Focus RS
Old Apr 12, 2016 | 11:17 AM
  #3046
bboypuertoroc's Avatar
Veteran: Army
Originally Posted by ambystom01
So what was C&D's car?
You mean the one that weighed in at 3459lbs?
As in under 3500lbs?
As in less than an Evo X?
(I see where you went with your post)
Old Apr 12, 2016 | 11:23 AM
  #3047
Veteran: Army
Originally Posted by nemsin
No USDM Focus RS weights are available. But there ARE 3500+ lb. weights posted for Euro versions. You are smoking crack if you think the US model is going to be lighter despite having heavier seats and a spare tire.
We don't really know. But the test was done at Ford's test track in Belgium and the car had euro plates.
Originally Posted by Car and Driver
DIMENSIONS:
Wheelbase: 104.3 in
Length: 172.8 in
Width: 71.8 in Height: 58.0 in
Passenger volume: 91 cu ft
Cargo volume: 20 cu ft
Curb weight: 3459 lb
Old Apr 12, 2016 | 11:28 AM
  #3048
nemsin's Avatar
I mean we don't know if the car C&D tested was pre or post production, euro or USDM spec, or what. http://www.caranddriver.com/ford/focus-rs
Here are 2 other sites that list it as 3525 lbs.
http://www.carmagazine.co.uk/car-rev...s-2016-review/
http://autoweek.com/article/drive-re...-ford-focus-rs
Time will tell.
Old Apr 12, 2016 | 11:43 AM
  #3049
Noize's Avatar
EvoM Administrator
I can't believe the bloodbath over 65 lbs. RS weight variance.
Old Apr 12, 2016 | 11:48 AM
  #3050
nemsin's Avatar
I think trying to source out the actual curb weight is worthwhile. Even though I personally consider both 3459 and 3525 as heavy.
Old Apr 12, 2016 | 11:51 AM
  #3051
Noize's Avatar
EvoM Administrator
200 lbs heavier than a CT9A. Not so much.
Old Apr 12, 2016 | 12:32 PM
  #3052
LetsGetThisDone's Avatar
Originally Posted by Noize
200 lbs heavier than a CT9A. Not so much, and wont kill you if you slide the car driver door first into a pole.
Fixed.
Old Apr 12, 2016 | 12:45 PM
  #3053
nemsin's Avatar
And 700 lbs. more than a Ford Escort RS Cosworth. http://www.hoonable.com/cosworth/
Old Apr 12, 2016 | 12:47 PM
  #3054
Veteran: Army
Brilliant use of the weight of a car from the mid-90s.
Old Apr 12, 2016 | 12:51 PM
  #3055
moparfan's Avatar
Well with the Focus RS turning into almost a 2017 car what else to talk about? The Evo x is fat and so is the Focus RS. Fat is easy for manufacturers to do. Power is plentiful and modern tires and suspensions can deal with the flab.
As to arguing over a car we won't buy, with availability and the lifespan of the body, most won't own this anytime soon.
Old Apr 12, 2016 | 01:11 PM
  #3056
nemsin's Avatar
Well lots of articles are saying this is the best RS ever. I am not so sure.
Old Apr 12, 2016 | 01:46 PM
  #3057
Veteran: Army
Depends on what your definition of "best" is.
Old Apr 12, 2016 | 02:00 PM
  #3058
ambystom01's Avatar
No kidding.
Old Apr 12, 2016 | 05:26 PM
  #3059
RazorLab's Avatar
I see this thread is still 100% crap.
Old Apr 12, 2016 | 05:57 PM
  #3060
Robevo RS's Avatar
then you forgot when the X came out lol
