EVO 8 body kit on Lancer ES 02-03
This swap is definitely possible. But not with the budget and time you gave yourself.
I'm taking electrical automotive right now (go to UTI) and lets just say, trying to make a custom wiring harness will take you more than 3 months.
You need to know what the difference is between series, parallel and series parallel circuits. How many volts, ohms, amperes, and resistors you need in each connection. That's just off the top of my head.
I am rooting for you and want you to pull this off. Oh and I have the diagrams but can't figure out a way of sending it to you since my scanner is effed up.
So you need the ECU wiring harnesses and diagrams for both cars right?
If so I'm not sure I can send you 100+ pages.
I would recommend getting a service manual for each car, that way when you run into an issue the solution will be right in front of you.
Me thinks what you need won't be in a service manual. Your best bet is to run a full standalone ECU for the mustang motor and tune it to work with the Lancer electronics (if needed). Of course a good standalone costs 1000$ so that's two-thirds of your budget gone right there.
http://www.alldatadiy.com/buy/index.html. It has the whole repair manual online where you can print all of the documents you need. The only bad thing is it expires after the subscription. If you have time i would print out all the documents at a library before it does expire and you'll have the whole Repair Manual for our Lancers.
Let's keep this on topic please. This is about a build. Nothing more. Nothing less.
Good luck with this. I will be impressed if and when it is finished.
