2008 Lancer Battery Drain
Old Aug 5, 2022 | 03:28 PM
davidoliveira's Avatar
I am having problems with my car battery. There is a parasitic drain on the car battery. When I take out Fuse #30 (30A Fuse) for the IOD the drain stops. Does anyone have any suggestions on what to look for next in order to find the source of the drain.
Thank you,
Old Aug 5, 2022 | 04:10 PM
@davidoliveira
My brother in-law has a 2011 Lancer & had the battery drain issue. It was the Blue Tooth component
Heres a thread where an 09, like yours, was doing the same thing
https://www.evolutionm.net/forums/la...ery-drain.html
Old Aug 9, 2022 | 06:04 AM
Isaque's Avatar
Yes I chased the same issues. Changed Alternator, battery and I'd come back from 2-3 day trip and car was completly dead. Removed bluetooth module and problem went away. It's under glove box. Tucked in behind the airbag. Mine was piping hot when I removed it.
Isaque.
Old Aug 28, 2022 | 06:27 AM
Good Morning,
I was able to remove the Blue Tooth module from behind the glove compartment and I believe that did the trick. I haven't had any issues with the battery drain for a couple of weeks since removing it. Thank you very much for the suggestion it was a huge help.
davidoliveira
Lancer Troubleshooting
Jul 23, 2022 09:47 AM
Ketchup287
Jun 9, 2020 12:00 PM
shanema88
Apr 22, 2016 08:27 AM
Evo2H8
Feb 10, 2015 02:35 PM
wickdaddy
Lancer Engine Tech
Aug 10, 2007 09:16 AM
