30, 2010 | 01:14 PM
  #150
ClixT's Avatar
lols hey are you AT too?
