Comprehensive Evo STU prep thread?
Old Oct 1, 2007 | 12:06 PM
  #841
donour's Avatar
Originally Posted by Dave Mac
Here-here for the practice....
Do you have lighter seats or anything?
No. It's insane. I haven't done anything; stock seats, stock battery, pretty heavy wheels, stock rotors, full tank of gas, water in the IC sprayer, heavy SS exhaust, A/C. I even left the stereo and speakers in.
3076 lbs on thursday.
It's the dirty little secret of the '04 RS.
d
EDIT: I'm already set up to drop weight quickly. Obviously the fluids are free. I already have a set of very light SSR rims (15.3 lbs). I even had them at nationals, but chose not to run them. I was also running full tread 245/45/7 tires. shaved 40 series are definitely lighter. The battery is a very cheap 30 lbs. Then I could add a lighter exhaust manifold and 02 housing. My megan TBE is just about as heavy as the stocker, and lots of folks make lighter ones. Seats are pretty expensive. I wonder if it is legal to get a super light/plastic passenger seat, then ballast it up to 25 lbs with heavy rails...
Old Oct 1, 2007 | 01:01 PM
  #842
russjnco's Avatar
Hey Jon, what happened to the car?
As for some of the stuff I see proposed, the A/C removal is illegal. You'll save about 30 lbs. by going with bucket seats. 20 lbs. with the battery and a little bit with the 02 housing. You won't save anything if only a little bit with the manifold. Someone can correct me if I'm wrong but I believe the stereo and speakers must remain in the car unless that's classified under comfort and conv.
BTW, an Evo that weighs around 3000 lbs. is pretty good and about right in my estimation.
Last edited by russjnco; Oct 1, 2007 at 01:32 PM. Reason: corrected an issue regarding the legality of 2-piece rotors
Old Oct 1, 2007 | 01:27 PM
  #843
Dave Mac's Avatar
2 pc aren't illegal. They are still metal.
Old Oct 1, 2007 | 01:28 PM
  #844
Silencer's Avatar
Originally Posted by russjnco
As for some of the stuff I see proposed, 2-piece rotors are illegal, same with the A/C removal.
2-piece rotors are legal for STX/STU.
14.12.7
"Brake rotors may be replaced with any rotor of equal or larger
diameter made from a ferrous or aluminum alloy. Calipers are
unrestricted, but must mount to the original attachment points."
Rule does not restrict rotors to a single pc replacement. I also received a clarification e-mail response from Doug Gill back in 04'.
Dave
Old Oct 1, 2007 | 01:30 PM
  #845
russjnco's Avatar
I stand corrected then!
Old Oct 1, 2007 | 01:36 PM
  #846
stimpy's Avatar
As for some of the stuff I see proposed, 2-piece rotors are illegal, same with the A/C removal. You'll save about 30 lbs. by going with bucket seats. 20 lbs. with the battery and a little bit with the 02 housing. You won't save anything if only a little bit with the manifold. Someone can correct me if I'm wrong but I believe the stereo and speakers must remain in the car unless that's classified under comfort and conv.
The car had what we believed to be a faulty turbo preventing timing in the top-end. We replaced it and retuned it for Denver. The car was the fastest it had ever been. We put the car on the dyno last week to do some tuning for something else and the car pulls timing from 2500rpm to redline. Here is the link: https://www.evolutionm.net/forums/sh...d.php?t=298426 .
2004-2006 RS models had no radio and no speakers. The stock exhaust manifold was 15lbs and I think the O2 sensor housing was another 9lbs. They weren't what I would deem as heavy. My car weighed in at 3100lbs with coil-overs, two-piece rotors, 3/4 tank of gas, and Hankook RS-2s on MR wheels.
-Jon
Old Oct 1, 2007 | 01:58 PM
  #847
russjnco's Avatar
Curious though, SP does not allow 2-piece rotors but STX/STU does?
From the SP ruleset:
B. Cross-drilled and/or slotted brake rotors may be used, provided
the replacement rotors have the same dimensions as standard
rotors and are of a standard-type construction and of ferrous
metallic material. This does not permit the use of a two-piece
hat/rotor assembly unless the standard configuration is two-piece.
I guess that's where my original confusion came in, I thought ST rules were a step ladder to SP......
Old Oct 1, 2007 | 02:01 PM
  #848
Dave Mac's Avatar
Silly Russ......do you expect SCCA rules to make sense or use ANY sort of logic?
Old Oct 1, 2007 | 03:38 PM
  #849
donour's Avatar
Not in my RS is doesn't. It's completely aftermarket.
d
Old Oct 1, 2007 | 04:24 PM
  #850
kekek's Avatar
Exhaust mani will net 5 lbs weight loss. This is going from OEM w/heatshield to a Megan tubular mani. I tried it and to me it's not worth it for the loss of bottom end (seat of the pants feel, no actual dyno results).
Old Oct 1, 2007 | 06:27 PM
  #851
dannykao's Avatar
Mike sold the M3 a few months ago to a road racer in the Mid West. He has been helping me setting up the car and showing me how to autox. I hope he doesn't abandon me and go to the STI camp... Just kidding of course.
Originally Posted by evo8dad
Is Mike done with the Bimmer? He had that thing rocking for a few years when STU first appearred as a class.
Old Oct 1, 2007 | 06:34 PM
  #852
dannykao's Avatar
I am trying to lose 25 lbs for the next year... I know Neary, Davemac and I can easily do it. Not sure about Gil, definitley not Corey or Anthony.
Old Oct 1, 2007 | 08:13 PM
  #853
Dave Mac's Avatar
A hahahahahahahahaaa......shut up fatty.
Old Oct 2, 2007 | 06:50 AM
  #854
russjnco's Avatar
You're right, silly me, how quickly I forgot about strut bar and emissions clarifications
Old Oct 2, 2007 | 02:17 PM
  #855
DaWorstPlaya's Avatar
Well said!
