Blackenedwings '06 IX MR build thread
Dude, your car sounds amazing. I see you have the same issue with the GoPro camera rattle as I do.
Do you run it with the water proof cover on or the open back? I had to use the water proof cover to stop the obnoxious wind noise.
What video editing software do you use?
looking forward to seeing you compete next year. i guess you're going to run with nasa mid-atl and not nasa northeast? i run with nasa northeast but have run with mid-atl at summit several times since the track is only 1.5 hours from me.
i'll be dropping power and class next year, so we wont be in the same class.
Thanks for the comments guys, yeah the GoPro is in the waterproof container, although I could probably take it out where I have it mounted. It pivots around because of the stupid cheap plastic screws. I use regular Win 7 Windows Movie Maker to "edit" the videos which in my case so far has been just crapping them onto YouTube. I'm going to try and get some slicker video next season. Not sure who I'll be running with next season yet honda-guy. I might do NASA TT or Real Time Attack or Global Time Attack. Still weighing options. I have to talk to my sponsor too because that will impact my decision.
i got videos of some laps there in september running on NT05 street tires. power level was around 330 whp mustang dyno. video show 1:23.x, i think i can get into 22's if i push harder in clean traffic, on NT05 tires.
Edit: I really like your line through 1 and through 5. I've been trying a tighter line on 5 and I think its costing me time. I really want to get back out there now!
^ thanks. most w2w race guys takes tighter lines through the turns to defend position. i take wider entry for better exit speed even though it adds track distance. i give up a little on T4 to setup for T5. i have to get the car settle before braking for T5 or my rear will lockup since i don't have ABS.
I'll probably be going to NT01 tires next season depending on the class I go for, what tires are you running?
you can hear the tires screaming on very turn on the new asphalt patch.
i started running A6 this year with NASA TT. have only been using a couple years old used A6 though. i won 2 new A6 this year, so next year i'll have two new A6 and two used A6 to start the season
i'll still be using NT05 for DE events and GTA, since i'll be running in street class for GTA. and A6 for NASA and NARRA.
