Let's see YOUR track Evo
My Evo 6 Track/race car, built for sprints, hill climbs and Time attack. Car is also road legal for testing purposes!
All work done by myself apart from cage fitment and mapping and specialist machining, although I do the drawings for my machinist!
Just at the testing/set-up stage at the moment, but first impressions are very good. Supension and brakes feel awesome.
Spec as follows;
Engine:
Fully blueprinted and balanced.
2.2L Tomei Crank, Arrow rods, JE Pistons. 9.4:1 comp ratio.
ARP main and head studs.
HKS head gasket.
Balancer shaft removed, modified oil pump.
Norris spec Piper cams and valve springs, solid lifters, Jun Titanium retainers.
HKS adjustable cam pulleys.
Ferrea 1mm oversize inlet and exhaust valves, Bronze valve guides.
Custom Port job and combustion chamber reprofile and matching.
Ceramic coated Norris/Shearer tubular exhaust manifold, Tial 44mm wastegate, Garrett T04Z turbo.
AMS inlet manifold, custom made Garrett cored intercooler, Custom 3” inlet pipework.
AMS baffled wet sump.
Custom Breather with oil/air separator and return to sump with non return valve.
Sparktech M&W pro 12 COP ignition system.
Walbro lift pump, custom made swirl pot, Bosch 044 main pump, custom fit fuel cooler and ducting.
Modified standard fuel rail, RC engineering 1200cc injectors, Sard FPR. -8 supply, -6 return.
Koyo aluminium radiator with dual lightweight fans.
Fluidampr.
Motec M48 Pro ECU
Motec 4 Bar map sensor.
Custom modified 3” full magnex exhaust with custom centre silencer.
Custom uprated Oil cooler with Custom Ducting.
Approx 700bhp on 97oct and 800bhp on VP import @ 2.4 bar and 8000rpm.
Rev limit 8350rpm
Drivetrain:
Custom rear diff housing from billet alloy.
Rear Cusco RS LSD with 45deg ramp angle and strong preload.
Front Cusco RS LSD with 55 deg ramp angle and soft preload, and soft centre viscous diff.
Quartermaster cerametallic twin plate clutch.
Rebuilt gearbox with uprated Ricardo output shaft
Shot peened front and rear crownwheel and pinions.
Suspension:
KW Competition 2way Race suspension, 9kg front, 10kg rear,
KW rear top mounts, Cusco front top mounts.
Cusco 25mm front anti-roll bar, Perrin 25mm rear anti-roll bar
Custom front ball joints for adjusting roll centre.
Whiteline rear roll centre adjusting kit.
All suspension and engine bushes replaced with polybushes.
Front wishbone rear offset bush for increased front caster.
Chassis:
Full FIA T45 cromoly weld in cage with custom rear crossmember brace.
Custom T45 cromoly dash support beam.
Custom T45 cromoly Longitudinal engine/gearbox support.
Custom T45 cromoly lateral brace.
Body de-skinned and lightened where possible without compromising strength.
Body:
Varis carbon roof
Carbon boot
Custom modified doors with lightweight aluminium inner skins and 4mm Poly windows all round.
Motorsport Heated front windscreen
Brakes:
Custom made front brake kit, Porsche 6 pot monoblock calipers, 362mm AP racing discs
Custom bells and brackets, Carbotech XP10 pads front and rear.
Braided lines throughout, no ABS, Tilton brake bias valve, hydraulic handbrake.
Custom Brake master cylinder stopper.
Motul RBF600 fluid.
Wheels/tyres;
SSR type C 8.5x18 with 245/40/18 Dunlop D03G.
BBS CH Motorsport 8.5x18 with 225/40/18 Michelin Pilot Sport Cup.
Enkei NT03 +M 9.5x18 with 265/35/18 Toyo R888.
Interior:
Custom modified flocked lightened dash.
SPA gauges, Oil temp/pressure, Inlet temp/Fuel Pressure.
Knocklink Knock sensor.
AEM wideband AFR gauge.
Greddy B spec 2 boost controller.
ECU controlled Shift light.
Cobra Evolution Carbon/Kevlar seats.
Schroth 6 point harnesses.
500gram driver cooling fan
Lightweight racing battery.
Custom rebuilt wiring loom.
Custom carbon control panel.
Safety:
Lifeline Zero 2000 electric fully plumbed in extinguisher system.
Lifeline Zero 2000 handheld Fire extinguisher.
Cartek Solid State Battery Isolator Kit with external cutoff.
FIA Roll cage padding.
FIA T45 weld in roll cage.
Front tow loop.
Near future to fit:
Varis front bumper with canards and carbon spitter.
GP sports wide front wings.
Carbon side skirts and carbon rear diffuser.
Custom wide rear arches.
A selection of pics throughout the build;
Spec as follows;
Engine:
HKS head gasket.
Fluidampr.
Motec M48 Pro ECU
Rev limit 8350rpm
Drivetrain:
Suspension:
Chassis:
Body:
Varis carbon roof
Carbon boot
Brakes:
Motul RBF600 fluid.
Wheels/tyres;
Interior:
Safety:
Front tow loop.
Near future to fit:
Most recent track vid: http://www.youtube.com/watch?v=O5MB6HAqMKM
I primarily run NASA TTB Midwest division, but also instruct for the SCCA, run some Redline TA in Street AWD and basic lapping / test-n-tune days. For more info, check out: BlogSpot or Twitter
Here's pretty much a complete list as the car sits currently:
2006 EB Evo IX - 21k miles:
Power Mods - restricted for NASA TTB:
- Ecutek Flash custom tuned @ AMS
- 311whp / 321wtq on 93oct
- 3" Heatwrapped Buschur TBE w/ TestPipe
- Blitz panel filter
- ARP Head Studs
- Stock clutch, trans, block, cams, turbo, etc
Redline Street - Switch out some powa mods:
- 3" Buschur TBE w/ HF cat
- AMS MBC
- 363whp / 366wtq on 100oct
Stop/Turn:
- Muellerized JIC Coilovers
- Energy Suspension rear trailing arm bushings
- Evo 'blank' Front rotors
- Forge Cooling air ducts
- Goodrich SS Brake Lines
- AMSOIL DOT4 Brake Fluid
- Hawk DTC60 Brake Pads
- Front Ti backing shims
- 245/45-17 Dunlop Z1's on Stock IX enkies - Redline Street and rain tires
- 17x9 5zigen FNO1R-C - 2 sets
- 245/40-17 Hoosier R6 - 2 sets
- self alignment
Other:
- No rear seats
- No pass seat
- Sparco Figther drivers seat - Binary lowered
- Biltz TT
- Perrin Shorty Antenna
- CF Doorsills
- STRi Boost Guage & Oil Temp Gauge
- Greddy Shift Knob
- Autopower 4pt Rollbar
- G-Force 6pt Harnesses
- Modified stock seats for sub-belts
- Traqmate
- Mishimoto Radiator
- AMS mini battery
- AMS 5sp shifter bushings
- Redline drivetrain fluids
3265 lbs with 3/4 tank of fuel
What I like most:
- A solid safe powerful tune I never have to worry about
- Finally have a minimal suspension setup w/o understeer! No off-power oversteer; ever.
- The grip of Hoosiers...tasty
What I've learned:
- If restricted by mods, build your car around your tires and maximize corner speed. Evo's have to fly through the corners to turn good laps.
- If your car has understeer; you might have a bad suspension setup.
- Evo IX 4th gear is way too f'in short
Future Plans - where to start... It really depends main group I want to run with next year as I've already learned you can't build a car for both NASA and Redline!
- Shep tranny rebuild with updated gearing
- TRE Rear Diff mod
- Shed another 200 lbs
- More Gauges inclusing wideband
- Modify fenders for 275+ tires
- rear diffuser for aero
- AMS wet sump oil pan (be safe in the corners)
- AMS fuel surge tank (run on empty!)
- cams?
- FP Red bolt on?
- AMS 2.3l stroker?
- AMS 750R Turbo?
my personal car (i.e. daily driver and track duty car):
engine:
Engine mods: ~500whp @30psi when on the track usually 24-25psi
Buschur 35r turbo kit with the cast manifold
Buschur candy cane LICP
Buschur UICP
Buschur Intake
Kelford 272 intake/exhaust cams
springs/retainers
Fidanza adjustable cam gears (set to 0/0 haha had them from the hks cams still)
Vishnu Signature series turbo back exhaust with test pipe
Forge RS blow of valve
buschur race intercooler
880cc injectors
AMS fuel rail
Walboro 255 fuel pump
greddy profec B spec 2 EBC
Zeitronix WB with ZR-2 gauge 3.5 bar MAP sensor
self tuned
buschur Mini battery
Aquamist HFS-5 methanol injection kit
CBRD lightweight race radiator
spal slimline fan
drivetrain:
Shep stage 2 transfercase w/lsd
ACT clutch
ACT lightweight flywheel
wheels/Brakes:
pirelli P-zero corsa tires 255x40x17 (track) on stock rims
performance friction 2 peice front rotors
hawk blue pads (F+R)
stainless lines
AMSOIL brake fluid
dust covers removed (F+R)
custom air ducting up front (thanks to TNT1109
interior:
Sparco Harness Bar
Sparco 5 Point Harnesses
weight reduction:
JDM rear bumper with no crash beam
seibon carbon trunk lid
removed intercooler sprayer
buschur front motor mount bar thingy
suspension:
JIC flta2 coilovers
hotckis adjustable rear swaybar
perrin endlinks
don't have many if any pictures recently, but i always do in car video.
Harris Hill Road:
http://www.youtube.com/watch?v=xHi8tpCqcew
http://www.youtube.com/watch?v=RqyW9XTFUok
eagles canyon:
http://www.youtube.com/watch?v=8h8Be7jHxdg
http://www.youtube.com/watch?v=w3Itx...eature=related
http://www.youtube.com/watch?v=aFtaqDOOoqE
motorsports ranch:
http://www.youtube.com/watch?v=d-QRbn-OGKI
http://www.youtube.com/watch?v=6HnSwcIjkmI
engine:
Buschur UICP
Buschur Intake
springs/retainers
880cc injectors
AMS fuel rail
self tuned
spal slimline fan
drivetrain:
ACT clutch
wheels/Brakes:
stainless lines
AMSOIL brake fluid
interior:
Sparco Harness Bar
weight reduction:
suspension:
JIC flta2 coilovers
perrin endlinks
Harris Hill Road:
eagles canyon:
motorsports ranch:
the shop car (dedicated track car, in the build process right now):
'03 evo 8 building for NASA TTU and redline TT unlimited
engine:
2.3L stroker
blunt edged crank
.020" over
eagle rods
JE or wiseco pistons (haven't decided yet)
Cosworth head
Kelford 272 cams
AMS HTA35r turbo kit (might switch to a red for more torque and less power in TTU, and will be building our own manifold for next year)
evodynamics custom exhaust, intake and intercooler pipes
mini battery
forge RS BOV
evodynamics twin pump system
large injectors
stock ecu, with 3 port boost control, E85, tuned
suspension (stealing it from my daily driver for now):
JIC FLTA2 coilovers
more to come...
wheels/brakes:
wedsport SA-70 17x9 with hoosier R6 in 275 width (for this year, 18"x 10.5 enkei rpf1 this winter)
stock brakes, with the performance friction two piece front rotors (this winter going to big brakes)
hawk DTC-70 pads
AMSoil brake fluid
stainless brakelines
evodynamics custom air guides
interior:
gutted, cage (this winter)
recaro SPG seats
sparco harness bar (this year until cage)
sparco harnesses
fire system (this winter)
exterior:
evodynamics custom dry carbon hood (ultra light)
seibon carbon wide front fenders
carbon roof (this winter)
carbon trunk skin (this winter)
GTC-300 APR wing with custom risers (this winter)
evodynamics custom undertray with rear diffuser (this winter)
the only pictures i have are of when we got the shell to build the car from. i'll make a build page in the next week or so as we get started. first event for a shake down test of the car is september 26th, and NASA event the week after.
all the parts not listed as this winter are sitting on the shelf waiting for a moment to actually put it on the car. the motor is at the machine shop, and the head just got back from being flowbenched.
engine:
2.3L stroker
blunt edged crank
.020" over
eagle rods
Cosworth head
Kelford 272 cams
mini battery
forge RS BOV
large injectors
JIC FLTA2 coilovers
more to come...
wheels/brakes:
hawk DTC-70 pads
AMSoil brake fluid
interior:
recaro SPG seats
sparco harnesses
exterior:
