Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Jul 11, 2010 | 08:09 PM
  #571
03lances's Avatar
Let me point out that adjusting latencys will have no effect on open loop so it wont effect your afr tuning.
Old Jul 11, 2010 | 09:07 PM
  #572
bvasquez12's Avatar
okay i see, so if my fuel trims are in the negatives do i increase the latencies?
I dont know why it would do this either. maybe the ecu is different somehow>? even though i was able to flash the rom onto it.
Old Jul 11, 2010 | 09:56 PM
  #573
03lances's Avatar
Ok if the trims are negative this means the ecu is cutting that percentage of fuel trying to reach stoich. With latencies the higher the number the more fuel you will be giving and vice versa so you will want to lower that number so you will be giving less fuel.
Old Jul 12, 2010 | 10:05 AM
  #574
senate6268's Avatar
Are your idle trims negative or are your cruise trims negative? Or both?
Old Jul 12, 2010 | 09:01 PM
  #575
bvasquez12's Avatar
llooks like both, maybe my header is whats causing this. Also does reflashing the ecu make it relearn? or do i still need to disconnect the negative terminal for a while. today i disconnected it to fix some wiring issues with my headlights and right now it feels like my car is running GREAT. but maybe its the placebo effect
Old Jul 15, 2010 | 07:18 PM
  #576
bvasquez12's Avatar
sooo does reflashing reset the ecu? or do i still need to unplug the batter?
Old Jul 16, 2010 | 09:12 AM
  #577
RoadSpike's Avatar
Depends.
On the evo 8 for example flashing the ecu with the same rom but modified doesn't reset fuel trims, on the evo 9 it would. If you flashed a different rom id then fuel trims reset regardless.
Old Jul 23, 2010 | 01:01 PM
  #578
Lancerboi808's Avatar
ok this must be a stupid ???? when dowloading the ecuflash its pops out asking Windows Logo????? and when i open the roms its reads weired words. do i need to download some kind of programs???
??????LMK
Old Jul 23, 2010 | 01:13 PM
  #579
RoadSpike's Avatar
??????LMK
It does not sound as if you have installed ecuflash on the computer.
The roms themselves should not be double clicked from the desktop it does not associate roms like other programs, ie winamp. Open ecuflash and use the open file dialog to open a file from the program itself.
If you are still getting these issues print a screen shot and show us whats going on.
Old Aug 17, 2010 | 11:38 PM
  #580
RoadSpike's Avatar
I'm pasting in this new xml because i'm tired of emailing peeps
One experimental portion is the speed limiter of 93mph we'll see if it works if not i'll just update this post.
File Type: zip
Old Aug 18, 2010 | 12:41 AM
  #581
4g94T's Avatar
Cant wait to try it!
Old Aug 19, 2010 | 05:09 PM
  #582
4g94T's Avatar
RS, I raised the value to 140 and still no go.
It cut timing, but not fuel.
Then I raised both values with the same results.
I hit the stock limiter on both WOT and slowly approaching the rev limit
Old Aug 19, 2010 | 05:22 PM
  #583
RoadSpike's Avatar
Damn back to the drawing board i guess
Old Aug 19, 2010 | 06:14 PM
  #584
RoadSpike's Avatar
4g94t
Add this to your XML
<table name="Timing Override" address="1914a" type="1D" level="1" scaling="Hex16"/>
The default should be 0x2ab1
Override this with 0x9
I found this is one of the few places where i can see a set value overriding the timing in ram so lets give this a shot
Old Aug 19, 2010 | 06:36 PM
  #585
4g94T's Avatar
Like this?
Attached Thumbnails Confirmed:  Evo ROM Can Be Flashed to Lancer ECU-untitled.jpg
