DarkMitsu's 4g64 Swap Page
Old May 31, 2011 | 05:50 PM
  #256
bvasquez12's Avatar
traction will be a problem with any fwd high power vehicle, that doesnt mean it wont be fast and run good...
Old May 31, 2011 | 06:18 PM
  #257
Demon_ni2's Avatar
just drop that bish in the lancer.. all i knows is.. at 24psi.. i dont have 'traction' issues.. if anything im making to much traction. just grab some mickey thompson DR tires for the street if u wanna get into some trouble im running 235/60/15s.. but they in no way clear (but i made em fit) u can get the 205/50 or 225/50/15s should work just fine, and plenty more traction then any honda out there. u do have to remember we dont have the same type of suspension setup.. we dont have near the suspension travel or rotation issues that hondas have. i dont get wheel hop at all. 7k launches with my 26'' DRs are NASTY fast on street or strip. plenty of mirages running fwd evo setups on stock motor n turbo deep into the 11s with just a small set of slicks.
on the small turbo.. maken 350+ u wil be a spin king below 50mph. DRs make a WORLD of difference.. bigger turbo guys with sticky tires dont seem to have as many issues on the street.
When this Motor goes, ill be swapping to a built 2.4 evo setup. and aiming for 750-800hp with a huge gt47r turbo for looks..
Old May 31, 2011 | 06:32 PM
  #258
WADADLIG_OZ's Avatar
Did this swap ever reach the track?
Old Jun 2, 2011 | 04:25 AM
  #259
Jehuty's Avatar
He doesn't seem (and I could be wrong) to have intentions of making his lancer full blown street, and if that's the case he doesn't need to do a swap like this to then have expensive maintenance with tires. There is just no point to it. I'm sure I'll probably be compared to Amby for saying it, but it's just not worth it. He has other ideas too on what he wants to swap it to that could prove just that much more effective.
Old Jun 2, 2011 | 04:34 PM
  #260
darkmitsu's Avatar
No, never run it at the track , brought it out there a couple nights , but just didnt see any mitsubishi's running down the lane , so I kept it on the side lines as well... but I have put a lot of miles on it since the swap , it is totally streetable in 4g64 form , since the swap has been done I got tied up in project, after project, after project, so many to list... I will be going again end of this month and just may run it , because I got a new daily driver in the works, and wont have to worry about beating on the lancer.
Old Jun 2, 2011 | 04:36 PM
  #261
darkmitsu's Avatar
You are correct I have a faster car 4g63 swapped car ATM , and want to keep the lancer streetable ...
Old Jun 2, 2011 | 06:42 PM
  #262
Having owned an OZ in the past, I was just wondering if any of the 64 swaps ever put down a time to see what differences the extra tq/hp made. I see you dyno'd yours.
Old Jun 8, 2011 | 12:22 PM
  #263
steven121's Avatar
any possible way we can see custom motor mounts for the car?
Old Jun 13, 2011 | 11:02 PM
  #264
bvasquez12's Avatar
whats not streetable about this, its not like your gonna have to gut it, and chop up the harness and use an EMS etc etc, everything is in place.
If anything its more streetable, the 4g63 is pretty damn reliable and can take a good beating, so having it at stock evo power levels with a lancer body should be nothing but fun, itll put you at about 250 whp being that the evo is around 220-230 stock, plus drivetrain loss, sounds like the PERFECT amount of power for such a platform with a GREAT amount of reliability.
Old Jun 30, 2011 | 11:14 AM
  #265
steven121's Avatar
Just wanted to get an update on this swap and had a few questions
-If I do this, I need a 4G64 motor from an eclipse or a galant right? Im going to get it built to handle the power I want
-Then I buy a 4G63 head to bolt on the top
-Now since Im doing that Im going to get a evo 8 intake manifold do I need any special wiring for that? Im assuming no because the stock lancer can run the evo 8 rom with no issues, except for the codes being thrown due to the boost solenoid.
-What does the custom motor mounts look like?
Is there any way I can just buy a transmission without taking it apart?
Old Jul 1, 2011 | 07:02 AM
  #266
darkmitsu's Avatar
ok guy's , ran it at the track last night
r/t .9218
60ft. 2.5892
330ft 7.2280
1/8 11.0764
mph 63.83
My times were all different on every run depending on traction and my mph ranged from 61-64mph...
Old Jul 2, 2011 | 03:07 PM
  #267
bvasquez12's Avatar
r/t .9218
60ft. 2.5892
330ft 7.2280
1/8 11.0764
mph 63.83
so 0-63mph in 11 secs?
Old Jul 4, 2011 | 05:37 PM
  #268
darkmitsu's Avatar
yeah its a slug , it feels fast but its a slug, here is some 0-60 to compare ...
2004 Mitsubishi Galant ES 0-60 mph 9.1 Quarter Mile 16.8
1995 Mitsubishi Eclipse GS-T (Manual) 0-60 mph 6.3 Quarter mile 14.8
1995 Mitsubishi Eclipse GS 0-60 mph 8.9 Quarter mile 16.4
1993 Mitsubishi Mirage Coupe LS 0-60 mph 10.9 Quarter mile 17.8
1994 Mitsubishi Mirage Coupe LS 0-60 mph 8.6 Quarter mile 16.4
Old Jul 5, 2011 | 09:37 PM
  #269
bvasquez12's Avatar
:-( try flashing that eclipse rom i sent you onto it and run it again.. see if it makes a difference, being that your running evo maps!
Old Apr 16, 2014 | 07:17 AM
  #270
Thahomeboyb's Avatar
I plan on doing the swap to my 02 lancer I was thinking going with an evo head but I'm not sure. If my car is automatic can I leave it automatic or do I have to switch it to manual .
