Focus RS
Old Jun 24, 2016 | 03:01 PM
  #3781
nemsin's Avatar
Originally Posted by ambystom01
...so you are this dense. Where is the baseline indicating what 250 whp means on that specific dyno?
I do not understand the question. Different stock RS's on different dynos are putting up the same results (i.e., ~250whp).
I am sure you could contact Kaizen and Mishimoto and ask them to prove their dyno's are accurate
Old Jun 24, 2016 | 03:03 PM
  #3782
ambystom01's Avatar
Originally Posted by nemsin
There is a lot of chaff in this thread so I will repost this for you.
2016 Ford Focus RS vs. 2015 Subaru WRX STI
0–30 MPH 1.5 sec vs. 1.4 sec
0–60 MPH 4.6 sec vs. 4.7 sec
0–100 MPH 12.2 sec vs. 12.0 sec
0–110 MPH 14.4 sec vs. 16.0 sec
¼-MILE @ MPH13.4 sec @ 105 vs. 13.4 sec @ 104
http://www.caranddriver.com/comparis...e-specs-page-5
Almost identical results. Which makes sense with both car's dynoing at ~250whp. stock. One would expect better results from the RS if the claimed 50hp. advantage of the RS was a reality.
Look at the 0-110 MPH. That is pretty telling. The RS gets there 1.6 seconds faster. That's a pretty clear sign that it's making more HP than the STI.
Here are some other numbers:
2015 Evo X MR
Zero to 60 mph: 4.9 sec
Zero to 100 mph: 14.0 sec
Zero to 130 mph: 32.2 sec
Standing ¼-mile: 13.7 sec @ 99 mph
http://www.caranddriver.com/reviews/...mr-test-review
So the Focus RS is faster than the Evo X MR in all categories. It's substantially faster in the higher speed runs.
Old Jun 24, 2016 | 03:05 PM
  #3783
ambystom01's Avatar
Confirmed, dense. Not all dynos are created equal.
It's not an accuracy problem, it's a measurement problem.
Old Jun 24, 2016 | 03:07 PM
  #3784
nemsin's Avatar
It likely has to do with the gearing. But if you really think that waiting until 100+ miles per hour to see any advantage of a 50hp. difference makes sense, then I give up.
  #3785
Biggiesacks's Avatar
2015 Evo X MR
While i didnt do the math or anything, the RS does seem to have the tallest 4th gear. It could be that it manages the speed without an additional shift. Because 1.6 seconds is pretty huge, and even the hp advantage it has on paper doesn't really justify that big of a difference.
Old Jun 24, 2016 | 03:09 PM
  #3786
nemsin's Avatar
If the results were from a single dyno I might agree. But when multiple dynos give the same result...
So you think Kaizen's and Mishimoto's awd dynos do not correctly measure whp? Really?
Furthermore, the same dyno also measured a 2015 STI at 250whp. So even if 250whp really means something else, why would both the STI and RS have the same results? The RS should be higher right?
Old Jun 24, 2016 | 03:14 PM
  #3787
dyno's are just tools, they can only focus on a certain element of the total picture. On top of that peak HP numbers are also just a small piece of the picture. 1/4 mile times are real, and they are much better report card on how well a car is performing.
Old Jun 24, 2016 | 03:15 PM
  #3788
ambystom01's Avatar
The RS is faster almost across the board, but a 50 HP isn't going to become massive until the speed gets up there. Really, what do you want here? The RS to be 2 seconds faster to 60 mph than a car with 40 less HP?
Old Jun 24, 2016 | 03:16 PM
  #3789
ambystom01's Avatar
Again, it's not about accuracy. A dyno is a tool.
I already addressed the STI comparison.
Old Jun 24, 2016 | 03:18 PM
  #3790
nemsin's Avatar
What are you talking about? How do you see "faster across the board"?
The STI is quicker 0-30, quicker 0-100, and identical in the 1/4 mile.
Old Jun 24, 2016 | 03:22 PM
  #3791
if the car and driver numbers are to be accepted as credible. Both the RS and STI weigh basically the same, so for the focus to claim to have 45hp and 60 ft-lb more power doesn't make sense based on the 1/4 mile times. Unless some other factor can be identified to explain this, then the reported power numbers seem pretty suspect.
Old Jun 24, 2016 | 03:26 PM
  #3792
nemsin's Avatar
C&D is about as credible as it gets for independent testing. Not only are Ford's numbers suspect, but there are now multiple stock RS dynocharts, from multiple tuners, showing the stock RS putting down 250whp. because the "overboost" feature is not working consistently. I am not sure what more some of you need to see to break free of Ford's marketing grip.
Old Jun 24, 2016 | 03:31 PM
  #3793
RazorLab's Avatar
I wonder why there doesn't seem to be any mfg in this platform that has the ***** to do a flexfuel setup. Now that would be something.
The Ecoboosts use direct injection so they are limited by the cam driven high pressure fuel pump. You have to get crazy and add things like additional injectors and such to go true E85. There is a setup available for the Focus ST but it has some drawbacks.
Most owners do a E30-E45 mix, like I do in my Fiesta ST.
Old Jun 24, 2016 | 03:33 PM
  #3794
damn from a modding standpoint, that seems like a pretty huge disadvantage for direct injection.
  #3795
ambystom01's Avatar
Your link is dead.
I noticed that you intentionally left out the results that favor the RS:
RS STI
ROLLING START, 5–60 MPH 5.7 sec 6.7 sec
TOP GEAR, 30–50 MPH 7.6 sec 10.8 sec
TOP GEAR, 50–70 MPH 6.0 sec 7.8 sec
So from a rolling start, the RS wins by a full second. In a top gear pull, it's 3 seconds. Huh, why would someone who hates the RS want to leave out the full results?
http://www.caranddriver.com/comparis...omparison-test
The RS was also ranked first in the comparison but that's none of my business.
Bolded for posterity. Car and Driver ranked the RS first, ahead of the STI and the Golf R.
