EVO 8 body kit on Lancer ES 02-03
to be or not to be is the question here..haha you can pull it apart.... but can you put it together? lol just kidding good to see some progress keep it you still have alot of work with only 2 weeks and change left
Okay well it is now the first of June, so i figured I would post the most recent pics i have. Not quite as far as I thought, didn't know I would have needed a new engine. And it took a little while to right deal on the welding/cutting tools. But its coming along good. let me know what you all think. The V8 would have been MUCH easier haha.
GT FRONT END STRIPPED
GT LEAVING
MY NEW DRIVE TRAIN
THE LOVELY WIRING
300HP
HEAVY!
NO ROOM IN THE GARAGE
TIME TO DISASSEMBLE
OIL PAN WHEN I PULLED IT OFF =/
BUSTED CRANK
JUST LOVELY!
PULLING IT APART
SINGLE TURBO HAHA
THE TWIN TURBO 4 CYL HAHA
ROD JAMMED
THE NEW SUBFRAME
PLASMA, MIG, AND 27 GALLON AIR COMPRESSOR 700$
NEW REAR END =)
WHERE THE NEW REAR MOUNT WILL BE
NEW FRONT REAR MOUNT WILL BE
FRONT AGAIN
FRONT MOUNTS ARE CLOSE
STEERING WILL BOLT RIGHT UP
TO BE SOON
BLOCK STRIPPED
GT LEAVING
MY NEW DRIVE TRAIN
THE LOVELY WIRING
300HP
HEAVY!
TIME TO DISASSEMBLE
BUSTED CRANK
JUST LOVELY!
PULLING IT APART
SINGLE TURBO HAHA
ROD JAMMED
THE NEW SUBFRAME
NEW REAR END =)
FRONT AGAIN
TO BE SOON
BLOCK STRIPPED
Finally made my own thread with a s*** ton of pictures. So i will be posting there now.
https://www.evolutionm.net/forums/la...ml#post7140327
Wheel safe!
Wheel safe!
Hello! sorry if my comment is off topic, but I wanted to share my ideas:
I saw some discussions about if your conversion is vaild or not but I have seen this:
Analyzing the pictures of the Lancer Evolution 2005 WRC, I see that is a Lancer Oz or ES
, with some body kit, but it still an EVO, I know it is AWD with Brembo brakes etc, but I feel that mitsubishi is saying us, hey you can take whatever Lancer and build your own EVOLUTION because your imagination does not have limits
Check the front, I see a Lancer ES or OZ 2001-2003, the headlights are not the EVO VIII ones, look the fenders, they are worked on the stock chasis, they are not on the stock EVO VIII fenders
Check this other one, the tail lights are not the EVO VIII ones
, they are the Es or OZ ones, the rear fenders are worked to accept the tyres, and the rear bumper is not the EVO bumper is the ES or OZ one:
Then I think we can take our Lancer ES, OZ, Ralliart, Evolution, and create
the monster that we want, FWD, AWD, RWD.
I just say you: go with your proyect!
:Check the front, I see a Lancer ES or OZ 2001-2003, the headlights are not the EVO VIII ones, look the fenders, they are worked on the stock chasis, they are not on the stock EVO VIII fenders
Granted time and time again. Anything can be done with $$$. You can't make our lancer look and work like the Lancer WRC with $5-10k. Mitsubishi dumped a lot of $$$ into making that thing. Yes that's our chassis, but with the money you have trying to make the lancer into a beast like that.... might as well get an evo or rebuild the entire engine and try to make it a mini-monster and aim for something more attainable to us like 200-300 hp.
there is a video somewhere of a rally team building a subaru. They start out with a stock STI, then completely strip it down to the shell and then rebuild it.
