how to log your AEM EUGO with evoscan
Old Jul 8, 2017, 06:50 PM
  #136
Sickmode7's Avatar
Coolly
Originally Posted by mines5
Thanks buddy..
cool happy boosting
Old Feb 10, 2019, 07:58 AM
  #137
TheLancerLife's Avatar
Hi I can not get passed step 5 for some reason I get the error code the given key not present in dictionary.. has anybody gotten this error?
Old May 21, 2019, 08:35 AM
  #138
UrbanSmoker's Avatar
hey guys, im trying to input these values to log, but unfortunately im getting an XML Error, says i cant save the file until XML errors are corrected, problem is this is a fresh install of evoscan, and i have not changed anything in the XML other then the omni 4bar settings found here https://www.evolutionm.net/forums/ec...evo-8-9-a.html
also with the newest version there are some ECU and vehicle choices, for some reason it wants to default to 1g DSM. do i use ACD evo 7-8-9? i changed the Omni XML in the MutII EFI XML.
any help would be appreciated. my car is a USDM 9MR
EDIT:
so instead of doing it that way (add new item) i just went directly into the XML and replaced WB02 logging value with the AEM Widebands values seen in the first post. it seemed to change it without error, hopefully it logs.
edit#2 and it does log! The formula is definately off at WOT. Is messing with the formula literally trial and error?
Is there a good thread around here that explains evoscans map tracing feature a little better? The table it shows when I load a log is not at all what I have in ecuflash. (But I’ll leave that for the correct thread)
Old Oct 7, 2019, 09:54 PM
  #139
Originally Posted by darkmitsu
How to log your AEM EUGO with Evoscan
Prerequisites...
-Tactrix Cable
-AEM EUGO wideband (already installed and working)
-Evoscan (installed on a laptop so you can plug into the car using the tactrix cable to take logs)
-Lancer evolution 8 ecu
Step one
cut wire connecting to pin 75 leaving some wire hanging out of the ECU , you will tap into this wire with your aem gauge . Your aem gauge will have red , black , blue , and white wire coming out of it . The red and black are, red for power, and black for ground these 2 wires power your aem gauge, the white wire is an analog output wire you will be connecting this wire to the wire going into pin 75 on the ecu.
step two
Launch evoscan
step three
Right click any scanning object in the list and click the option edit data item.
Attachment 292459
step four
click add new item in the bottom left hand corner , new item option will apear on the right hand side where you will input all the data from the next screenshot.
Attachment 292460
step five
display: AEM UEGO
LogReference: AFR
RequestID: 3C
Eval: 0.03913*x+9
Unit: AFR
MetricEval: 0.03913*x+9
MetricUnit: AFR
ResponseBytes: 1
GaugeMin: 5
GaugeMax: 20
ChartMin:5
ChartMax:20
ScalingFactor: 10
After inputing this information , click OK .
I tried this 0.03913*x+10 formula but my AFR display on the Gauge and what was displayed on the log were off by 1 so I edited the formula to 0.03913*x+9 ...
Attachment 292461
step 6
You will now have a option within evoscan to select AEM EUGO and can log your wideband now without having to plug in an extra serial cable ...
Attachment 292462
step 7
Now open ecuflash and edit the table below to 0x0009 to get rid of the rear o2 heater cel...
Attachment 292463
do you have this info for AEM x series 4.9 LSU sensor gauge? They are quite different, as more people get the newer gauge the settings would be nice to have access to. (The gauges and sensors are completely different)
Old May 29, 2020, 07:41 PM
  #140
ScubaStevo's Avatar
Has anyone gotten this to work with the X series 30-300? I've tried so many equations.. Including all in this post and most others that ive found.
Old May 2, 2022, 06:00 AM
  #141
Wulfen's Avatar
I derived this equation from AEM's data set, it is accurate on my 8MR
The eval for the AEM X-series Wideband is 0.046787*x+7.31845
Make sure to connect the Brown wire to Sensor ground in the ECU, NOT chassis ground.
Old Dec 31, 2022, 05:41 AM
  #142
mines5's Avatar
Hi Wuffen,
What is the request id in evo scan ? 3c ?
Which pin did you connect the white signal wire to ?
darkmitsu
Lancer Engine Tech
282
Feb 27, 2024 01:31 PM
xPRimNT
157
Dec 26, 2018 08:09 AM
Evo8life
Dec 2, 2017 06:05 AM
eazlan
May 7, 2017 01:30 AM
doom26464
Cobb AccessPORT
40
Mar 23, 2016 07:42 PM
Quick Reply: how to log your AEM EUGO with evoscan
