Lancer Sputtering
Old Mar 30, 2007 | 09:51 AM
EvoDimension's Avatar
Lancer Sputtering
my 1.6 L 02 Lancer es sputters while acceleration and while driving. It cant make it up hills past 15 mph and the sputtering sound gets louder as I hit full throttle. I changed my spark plugs and the Lancer drove normally for a little over a week, but it started messing up again.
New NGK Spark Plugs
New Spark Plug Wires
Really Old Air Filter on Short Ram
No Oil Change since around 8 Months (oil is full)
140k Miles
Based on this info does anyone know what could be causing this?
Old Mar 30, 2007 | 10:38 AM
blaze_125's Avatar
how are the coils?
are you getting fire in all cylinders?
is the check engine light ON?
has it come ON at any time?
are your plugs wired in the proper order?
any mods done to your car?
has the MAF been damaged?
is the battery holding it's charge? (bad battery can cause weird problems, I learned that the hard way this winter.)
No oil change for 8 months? I don't care how full your oilpan is... 8months???? I can barely stand going 7 weeks.
Old Mar 30, 2007 | 10:44 AM
atilla's Avatar
you should change your oil a bit more often than that. i bet your oil is nice and gross by now.
could be an issue with one of the cats, too... does either smell funny or glow?
Old Mar 30, 2007 | 10:48 AM
blacklancerr's Avatar
mines doing the same thing. my warm up cat is bad. does it sputter ALL the time, or is it ok sometimes?
Old Mar 30, 2007 | 10:59 AM
grapeapeoftokyo's Avatar
change the air filter and oil. more than likely its the filter but you should definately change your oil. start small and if it doesnt fix it work your way up.
Old Mar 30, 2007 | 11:29 AM
Check engine light hasnt been on since I bought the car. Plugs are in properly. New Battery.
The bad thing about my Lancer... it sputters constantly.
My grandpa said it could be the ignition coil... does that have to do with the cylinders receiving fire?
Old Mar 30, 2007 | 11:43 AM
yes sir. very well could be the coil packs
Old May 7, 2007 | 05:20 PM
wOZrally's Avatar
im having the same problem. except for my CEL is on and getting a code for random misfire and burning rich so my guess it must be the coil packs as well
NOFATCHX
Pacific Northwest
14
Dec 11, 2012 07:04 PM
redjones3001
Oct 23, 2010 11:22 AM
Xx_VeLcRo_xX
17
Apr 17, 2010 08:17 PM
bboy_RES
Apr 10, 2010 06:01 PM
EVIL_EVO_VIII
13
Oct 14, 2007 09:43 PM
