post all STRANGE NOISE complaints here
Old Apr 2, 2006 | 02:22 PM
  #76
ThunderOZ's Avatar
Originally Posted by 03ozwhip
i have a problem. the dealership says its rocks in the struts. when i turn, it sounds like my springs ae about to fall out and my wheels are going to fall off. just a huge clunking noise. anyone else hear about this. i know the guys i know from Lancernation have all had this same problem, but is it really rocks in the struts? let me know if you guys know about this.
The spring may have unsettled...mine did the exact same thing until I jacked both side of the car up off the ground and slowly put it back down...try it...
Old Aug 26, 2006 | 05:42 PM
  #77
drujitsu's Avatar
Hey guys. Even though this sticky isn't getting much love, I didn't want to s**t up the forums with another noise complaint thread (just trying not to be so n00bish). I'm getting some weird, slipping noises on my 03 ES when it goes to 1800-2000 rpms, and only in that range, unless I'm driving on the freeway (which I don't hear it, but most likely due to ambient noise and wind I would guess). It doesn't seem to hinder the performance much, but then I'm really new at cars so I don't exactly know.
Any help would be appreciated, so reply or rather PM me. Thanks guys.
Ninja edit: grammar
Old Aug 26, 2006 | 06:42 PM
  #78
DjDoubt's Avatar
I have this whistle or whinny sound coming from the engin bay, sounds like a vac hose lose but I can't find it, it only happens at high RPMS, I call it my N/A Blow off lol. Any know what this is and how to fix it? alos I juse hit 80,000 mile
Old Apr 9, 2007 | 07:40 PM
  #79
Shadow316's Avatar
I wanna say there is a groaning sound coming from the engine going around 45, well actually pretty much any speed for that matter. It has recently started to really get on my nerves, and it started doing it awhile back. Any ideas?
Old Apr 10, 2007 | 11:05 PM
  #80
Mr Lancer's Avatar
Strange Noice
I'm keeping hearing noice like "grinding" when i stop (just start acting now) and the blake viblate. and the other noice is when i'm driving i hear something is rubing the brake, like when Rotor is still lock onto the Pad. Would someone please tell me how to fix those noice please. ALso my Cigerate Adaptor isn't working it just doesn't heat it. someone help please.. thx.
Old Apr 17, 2007 | 05:13 PM
  #81
Mirage2.0's Avatar
I just put in the cam in my car last weekend. It sounds like my lifters knock like crazy accross the head. I opened the valve cover twice and tried to re-torque everything down. No good. Knocks even when warmed up.
What should I do??? Help.
Old Apr 18, 2007 | 09:46 AM
  #82
DSMFRK's Avatar
i got one for u guys. i have an evo 8 and every time i down shift it makes a noise like if u had a rock stuck in ur breaks. its not a high pitch noise is more like a honk. mitsu says its the clutch glazed over.it happens when i use the tranny to slow the car down comming up to a light or stop sign.
Old Apr 18, 2007 | 11:41 PM
  #83
KFizzle's Avatar
Lightbulb TimingBeltNoise
MY TIMING BELT IS MAKING A WOO WOO NOISE AFTER THE CAR WARMS UP I AM GOING UP TO MITSU I JUST THOUGHT I WOULD SEE WHAT YALL THOUGHT ABOUT IT THANK-YOU
Old Apr 18, 2007 | 11:56 PM
  #84
KFizzle's Avatar
HEY BRO SOUNDS LIKE YOUR CALAPERS ARE BAD YOUR BEST BET WILL BE TO TURN THE ROTERS GET NEW PADS+CALAPERS ON THE FRONT YOUR BACK BRAKES WILL MOST LIKELY JUST NEED PADS IF YOU KNOW SOMEBODY THAT CAN DO BRAKES THAT IS GOOD BUT MIDAS DOES GOOD WORK WHERE I LIVE ANYWAY IF YOU DRIVE YOUR LANCER LIKE I DO THAN YOUR BRAKES ARE MOST IMPORTANT!!!!!! WELL THATS JUST MY OPINION HOPEFULLY IT ISNT THAT BAD??? WELL PEACE-OUT
Old Jun 15, 2007 | 08:43 PM
  #85
bradw3488's Avatar
Ok here is my RATTLE... its coming from the passenger side under the hood and just started tonight. I should add that I also bottomed out today and bent the front ride bolts back... everyhing seems to be intact though.
When driving somewhat hard, there is a very distinct rattle/clicking noise coming from the passenger side under the hood....more so under hard left turns... any idea??
Old Jul 6, 2007 | 02:50 PM
  #86
OzRallyX's Avatar
Pretty much i just got back from Promotion Tuning where they put my RRM motor mounts on and some brake lines and new cat which was done perfectly but since the second i left there the entire car rumbles for the most part when i have it idle or using first gear. I had them look at it again and they said its the motor mounts doing their job but it seems like its doing to much. When I messed with the throttle it seemed like it could be the clutch or tranny having an affect on the car because looking at the engine it really doesn't move, only when using the pedals does it shake. Another note was that beforehand i had clutch chatter whenever the clutch wasn't engaged which i thought would be stopped with the mounts but it seemed to have made it worse. I really just wanted to see if anyone had any input for what i should do in my situation?
Old May 4, 2008 | 03:03 PM
  #87
caedar's Avatar
Whenever I'm not turning the wheel, there's a faint "eeeeee" squealing sound at a consistent volume. When I start to turn the wheel, the second that I turn it about 1 degree in either direction it stops until my wheel is straight again. Any ideas?
Old May 30, 2008 | 10:03 PM
  #88
BrandonShaw's Avatar
Alright... I finally got a noise... went a whole year without hearing a thing and it finally happened
There's this noise coming from the engine bay... it's like a tapping sound and it variates with the the rpm's. Low rpm's it's slower... high rpm's it goes a lot faster... any ideas??? I think it might have something to do with the belts... but i'm not sure...
Old May 30, 2008 | 10:06 PM
  #89
Maybe the tires rub a little when they're straight and when you turn it fixes it... what size tire/wheels are you running?
Or do you have lowering springs or any aftermarket suspension?
Old Jun 9, 2008 | 09:50 AM
  #90
fvshaggy's Avatar
Originally Posted by citru5cyrus
that clicking noise is still coming out of my front end. Happens once in a while, i'm thinking it's the fan ..whenever the car is in gear and hits about 3000RPM, you here this clicking noise as if soemthing is being whipped against something...on every gear...and when teh car is in neutral or when i have teh clutch applied and step on the gas past 3000RPM, there's no noise.. anyone else have this issue? It's been there for quite a while..i'm thinking its' ither the wheel/tires...or a fan is hitting something... and again, dealership won't do anything about it..which pisses me off..
Got the same thing too recently. Anybody have any ideas. Checked the whole thread nobody has an answer or even a response.
