Let's see YOUR track Evo
Old Aug 12, 2009 | 12:19 AM
  #91
OctaneReport's Avatar
Here is our Street AWD time attack Evo 9 project car. Still daily driven. Full interior/weight, a/c, stereo, registered, stock intake, cams, turbo, intercooler and ECU. Stickers and aero are swapped on/off before/after time attack events, track testing and car shows. Biggest go-fast mods are the JIC coilovers, 18x9.5 5Zigen FN01R-C wheels (NT05 tires are coming next), Works downpipe, GReddy exhaust, Tuning Technologies ECU flash, APR / M1 Fabrication aero and good pads.
We've taken a class win and a third place podium out of two events in '09. Not too much power (especially for the class) but a lot of setup time. Visit our build articles below:
All the project car updates can be found HERE
Old Aug 12, 2009 | 11:13 AM
  #92
delongedoug's Avatar
Originally Posted by Jeff_Jeske
I have two sets 8/10 and 9/11 with 24mm RSB. I'm heading to MAM next friday and I'm gonna try the stiffer of the two. It's a 9 hour road trip so by the end of it I should know whether or not I think that is too much or too little.
Let us know what you think of the 9/11s compared to the 8/10s. I'm currently running the 8/10s and have been in some much much stiffer setups recently. Curious what a little step up might do.
Old Aug 12, 2009 | 02:04 PM
  #93
blkmkIII's Avatar
me and Ssccoootttt (is his evom name)
-downpipe, z1 star specs... STU. more to come... asap.
Old Aug 17, 2009 | 06:20 PM
  #94
ninetails's Avatar
sweet rides!
Old Sep 15, 2009 | 05:52 PM
  #95
timmiii's Avatar
Just curious but is there a difference between a 17" and 18" wheel setup for the track besides the cost? Does the 18" "feel" better or more responsive than the 17" setup?
Old Sep 15, 2009 | 09:40 PM
  #96
Jeff_Jeske's Avatar
If you want to go really wide ..... there are more options in an 18" tire.
Some big brake kits do not fit with 17" rims.
If you are sticking with 255 or less then nothing wrong with a 17x9.
Old Sep 16, 2009 | 07:27 AM
  #97
boomn29's Avatar
That's pretty much the straight poop!
18" offer more larger size options (like 265's for instance) but cost more and are heavier. BBK = 18" only for the most part.
Now if you're going to run street tires on the track, it might be worthwhile to run an 18" tire for a shorter (aka stiffer) sidewall option.
Old Sep 16, 2009 | 07:39 AM
  #98
Balrok's Avatar
I don't mean to poke the search finger, but i'd like this thread to keep the TA car action coming
Bump this one for more info on wheel sizes
https://www.evolutionm.net/forums/mo...ad-course.html
Old Sep 20, 2009 | 12:40 AM
  #99
AIREKone's Avatar
Engine
-378whp/356wtq on 91 oct., 402whp/373wtq on 100 oct.
-Tuning Technologies custom ECU tune
-CBRD BBK full turbo
-Cosworth M2 camshafts
-ARP headstuds
-eBay 02 housing
-Buschur down pipe
-Greddy titanium exhaust
-iApex cone air filter w/ box
-ETS 3.5in intercooler
-Nisei LICP
-RC 1000cc injectors
-MilSpec 100 cell cat
-Walbro fuel pump
- Gruppe-s 3port boost solenoid w/ map switching
Suspension
-RobiSpec KW Race 2-way coilovers
-K-Mac camber plates
-Whiteline roll center kit
-Energy Suspension rear trailing arm bushings
-Whiteline rear bump steer bushings
-Progress 25mm rear sway bar
-DCsport Titanium front strut bar
-Cusco rear strut bat
-RS rear trunk bar
-RobiSpec custom alignment and corner balance
Drivetrain
-ACT clutch and flywheel
-TRE rear diff upgrade
-AMS shifter base bushings
-AMS shifter linkage bushings
-RRE SS clutch line
Exterior
-Voltex street front bumper w/ undertray
-Voltex wing
-GarageHRS wide fenders
-JDM rear bumper
-Buschur rear under tray
-JDM Evo 7 taillights
-APR mirrors
Interior
-Bride ZetaIII seat
-Nardi Rally Sport 350mm steering wheel
-Defi gauges (boost, water temp,oil pressure)
-WorksBell hub and quick release
-Schroth Rallye4 4-point harness
Wheels
-Enkei RPF1 17x10 +18F/+38R w/ Nitto NT01 275/40/17 (track)
-Enkei RPF1 18x10 +38 w/ Advan AD08 255/35/18 (time attack street class)
-Volk CE28 17x9 +35 w/ Nitto NT05 255/40/17 (time attack street class)
-OEM Evo 9 w/ Falken Ze502 235/45/17 (daily drivers)
-ARP wheel studs
-Buddyclub lug nuts
Brakes
-Performance Friction PF01 brake pads
-Stoptech SS brake lines
-Centric blank rotors
-OEM brake air guides
-Motul RBF600 brake fluid
Old Sep 20, 2009 | 02:56 PM
  #100
o-townFLA's Avatar
^^^ haha Post *****...
Old Sep 20, 2009 | 03:14 PM
  #101
DSMorBUST's Avatar
this thread is AWESOME.
Old Sep 20, 2009 | 03:44 PM
  #102
jid2's Avatar
AIREKone -
What spring rates are you running? Your car looks great and has some niiice parts!
Old Sep 20, 2009 | 05:12 PM
  #103
AIREKone's Avatar
Originally Posted by jid2
AIREKone -
Thanks! 8f/9r, rear sway bar set at full stiff.
Old Sep 20, 2009 | 05:45 PM
  #104
Nastynine's Avatar
a little off topic, i don't knowmuch about auto xing' and road racing my evo's build for drag, but i've been rele interested in building a old school like 95 impreza and set it up for road racing, but anyway
whyy do ppl put blue tape on their head lights?? is there a reason for this? its always made me a little curious
Old Sep 20, 2009 | 06:46 PM
  #105
Ludikraut's Avatar
So that they don't get chipped by debris being kicked up from other cars. Sticky, wide tires pick up and fling a lot of crud.
l8r)
