Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
**How to change your oil**
Old Mar 14, 2007 | 04:46 PM
Lusion's Avatar
I believe its 3.4
Old Mar 14, 2007 | 06:07 PM
atilla's Avatar
4 quarts (with filter).
Old Mar 21, 2007 | 07:56 PM
import_speedzz's Avatar
Alright thanks guys! I put 4 quarts of Royal Purple 5W-30.. I just made the switch to synthetic and im on 93,xxx miles..
Old Mar 21, 2007 | 10:59 PM
grapeapeoftokyo's Avatar
[QUOTE=wickdaddy;3655189]when i first got the car, i did have problems when i would blow it off and then not hit the gas, i would stall out bc of being too rich, but now, since i had my SAFC tuned a bit more, i don't fall into that problem as often, but occasionally it happens.
your stalling because your blowing off metered air. you need a return from the blow off back to the intake. just thought i would put that our there.
http://www.roadracemotorsports.com/images/autoturbo.jpg
it is the tube running along the intake from the blow off back.
apologies for being off-topic.
Old Mar 22, 2007 | 06:47 AM
wickdaddy's Avatar
yes, I know that technically it should be recirculated to read properly with the MAF, but I am not really pulling 450whp, so for now, I'm going to enjoy the loud VTA BOV I will soon be tuning with openECU and will not have to worry about my SAFC anymore!
Old May 16, 2007 | 09:57 AM
Joho22's Avatar
i just felt like my RA was a little low looking with only 4, i think it took 5 after filter.
Old Nov 15, 2007 | 01:46 PM
tjbartjr's Avatar
What's the torque spec for the drain plug?
Old Jun 24, 2008 | 08:07 PM
bcollinstex's Avatar
Back from the dead!
29 ft pounds +/- 3
Old Oct 24, 2008 | 01:40 PM
luischav3z's Avatar
Any of you guys know wat is the difference between the 5w30 and the 10w30?
Old Oct 24, 2008 | 03:11 PM
Lucas03ES's Avatar
Here you go
http://synthetic-motor-oil-air-filte...-30-10w-30.htm
Old Oct 24, 2008 | 03:38 PM
YeOldeLancer's Avatar
Originally Posted by kfos01
Then maybe you can explain this debauchery...
https://www.evolutionm.net/forums/sh...d.php?t=226625
What the HELL were you doing?!
This thread is funny as hell!
Old Jun 3, 2009 | 12:57 PM
toolmanblink182's Avatar
Just finished changing my oil today, the size of the socket I used to remove the drain plug was 17mm. Thats on a 4G94 Engine
Old Jun 11, 2009 | 05:56 PM
green hornet's Avatar
This helped when I changed my oil. Thanks for the write up bro.
Old Aug 8, 2012 | 05:19 PM
Corey_07's Avatar
Thanks for the thread, embarrassingly enough, I do not know how to do much with cars, not even change my oil lol. I do want to learn more, that is why I joined this forum. I think I may try this weekend, a jack is not enough, you need jack stands in case of jack failure?
crypto
Lancer How Tos / Installations
22
Feb 1, 2017 11:39 AM
clifhanger87
46
Oct 30, 2016 07:11 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
blaze_125
Lancer Tranny/Drivetrain Tech
29
Mar 24, 2016 10:02 PM
chaotichoax
Feb 7, 2010 10:20 PM
