CEL on RRM Headers
Old Jun 25, 2003 | 08:52 PM
pumpdog720's Avatar
CEL on RRM Headers
Who here that have the RRM Headers has had there check engine light come on after it is installed, and what can be done to make it go off if it does come on?
Old Jun 25, 2003 | 08:55 PM
ryancb's Avatar
SEARCH ....its norm chk ilp for cel fix
Old Jun 25, 2003 | 08:56 PM
ghostrider's Avatar
Everyone's CEL comes on with a header install cuz it removes the 1st cat and causes both o2 sensors to get the same reading. Except for my magical RPW header which hasn't triggered the CEL, and I've been using it for months now...
There's a CEL fix you can buy from ILP that wires into the 2nd o2 sensor to fix your problem.
Old Jun 25, 2003 | 09:02 PM
Satrona's Avatar
will CEL cause any problems with the car...or does it just show the light (check engine)?
Old Jun 25, 2003 | 09:03 PM
Boeturbolancer's Avatar
causes no problems with the car... however if something else does occure then you won't know as the light will already be on.
Old Jun 25, 2003 | 09:05 PM
Satrona's Avatar
okay, thanks
Old Jun 25, 2003 | 09:06 PM
Satrona's Avatar
hey Boeturbolancer...you seem to have a lot of RRM stuff on your lancer, are you happy with its performance and everything? because im looking at RRM to get my gear
Old Jun 25, 2003 | 09:12 PM
pumpdog720's Avatar
So if you get the headers and test pipe... you have no cats?
Old Jun 25, 2003 | 09:17 PM
Satrona's Avatar
pumpdog720, since you mentioned a test pipe, i have a question for you. on RRM website, it says not to drive on freeways and such with a test pipe. Why is this? and if you get one, do you have to trade the stock and the RRM one back and forth depending on the condition?
Old Jun 25, 2003 | 09:20 PM
pumpdog720's Avatar
Well I think it's mostly because of the smog restrictions and stuff like that, so you can get busted if you drive without your cat, but if you live in a place like me in FL, where there are no checks, then you can get away with it.. just don;t take it to the dealership. But you can drive with it on.
Satrona's Avatar
alright, thanks a lot!
Old Jun 25, 2003 | 09:22 PM
Satrona's Avatar
im looking at the RRM site and it shows a GReddy catback exaust system...and then lower it shows a test pipe...would you need a test pipe if you are getting the catback exaust?
Old Jun 25, 2003 | 09:26 PM
pumpdog720's Avatar
Yes the cat back is for everything past the cat, so it does not change the cat, the test pipe changes the cat.
Old Jun 25, 2003 | 09:34 PM
Satrona's Avatar
okay, thanks again
Old Jun 25, 2003 | 10:54 PM
ghostrider's Avatar
Correct. The header removes the 1st cat and the test pipe removes the 2nd cat. Lots of gain, but super high pitched exhaust note.
