EVO Aerodynamics Review
Old Jan 21, 2015 | 06:00 PM
  #451
kaj's Avatar
kaj
Originally Posted by bee-raddd
What id really love to figure out is what size and angle etc equates to what.
Eg is there a certain angle that they should point relative to the size of your wing ect.
same here. i see people adding canards to their cars and always wonder how they know what size, where to put them, angle, spacing, etc.
i also see lots of different sizes. some even have end plates, which makes sense to me.
i honestly wouldn't even know where to put them without putting my car in a wind tunnel LOL
Old Jan 22, 2015 | 11:01 AM
  #452
woodchuck's Avatar
I agree with everything said above.
Am I supposed to install those APR front bumper canards towhere they look symmetrical on both sides and know that in theory that they aredirecting airflow to my GT wing?
That’s essentially what people do, but some take it a stepfurther and take aero cues from what’s proven to work (like voltex front aero).Since wind tunnels are not something that’s available to the average track guy,you end up testing these aero parts on the track to see if they shave laptimes.It may not be the most efficient way to test aerodynamics but one can decide ifit helps or not.
This is exactly what the OP of this thread did, and I’m surehe’s not the only that does it.
Old Jan 22, 2015 | 12:25 PM
  #453
killerpenguin21's Avatar
Well the apr canards are junk to begin with anyway so
Old Jan 29, 2015 | 07:25 PM
  #454
XcreatonX's Avatar
Has anyone used High Density Polyethylene for splitter material? I was thinking about using alumalite but this may be a cheaper item to experiment with and figure out the design I'm going with.
Old Jan 29, 2015 | 08:01 PM
  #455
honda-guy's Avatar
^ use plywood to experiment with. some even use them to make functional splitters
Old Jan 29, 2015 | 08:09 PM
  #456
Make your own canards just like Clive did (The Master EvO Builder)
Heres the link to his canard build page
http://www.lancerregister.com/showth...268523&page=39
IMO, one of the best EVO modification fabricators around. Build thread in my sig
Old Jan 29, 2015 | 09:01 PM
  #457
kaj's Avatar
kaj
i'm building a plywood splitter as soon as i find a better wing. they seem to last a season or more.
Old Jan 30, 2015 | 05:27 AM
  #458
honda-guy's Avatar
i bought a Special Projects front splitter for a crx and it's made from some type of high density particle board but seems very light and stiff. i'm trying to find out what the material is called so i can get some for the evo. it's about 1/2" thick.
Old Jan 30, 2015 | 09:49 AM
  #459
kaj's Avatar
kaj
That sounds familiar. I think I've read about something like that a while back, but I'm drawing a blank right now.
Old Jan 30, 2015 | 11:04 AM
  #460
Bee-Raddd's Avatar
I made my front splitter out of MDF then a layer of fibreglass to keep it weathertight. have had it on there for over 2 years now. takes a beating but is still mint.
scroll up to find my photos earlier showing mountings etc.
As for canards i have made my own. on my second set now. problem is dont have a clue how effective they really are haha. i havnt been on the track since i made my voltex lookalike ones so that will be interesting to see if i notice much difference. problem is ive also slapped a wing on it at the same time.
May have to pull the canards off and do some laps then put them on n see if theres much difference.
Have any of you played around with your rear guards etc to fit nice wide tyres under them? like more than just ur regular rolling. and anything but putting the voltex rear overfenders on. cant stand those.
My guards r rolled pretty tight and slightly pulled but ive just put new wheels and slicks on it and not sure if im going to get much rub. ive done the classic jump up and down on the back of the car test and they dont touch haha.
Old wheels were 18 x 9.5 + 15s with 245 40 r18 nt05 semi slicks. new wheels r 18 x 9.5 +12 with 240/64r18 michelin porsche cup N1 slicks.
Thinking may have to do some work to the rear guards with regards to clearance at high loads thru corners.
Id love the APR rear fenders but when i emailed APR they refused to sell me just the fenders as they fear they will be copied by the chinese which is a shame
Old Jan 30, 2015 | 11:46 AM
  #461
kaj's Avatar
kaj
Do they run really wide or is that a typo?
Old Jan 30, 2015 | 11:59 AM
  #462
heel2toe's Avatar
Yeah they are most certainly wiiiide. However that offset isnt helping the case...
Old Jan 30, 2015 | 03:19 PM
  #463
boostincincy's Avatar
I'm excited to experiment this year with designing a Splitter, however it seems to be concluded that if you build a splitter, you better add more DF to the rear of the car as well, or else you're hurting more than you're helping (I know that's not 100% true, just a 'for the most part' situation)
Old Jan 30, 2015 | 04:57 PM
  #464
And while we're on the topic of splitters, does anyone here make multiple splitters, to test different splitter lengths? I guess you could just make a plywood one, 150mm length, and then cut it down to 120mm, do some timed laps, then cut it down to 100mm and do some timed laps and see what yielded the best results.
Then with the proper length figured out, make a new splitter out of alumilte?
Old Jan 30, 2015 | 06:08 PM
  #465
woodchuck's Avatar
wow. this motivates me to finish up my aero project.
