Comprehensive Evo STU prep thread?
Old Jan 19, 2007 | 07:21 AM
  #91
russjnco's Avatar
Originally Posted by ReSin
Out of curiousity, is anyone running a larger front anti-roll bar???
Dennis
I don't think so, or at least nobody that I know of. I've contemplated going to a smaller front sway bar but the labor involved to make that change is not something I'm willing to tackle at the moment.
Old Jan 19, 2007 | 04:07 PM
  #92
Dieman's Avatar
Originally Posted by DaWorstPlaya
Thanks for the correction. That is a lot for an STU *cough* EVO *cough*, are you sure you didn't mess with boost . I see your mom is going to run STU now how come not B-Stock this year?
The M3 juust isn't competitive in that class anymore really. Not to mention the fact she never really liked driving it. She always had more fun in my evo when she drove it around town. So she bought her own. She also has damn near an unlimited budget so she is putting all the stuff on her car I wish I could afford to do to mine. Everything from Carbon Fiber Intakes to a Titanium downpipe and cat-back. The car is going to be way better than the driver that's for sure. The worst part is I've already asked if Jerry and I can drive it this year and nats and I got a resounding "No, it's my car not yours. You have an evo!" oh well, back to my boring old car
Old Jan 20, 2007 | 09:14 AM
  #93
Ookami's Avatar
Let me guess along with a ceramic coated race header/o2 housing? Moton coilovers? and tuned for GT100??
Old Jan 20, 2007 | 09:35 AM
  #94
DaWorstPlaya's Avatar
Thats what you get for getting her hooked to Auto-x and letting her drive your EVO Ladies in the STUL class better watchout! ... Are you guys still going to be campaigning in STU this year?
Old Jan 21, 2007 | 08:18 AM
  #95
EVOlutionary's Avatar
Dennis
Don't know about in STU, but in other classes, yes there are folks with larger front bars. . .
I ran the stocker last year, but am going bigger this year to try to keep the inside rear on the ground. Had to replace the clutch, so I figured while the front subframe is out it's as good of time as any to put the new bar in. . .
I think whether upgrading the swaybar or not will improve the handling of your car depends alot on your specific suspension setup. Even if it makes one car faster, it may not on another car. . .
EVOlutionary
Old Jan 24, 2007 | 09:14 PM
  #96
Dave Mac's Avatar
Here's a bump guys. I've added some info into the beginning part of my thread to get a basic "what to consider" format. Feel free to critique me and correct anything that seems out of whack.
Old Jan 24, 2007 | 10:10 PM
  #97
Dieman's Avatar
She definatly has more car than driver. She just wants to be competitive I mean c'mon...she's 66 years old (DON'T TELL HER I TOLD YOU!!!). She's in it for the fun of the sport, you know, what we should all be in it for. She made a joke last year about being older than the entire class combined.
Jerry convinced me to spend one more year in STU as much as I wanted to move up. Let me re-phrase that... Jerry TOLD me I was spending one more year in STU.
Mom's car build is pretty much full tilt unlike my car. It'll be interesting to see how it compares really. It's nice having two evos to test product out on though. Hoping by June to have a common set-up on the two cars with just some tweaking on the two to make them fit the drivers. Jerry and I have the same taste in how we want the car to feel which is good. The biggest differences in her car and mine is the suspension. I'm sticking with Steve's stuff (ZZYZX Motorsports) and we are changing the spring rates from last year and adding a sway bar to the front. Mom's car has a sway in the front and rear for now and is running the HKS Hipermax Pro's. The Pro's are a made to order coil-over only. The car spent three weeks at HKS USA getting corner balanced and set-up specifically to her specs. It was interesting to see what they came up with for her in terms of ride height and spring rates. It was nice because it's very similar to what we are doing to my car set-up wise this year too so I feel like we are on the right track if we agree with HKS. Her's though as less camber and a lower spring rate in the rear but identical spring rates in the front. Ride hieghts were slightly lower on the HKS car as well.
Old Jan 25, 2007 | 05:00 PM
  #98
Silencer's Avatar
A Toledo (Ohio) Pro Solo has now been added to the list. Registration is open.
Dave
Old Jan 25, 2007 | 05:54 PM
  #99
Slowride's Avatar
Have you guys seen this:
DG's Autocross Setup Secrets
The author, Dennis Grant, is EvoM user FarNorthRacing. Interesting stuff...
I'm installing Robispec KWs this weekend. Robi says if use his ride height specs, the cross-corner weights will be very close--the only variable is driver weight. So I was going to skip the corner weighting. Then I read:
Corner Weight Calculator
And he makes the case for equalizing front and rear left/right ratios. I.e., rather than equalizing the sum of opposing corners, you look at ratios of the weights of the front and rear corners and equalize them. E.g., if the 52% of the total rear weight is on the left rear corner, then 52% of the total front weight should be on the left front corner.
Anyone think it'd be worth $150 to try that out?
Old Jan 26, 2007 | 07:59 AM
  #100
CoreyR's Avatar
Interesting logic... but where is the $150 coming from?
Corey #89 STU
Old Jan 26, 2007 | 08:03 AM
  #101
Slowride's Avatar
That's what I'd have to pay for corner weighting.
Old Jan 26, 2007 | 09:41 AM
  #102
CoreyR's Avatar
Gotcha.
Old Jan 26, 2007 | 02:41 PM
  #103
Slowride's Avatar
Here's a little tidbit on what our STi brethren are up to. This is a national-level competitor, '04 STi with ZZYZX, header, TBE, AccessPort, shaved Neovas:
...went to Atlanta to TopSpeed. I would highly recommend Doug Wilks. He did a great job and is a nice guy. Can't wait to autox it now. Depending on which gas it has about 312 torque with 100, and 300 with 93.
Old Jan 26, 2007 | 02:50 PM
  #104
SS RX7 r2's Avatar
Power's not that important...got the link to that thread?
Old Jan 26, 2007 | 05:04 PM
  #105
Slowride's Avatar
So why is it that STi's have been dominating at Nationals? Just more of them running, so more of them are well-prepped? Better drivers?
I checked the entry list for the Dixie event--all eight cars entered are STis.
