Focus RS
Old Apr 9, 2015 | 06:22 PM
  #586
WarmMilk's Avatar
Originally Posted by razorlab
No, I stated with the nannies off, it will be like a Golf R with the nannies off, meaning, open diffs front and rear as both use brakes as pseudo LSD units.
According to that sheet I posted, the Focus RS "to optimise handling and stability, the car's brake-based Torque Vectoring Control is tuned to work in parallel with the torque vectoring AWD system" which probably means it helps torque vector the front in conjunction with the rear drive unit mechanically doing it, which I personally think is pretty awesome, if true. However, the sheet I posted talks about the rear of the car overall, so front is probably just the brake based pseudo LSD.
At least that is the way I understand it with the *very* limited information we currently have.
I'm fine with having a discussion over the system but really not interested in arguing over it.
now I'm confused, first you said it'll be like the Golf R with all nannies off, open diff front and rear.
then in the next paragraph you say its brake biased controlled front and mechanical diff controlled rear. so all nannies off would mean open front and mechanical TV rear. (which is how I understand it)
or are those meant to be separate statements about the Gold R and the RS?
I'm also in discussion mode, not trying to just argue for the sake of arguing if it sounds like that
PS.
Does the new Golf R allow you to fully defeat nannies? I remember watching reviews about the previous gen and they were complaining about the nannies crippling on track performance...
Old Apr 9, 2015 | 07:01 PM
  #587
RazorLab's Avatar
PS.
Yes, open diff front and rear, aka no mechanical LSD. You might be confusing torque vectoring and LSD? Also perhaps the way Ford wrote about it is confusing it as well.
On a simplified level, I personally view torque vectoring as using a yaw input (and other inputs) to aid in rotation in a corner. I see LSD as a aid in forward moving traction.
Yes, the MK7 Golf R you can turn nannies fully off, from showroom floor in the USA. The MK6 Golf R you could not from the showroom floor, but the fix was a very easy ecu bit flip away (no need to even flash the ECU). It was the first thing I did on my MK6 Golf R.
Old Apr 9, 2015 | 07:24 PM
  #588
WarmMilk's Avatar
I disagree in my interpretation of fords material. I understand it is its a brake system for the front, and the rear uses the hydronic diff to send power where it needs to, not using the brakes
lsd's control where the power is sent, typically its a mechanical system so you can't control where the power is being sent intelligently. In the RS case it's and intelligent system with hydrolics and clutches and stuff that can send power where and when it needs.
These guys understand it the same as me
http://oppositelock.jalopnik.com/her...rks-1683508180
Old Apr 9, 2015 | 07:38 PM
  #589
RazorLab's Avatar
I think we are saying the same thing again, in different ways. Sounds good to me!
Old Apr 10, 2015 | 06:01 AM
  #590
rongdoer's Avatar
I don't understand the effort to avoid using a regular old lsd.
Old Apr 10, 2015 | 07:08 AM
  #591
nemsin's Avatar
The Ford info sheet clearly states "To optimize handling and stability, the car’s brake-based Torque Vectoring Control is tuned to work in parallel with the torque vectoring AWD system."
I have not read anywhere that "either" system will be able to be turned off.
Old Apr 10, 2015 | 09:16 AM
  #592
WestSideBilly's Avatar
El Jefe
Cost, weight, packaging... all possibilities. Guessing the first one is a principal driver.
And you can't really adjust power dynamically (which Ford is using to offset the understeer bias of the FWD platform) with LSDs. You just get traction to whatever wheels have it. Which is a good start, but still limits what you can do with the system.
Old Apr 10, 2015 | 09:35 AM
  #593
nemsin's Avatar
I suspect Quaife will be offering an ATB diff for the Focus RS when it releases
http://quaife.co.uk/quaife-atb-diffe...esta-focus-st/
Old Apr 17, 2015 | 12:02 AM
  #594
mrfred's Avatar
so no news about actual hp and no test drives?
Old Apr 17, 2015 | 07:23 AM
  #595
RazorLab's Avatar
The car isn't in production yet.
As far as HP numbers, I think they might be waiting for the RS3 launch before stating them.
Old Apr 17, 2015 | 07:47 AM
  #596
nemsin's Avatar
I will be interesting to see how the Focus RS Nurburgring lap times compare with that of the new Civic Type R (assuming the Civic can repeat its staggering 7:50 with a production car).
Some may say that Nurburgring times don't matter, but I think its a great way to see how cars compare in a closed loop/track environment. With awd, more hp, and super sticky pilot sport cup tires, Ford really has no excuse if they get trounced by the Civic.
Old Apr 17, 2015 | 10:01 AM
  #597
OX's Avatar
OX
Typically you can almost buy the car before you get official HP numbers or actual curb weights with fords these days.
Would not matter much to me at all, almost no one tracks a bone stock car, so what does it really mean (stupid bragging rights).
On the flip, same reason I got my talon and then the EVO. On the street, every day, it hooks up. Little mist or patch of sand on the ground that trips up FWD's and muscle cars, doesn't mean a thing with AWD.
Old Apr 17, 2015 | 10:36 AM
  #598
nemsin's Avatar
Actually, tons of people race stock or lightly modified cars these days. It makes it more about driver skill than the size of your bank account. http://www.scca.com/clubracing/content.cfm?cid=44726
So how a car performs in stock trim is supremely relevant. Nearly any car can be made fast if you dump tons of cash into it.
Old Apr 17, 2015 | 04:16 PM
  #599
OX's Avatar
OX
Which one of the classes is for bone stock, NO changes whatsoever??
Old Apr 17, 2015 | 04:24 PM
  #600
RazorLab's Avatar
hhaha. Match point.
