iPod Idea
Old Jan 23, 2007 | 08:14 AM
drucea's Avatar
ok good so this one for $31 has nothing to do with the FM thing? If so, I will definately be getting this.
Old Jan 23, 2007 | 10:15 AM
johnjonfenomeno's Avatar
If you guys look at the installation manual in pdf. the unit comes with a component much like the alpine 420i.. So in a sense you will get pure digital sound through your radio and not a crappy FM transmitted one.. The mods should make this a sticky and someone should post a step by step how to on the install...
Old Jan 23, 2007 | 02:24 PM
Joho22's Avatar
Originally Posted by johnjonfenomeno
It should as that is where most factory locations place their ipods if the vehicle is equipped with such a unit...Plus its OEM part.
yeah, im pumped, Im gonna order it probably in 2 weeks.
stupid biweekly checks.
Just started a new job.
but yeah def to that find.
and another to the OEM
Old Jan 23, 2007 | 02:26 PM
Joho22's Avatar
when i install ill take many photos.
and ill say exactly what i do.
just so everyone knows, im really excited right now.
I ASSUME this will charge the ipod too?
Old Jan 23, 2007 | 02:40 PM
Joho22's Avatar
After throughly reading the instructions in the PDF file,
I am going to make my own alterations to the install.
Instead of placing my ipod in the glovebox,
where i would be retarded to place it IMO,
I am going to go with my planned mod.
Im going to replace the factor hinge on the arm rest,
with a hinge that can open 180 degrees,
and mount it reversed, so that it opens towards
the stick shift / front of car, where i can use/reach it.
I will cut a mount for the ipod with the dimensions
needed to keep it snug.
To keep it in place while upside down is something I am not 100% on yet.
(VERY open to ideas)
I will run the cable under the carpets to the arm rest,
cut accordingly so that the mounted Ipod will be reached,
charged (if the part does that, which i hope it does) and makes me happy.
Im not sure where to place the adapter main unit yet,
but I would like to keep it out of sight if possible.
Maybe in that little sunglass holder below the dials and above the cig adapter?
Any ideas or suggestions welcomed, im taking measurements now.
Old Jan 23, 2007 | 02:53 PM
Joho22's Avatar
If you look,
I may be mistaken, but is it showing me to have wires externally on
my dashboard?
cause im not cool with that.
I will find some way to make this an almost all internal job.
they seem adamant about that unit being in the passenger side
wall thing....
dunno if were getting around that.
Ideas again?
Old Jan 23, 2007 | 03:51 PM
otter's Avatar
EvoM Administrator
You're looking at it wrong. It shows the wires being routed behind the dash. The iPod end drops into the glovebox, and the signal end goes to the back of the headunit.
Old Jan 23, 2007 | 05:14 PM
Joho22's Avatar
ok now i see where it goes into the back,
I definately dont want it in my glove box,
Im gonna have to try to find a way to send that to my arm rest.
Think its possible?
Old Jan 23, 2007 | 05:58 PM
[C-4]PUMA's Avatar
Anyone have a part number for this thing to order it straight from a mitsubishi dealer?
Old Jan 23, 2007 | 07:23 PM
drucea's Avatar
to get it to your armrest, run it back behind th head unit, then take out your center console (the oart with the cupholders) and run it under there. Thats where I planned on running it. I'm having my buddy make me a custom armrest top that has a spot for the ipod with the charger/plug for audio in it so the arm rest is still flat on top.
Old Jan 23, 2007 | 07:30 PM
TouringBubble's Avatar
I did something similar ...
http://www.frameleft.com/evo/gallery...s/100_3231.jpg
There is room beside the e-brake to mount the control box if needed. It's kind of a pain to hook up though. I just used an old universal cell phone holder for my mount instead of fabbing something. the mount is big enough for my video iPod and can also hold my wife's Nano.
I did not use the Mitsu controller though .. I've got a Sony head unit.
Old Jan 23, 2007 | 07:39 PM
drucea's Avatar
Thats pretty good. I'll have to draw something up for what I'm doing. My ipod will be on the top of the arm rest on the outside so I can change it.
Old Jan 23, 2007 | 07:44 PM
If you get an iPod control unit you will change the iPod using the head unit, not the iPod itself. The control unit is the only way to charge the iPod w/o the cigarette lighter plug.
Old Jan 23, 2007 | 07:50 PM
drucea's Avatar
oh ok, well will it show whatevers on the ipod screen on the head unit? if not, then i'll mount the ipod somewhere visible so I can see whats playing.
Old Jan 23, 2007 | 07:53 PM
I don't know if the stock unit will show the track that is playing. Most aftermarket units will. Mine is odd ... it shows the artist/album/title and scrolls it if needed, but then it disappears after a few seconds. I honestly haven't played with the settings on the head unit to figure this issue out ...
