Focus RS
Old Jun 24, 2016 | 03:34 PM
  #3796
RazorLab's Avatar
Going to post this again since most of you didn't see it because you where stroking e-*****.
Originally Posted by razorlab
I have some logs of the USDM Focus RS and what is happening is throttle closure, so my thoughts where correct.
It's not overboost not working, it's the other ECU fail safes coming into play. I think perhaps Ford made the first ROM rev a little too conservative for North American fuel.
Tuning will of course help, a new ROM rev from Ford is also probably inevitable.
Mitsubishi did the same thing with the Evo 10 when it first came out.
Here is a 4th gear pull showing throttle closure:
http://datazap.me/u/razorlab/fors?lo...lo=3-5-8-11-14
Old Jun 24, 2016 | 03:37 PM
  #3797
RazorLab's Avatar
damn from a modding standpoint, that seems like a pretty huge disadvantage for direct injection.
Yup it's kind of a pain. The VW's have the same setup but have upgraded HPFPs available. The Ford HPFP is a bit more complicated and nobody has created an upgrade yet.
The Fiesta ST HPFP maxes out at about 280whp on E8X. 280whp in a 2700lb car is still pretty awesome though.
On the stock turbo, I didn't make anymore power after a E45 blend so there was no reason to go higher. The stock Fiesta turbo is very small.
  #3798
ambystom01's Avatar
I'm excited to see what's nemsin's argument will be when this is explained and addressed.
"But the Evo didn't have these problems after 10+ years of tuners working out all the kinks! How dare a completely new car not be perfect and fully understood right away."
Old Jun 24, 2016 | 03:39 PM
  #3799
RazorLab's Avatar
Like I mentioned, the Evo 10 had a crappy first couple ROM revs that ran rich enough to have the car choke on it's own fuel. Mitsubishis newer ROM revs made a good amount more power.
Old Jun 24, 2016 | 03:45 PM
  #3800
Biggiesacks's Avatar
its all about that p/w ratio. Im sure with the RS hitting the market and demand there will be options in the future. I suppose if your already blending the fuel yourself, you can start off with pretty decent gasoline vs the crap they probably throw into the typical E85 blend.
Old Jun 24, 2016 | 03:46 PM
  #3801
nemsin's Avatar
Whether its the overboost not working, or the ECU fail safes coming into play, the end result is the same (i.e., not 350hp). If Ford fixes this with an ecu reflash great, until then enjoy your 250whp RS.
Old Jun 24, 2016 | 03:48 PM
  #3802
maybe to just end the back and forth, is it fair to say that based on what ford is advertising, the current examples of the Focus RS are under performing?
Old Jun 24, 2016 | 03:49 PM
  #3803
RazorLab's Avatar
Just get out of here and stop being such a *****. The adults are trying to have an actual multi viewpoint conversation.
Old Jun 24, 2016 | 03:52 PM
  #3804
RazorLab's Avatar
I blend in the tank using simple math. With the correct tuning strategy, the Ford ECU is almost flex fuel capable so you don't have to be totally accurate in your blending. The ECU is very sophisticated and very fast to react to hit target AFR since it runs a wideband stock and Target-AFR fueling strategies and a crap ton of compensation tables that if you tune correctly, make the ECU VERY flexible. It also has a very sophisticated reactive ignition timing strategy with 20+ timing tables.
I've said this before but the MED ECU makes the mitsubishi ECU (even the 10) look like a Abacus.
Old Jun 24, 2016 | 03:59 PM
  #3805
Sounds pretty awsome, i haven't messed around with the blue oval stuff in a while. My Fox body has been in pieces for the better part of a decade. Ill have to start looking into what those guys are upto. Do they have an equivalent to openecu for their stuff?
  #3806
Noize's Avatar
EvoM Administrator
If all goes well, I'm weighing one tomorrow.
Old Jun 24, 2016 | 04:02 PM
  #3807
Noize's Avatar
EvoM Administrator
Well I concur the stock fluctuating power is frustrating, but it would not bother me in the least. There is no way in crap I would have a car like that and keep it stock. Does anybody in this thread have a stock car? No. This is the dumbest thing in the world to argue about. Once tuned, it will be really good!
Old Jun 24, 2016 | 04:04 PM
  #3808
RazorLab's Avatar
I use a Cobb Accessport with Race Tuner. It was about a $650 investment.
Cobb must have a relationship with Ford because it's VERY well defined and some of the tables have names that nobody but the actual engineers at Ford would have named that way.
BTW, Cobb has an RS now so it's only a matter of time...
Here is a log from my Fiesta ST a long time ago, showing the reactive ignition and fueling strategy, if you are interested:
http://datazap.me/u/razorlab/fiesta-...12&zoom=92-204
Old Jun 24, 2016 | 04:11 PM
  #3809
ambystom01's Avatar
Both of my cars are stock but only because I don't want to risk warranty on a C63.
Old Jun 24, 2016 | 04:12 PM
  #3810
ambystom01's Avatar
Keep the dense comments going.
