GTS with EVO X Cams
Old May 22, 2020 | 01:17 AM
  #151
bumblebee.4G69's Avatar
5 Year Member
There was talk earlier in the thread on how to tell what the injectors looks like by looking at them
The 4b11 ones are here
http://imgur.com/a/BPsUOhO
See that white band on them , that's how you tell if they are 4b11
Evo X / Ralliart injectors don't have a white band, they have a red band (and obviously the part number is different)
http://imgur.com/a/rBE7TF4
And 4b12 injectors look the same at the others but with a different colour band and part number
http://imgur.com/a/DAF1t30
So that's how you can tell the difference of the OEM Injectors by just looking at them
Hope this helps
Old May 22, 2020 | 03:04 AM
  #152
Blackgts10's Avatar
Originally Posted by Wanchai Panpron
Swap cam shaft with different design and no fine tune will make your engine hiccup.
If you tune the ECU , there no need new cam shaft .
Originally Posted by jajk
Blackgts10 200hp is a walk in the park for a stock 4B12 without "bolt ons".... providing you have a 5MT.
Stock evo x cams do not require the springs to be replaced and are only really useful if you increase the throttle size, improve exhaust and intake system first. If you have a CVT, forget it!!! A tuned stock 4B12 is more than capable of destroying the CVT and the TCM will be limiting available torque and rpm anyhow....
Heck no man its a manual i would be scared to even add a cai to a cvt lancer! lol i'll start with the small stuff first. After the cam and springs should i just tune it and be fine to daily? That should give it some decent power!
Old May 22, 2020 | 05:30 PM
  #153
jajk's Avatar
5 Year Member
Blackgts10 Installing cams is easy but tuning for different cams is far more complex than it first appears......do you already know how to do this? I see plenty of well known "Pro Tuner" attempts that prove most of them have no idea either.
So think twice before doing something you will regret. Did you notice I said stock evo x cams do not require springs to be changed and no point in doing cams before improving intake? Also evo x exhaust cam is exactly the same as 4B12 ex cam so zero gain in changing that.
The starting point is always to do absolutely nothing to the engine before you establish the ability to comprehensively log it. This require you to download the current ROM, create a suitable definition file, enable mode23 and reflash it. Then you need to create a logging configuration file for either SDCard logging or Evoscan logging. Then you take the car for a few runs and establish a baseline log for a WOT run in 2nd gear from below 2000rpm to rpm limit.
If you haven't done all of this, you are just blowing smoke out your @#$% and you are just a "decorator".
Not having a go at you personally, just pointing this out to all who think about going down this path....
Old May 22, 2020 | 09:17 PM
  #154
Blackgts10's Avatar
yeah im not trying to be a ricer ive just never had a tune done i dont know the exact process thought u just went to a tuneshop or got a manual tuner. I saw somebody posted that the x springs will give you some more durability. I was gonna do the stupid stuff first like exhaust and headers. Its just a ****box anyway i guess so i'll just keep it stock and do nothing to it.
Old May 22, 2020 | 09:41 PM
  #155
jajk's Avatar
5 Year Member
4B11T springs have more seating pressure to combat valve bounce at much higher rpms than you will sensibly operate the non-turbo (much weaker) variants of the 4B1x engines. Stronger valve springs are required if going to a typical stage 2 cam (270 degree duration, over 10.5mm lift) but stock springs can handle up to a stage 1 cam (260 duration, less than 10.5mm lift)
Old Mar 25, 2021 | 02:11 AM
  #156
MitsuLancer4Evo's Avatar
I agree with what you said!!!
Originally Posted by Evo10HKS
well transmission wise, i tihnk those high HP numbers have to do more with boost. Rather than NA numbers. im sure the tranny can hold 200 at the wheels all motor. i think the turbo is what puts the stress on the tranny i could be wrong here so someone with more knowledge on the actual issue with the CVT if you could chime in that would be great. because rumor is, is that the altima and the dodge caliber all use the same CVT as us. and the highest hp motor of those is 171. so i dunno i would like to know more about possible tranny issues with this.
If RRM has a Turbo Kit that is specifically designed to handle 09-15 Lancer ES, DE, GTS with CVT Transmissions under low boost that would give the Engine about a theortical 40% more HP (164HP x 1.40 = 230 HP) then I really don't see what the problem is with installing Evo X Cams/Brain Crowler Cams in a CVT Transmission. I do totally agree with what was mentioned about installing new valve springs, retainers, valves, valve tappets/lifters to be able to handle the new Lobe Duration and Lobe Lift since the new Intake And Exhaust Cams will put alot of stress on the Valve Assembly of your 4b11/b12.
Old Mar 25, 2021 | 02:22 AM
  #157
Can You Prove That!
Originally Posted by yitzac1990
he might as well have just swapped in an evo motor. it goes right in lol
I am sure you have'nt swapped out a 4b12 engine and CVT assembly for an 4b11T and Evo Manual Transmission yourself if so please enlighten us?
Old Nov 18, 2024 | 08:51 AM
  #158
Fr0styGTS's Avatar
Originally Posted by derrickeliu
Hi Again: CARVS you are wrong when you said that Puerto Rico lancers are all 2008 GTS, I have a Rotor Glow Color 2009 GTS with 172 whp and 176 tq (flash tune)stock 4b12 cams. if you read my post about cams i mentioned that in a 4b11 N/A you can install 4b12 cams and EVO X cams.you dont need to wait for a company to develop cams for our cars because they all ready exsist. ANY EVO X CAMS WILL FIT OUR ENGINE PROPERLY , 4B11 NA AND 4B12 ENGINES. MY TUNER HAS A 2009 GTS 4B12 WITH BRIAN CROWER STAGE 2 CAMS (272) MAKING 196 WHP.MANY PEOPLE IN PR HAVE DONE THIS MOD WITHOUT ANY PROBLEMS. JUST WANT TO SAY THAT I RELEASE THIS INFO BECAUSE I LIKE MY CAR AND WANT TO HELP PEOPLE THAT LIKE THIS CARS LIKE ME.
HEY PEOPLE BUY EVO CAMS , INSTALL THE CAMS,TUNE YOUR ENGINE AND THEN SEND MY A MESSAGE GIVING ME THANKS . IF SOMEONE HAVE A QUESTION BE FREE TO WRITE ME A MESSAGE
So I plan on putting stock EVO X cams in my 2009 lancer gts, but id like to know if its simply put the new cams in and get it tuned and your all set or is there other stuff I should replace or install along with the cams.
Old Feb 24, 2026 | 12:37 AM
  #159
Minho731's Avatar
Components needed?
This is probably a dead thread by now but I've got a 2017 Lancer that I have access to a pretty defined XML with my ROM, am I able to install EVO X Cams without having to replace the retainers and springs?
dadsgts
May 12, 2010 10:32 AM
Yearlongstorm
50
Aug 24, 2009 06:28 AM
TwStDeVo
Aug 30, 2006 06:18 AM
EVO_EDGE
Aug 20, 2005 08:31 PM
