SST Questions
i'm no sst/dsg/dct expert or anything like that but this sounds wrong. it'd be the case if you're talking about a true sequential manual like the ferrari f1 tranny but the SST is a dual clutch. gears 1,3,5 are on one shaft and 2,4,6, on another. so to go from 6 to 2 it DOESN'T have to go through every gear to get there. it simply has to go from 6 to 2. the problem however is that the next gear on the other shaft is preselected. if you slow down and then plant the throttle, the computer gets confused and it may need to deselect the next preselected gear for a situation that it didn't expect given the parameters that it monitors.
EDIT: i reread the original post that talks about the delay and this only happens in normal mode. that's because only in normal mode does the SST skip gears. in supersport and sport modes it will act like a true sequential and row thru all the gears. why? exactly for this reason, no delay in power.
if you're in 4th and start braking, it will preselect 3rd. step on the gas and depending on rpm it may either stay in gear or drop down to 3rd for a bit and then go back up to 4th. in normal mode, depending on how they programmed it, it may preselect a much lower gear like from 4th to 1st. when you step on the gas you really need 3rd so the tranny has to disengage 1st (the "wrong" preselected gear), engage 3rd (the "right" preselected gear cuz you all of a sudden pressed the gas again), disengage the clutch on shaft 2,4,6 and engage the clutch on shaft 1,3,5. all this for a simple downshift to the next lower gear? YES!!!
THIS IMO causes the delay in normal mode. the preselection of the next gear is all based on fuel economy and well... NORMAL driving. if you want uninterrupted power, use sport mode always.
for evidence look a this video where BM does 0-400m runs in all 3 modes.
http://youtube.com/watch?v=ZvSvN5ja884&feature=related
in s-sport and sport modes, even when the brake is fully depressed, the SST will row thru all the next lower gears to get to 1st. in normal mode, the gears go from 5th to 6th (an upshift on decel!!!) back to 5th then 2nd (totally skipping 4th and 3rd) then 1st.
This is a true sequential transmission, not act like, it is. It just has an option not to be. My motorcycle comparison was just to show that this tranny is comparable to one in the way it shifts, and to stress the point its not an automatic with a torque convertor. Where did you find that it skips gears in normal mode? I been reading everything that comes up about this car since the unvieled it at SEMA I never saw anything like that to date. Read this link below, I got more if anyone wants to see them.
http://en.wikipedia.org/wiki/Twin_Clutch_SST
Also read this page, you'll see it is like the one you use on a motorcycle or a race car. The differance in the ferrari tranny and this one is... The ferrari has one clutch and one tranny. In the SST what you really have is two 3 speed trannies and 2 clutches. You still can't skip a gear like you think. Each gear box will have to move down to the next gear in its selection. Now I'm not saying that the computer can't or want not go from 6th a differant gear than 5th, I'm saying each tranny must move to the next gear in its order. If this doesn't make sense tell me.
Anyway read this too:
http://en.wikipedia.org/wiki/Sequential_manual_gearbox
please view the link i posted and watch the 0-400m run in normal mode. at the end when they brake you can CLEARLY see the SST skip gears. don't listen to me, listen to what your eyes see. ooh that rhymed
i have a question on SST operation. if you have the console shifter in manual mode and then use the paddles to go into automatic mode, what happens when you come to a full stop? does it stay in auto mode or revert to manual mode?
i'm guessing when you come to a full stop the system resets itself and goes back to whatever mode the console shifter is in.
Ridge Racer you are flat wrong man. There is a scematic for the SST running around somewhere. The SST is not a stacked design like a motorcycle tranny, you DO NOT have to go through all of the gears when going from 6-2 or vice versa. And a sequential tranny like in a motorcycle and a Ferrari or BMW are not secissarily sequential in the same way a motorcycle is to, some SMG's are automated manuals, not true sequential tranny's. And don't believe everything that you read on Wikepedia...
To Answer Madfast's question. Yes it reverts to what ever mode the console shifter is in. A bit handy as what I find I do is use the paddles to go into manual mode drive for a while at highway speeds forget it in in manual mode stop at an intersection then carry on. Mean while the gearbox has automatically down shifted and then gone in to auto mode and the driver (Me) carries on blissfully unaware.
People seem to be getting side tracked with this SST pause. Just remember that normal mode is designed to down shift as late as possible and up shift as early as possible and to deliver a great lo stress drive, witch it does. If I think I may need to leave an intersection in a hurry then just flick it to sport mode as you brake. Problem solved.
I have own my SST for 3 months and just passed 10,000 Km. I drive it about 60 % open rd and 40 around town. The longer I own the car the more I find myself leaving it in normal mode and only occasionally sport as far as the auto manual modes go more and more I leave it in auto. Hope this help :-)
Probable a repost but I thought any one interested or who owns an SST should know About the launch control.
From what I understand, at a dead standstill, you turn off ASC, then change to Super Sport mode, stand on the brake pedal, rev to 5,200 RPM and then let off the gas when you want to take off! I have an Evo X MR on order, can't wait! Let me know if I missed a step
. Note to turn AST completely off you need to hold the switch down until the display changes. for results check this vid out.
http://youtube.com/watch?v=ESwwuUSwkMQ&feature=related
. Note to turn AST completely off you need to hold the switch down until the display changes. for results check this vid out.http://youtube.com/watch?v=ESwwuUSwkMQ&feature=related
it is NOT a true sequential. it can skip gears. motorcycles can NOT. the ferrari f1 sequential tranny can NOT.
no you are wrong. the engagement of both clutches and the engagement of gears is electronic. by virtue of having two shafts you can skip gears. for instance if i'm in sixth, i could have programmed the twin clutch to preselect 1st, 3rd, or 5th on the other shaft. i could even program it to skip the other shaft altogether and have the clutch disengage and select either 2nd or 4th and then re-engage the clutch. this of course would destroy the purpose of having 2 shafts/clutches and would be very slow.
I may be wrong, but so far nobody has shown me anything solid to prove me wrong. If I am wrong please show me something I can look at to prove it. I would like to see the scematic if you can find it thanks. By the way those were just 2 links I went and grabed, I didn't get all the info from wilkpedia. Everything I have read so far agrees with wilkpedia though, even car and driver agreed it was a sequential, not that they know anything though.
Reread what I wrote again, I never said it couldn't skip gears, I said each of the seperate 2 trannies can't skip gears, I don't think I am wrong. I think you still don't understand there are like 2 three speed trannies spliced together and that each one operates separatly.
i fully understand that the tranny acts as two 3-speed trannies. what you seem to not understand is that each 3-speed tranny is not a true sequential tranny. by true sequential i mean any tranny that cannot physically skip gears. in motorcycle engines and other auto sequentials, the tranny uses a ratchet type mechanism to turn an up/down motion into an H-pattern. now i dunno for sure if the ferrari f1 tranny can physically skip gears but i doubt that it still uses this ratchet system. it may be that ferrari just programs the tranny to not skip gears so as to be as "F1-like" as possible. if someone knows for sure, chime in. my guess is that it's not a true sequential as it can skip gears if programmed to, but they don't?
what i DO know is that DCT's use electro-hydraulic activated shift forks to switch gears. so depending on how you program the tranny, ANY gear can be engaged at ANY time on the other shaft. which gear to select of course would depend on the parameters set. if you're in 6th gear at 6000 rpm and you brake, you could program the SST to physically move the shift fork to engage 1st as the next lower gear, but that'd just destroy the engine. in a motorcycle tranny, you cannot physically get to 1st without engaging every gear in between. there's a big difference between "could but wouldn't" and "can't".
so what we have here is PROOF that the two 3-speed trannies that make up the DCT are NOT sequential trannies. they do NOT use any kinda ratchet system. they have electro-hydraulically actuated shift forks.
DSG proof:
http://www.youtube.com/watch?v=WVWP7TYhP0c
you CANNOT get anymore clear than this video above
SST proof:
http://www.carbuyersnotebook.com/TC-SST_01.gif
notice the "hydraulic unit" activates (green lines) EACH INDIVIDUAL shift fork (rectangle with X).
you asked "Where did you find that it skips gears in normal mode?". i posted the youtube video that proves that it does.
DSG proof:
SST proof:
DSG proof:
SST proof:
http://www.evoxenthusiast.com/sec-ev...ogy/tc-sst.htm
Check out the gas miliage comparing the 3 trannies in this link. That alone makes me swing even more towards the SST.
http://paultan.org/archives/2007/07/...h-sst-gearbox/
" think the SST gearbox are based on (if not sourced from) Getrag DCT as bigwigs at Mitsubishi denied that it’s a DSG or a DSG derived transmission. Plus the new getrag DCT are touted to be able to handle up to 750nm of torque which is pretty logical choice for Mitsu since we know that tuners will mess with this car engine barely 1 week after it’s release. You can read the research article at just-auto.com"
I hope this is true, quoted from page above, if it is we have no worries about upgradeing and can have a 500 horse SST ;].
