Curb weight reduction
Old Mar 8, 2017 | 01:08 PM
  #106
Balrok's Avatar
Ya'll should hit up Dan because he already did several revisions of this on the pro awesome car. He's even controlling each fan based on temp all within the AEM infinity. Pretty slick in person.
Old Mar 8, 2017 | 03:26 PM
  #107
Meathooker's Avatar
i picked his brain a few weeks ago
Old Mar 8, 2017 | 04:22 PM
  #108
godlikelol's Avatar
EZ , get a gym membership and that will shave off weight KAPPA!!!!!XDXDXDXDXDXDXDXDXDXDXD
Old Mar 8, 2017 | 05:40 PM
  #109
kaj's Avatar
kaj
Already did that. -20lbs. Now gotta wprk on that car.
Old Mar 8, 2017 | 06:09 PM
  #110
V.8MR's Avatar
I guess being a smaller guy pays off for something. Only 5'6" and ~150lbs myself haha
Old Mar 8, 2017 | 06:28 PM
  #111
Balrok's Avatar
Originally Posted by Meathooker
i picked his brian a few weeks ago
Nice
Did he take it....sitting down? Or is he a ....stand up kind of guy
Old Mar 8, 2017 | 06:52 PM
  #112
kaj's Avatar
kaj
Putting the cooling system, ACD pump, etc. into the back of the car sounds awesome. If I knew how to fabricate everything, that would be an awesome project. Then I could pretend I have a rally cross car LOL
Old Mar 8, 2017 | 08:00 PM
  #113
Meathooker's Avatar
Nice
Old Mar 9, 2017 | 01:50 PM
  #114
EvolTweetyBird's Avatar
Originally Posted by Shiroi Kitsune
Naturally you want to help the balance but overall weight reduction is always good. We'll have a mini battery in the rear, ACD pump will be back there, Accusump, cage is behind centerline fire system behind center line, etc.
So true. We are building to turn left and right and go fast doing it.
Less weight means better cornering, acceleration, and braking. Not to mention adding the WiseFab wide stance suspension/steering to make it handle even better.
And less weight takes less horsepower to out perform the competition in a heavier car.
And ours it going to be more a track car vs street so what we are doing may not be what you want to do to yours.
Old Mar 15, 2017 | 05:00 PM
  #115
03whitegsr's Avatar
Step 1. Buy my car
Step 2. Enjoy a ~2600 pound 500HP EVO.
Oh, there is a middle step in there where you'll have to finish the wiring that I still haven't finished after like half a decade.
LOL
As for random things I've done to reduce weight (it has become a drag car at this point):
Motor mounts -> ~18 lbs lighter
Dash bar/steering column -> ~20 lbs lighter
Intercooler -> 13lbs total weight with piping (rated to 500+ HP)
Fuel Cell -> ~30lbs lighter + 60lbs less fuel weight (when full)
Side exit exhaust -> ~3 lbs total weight
Tial turbine housing/tubular manifold -> ~18lbs total weight
Electric water pump and power steering pump
Manual belt tensioner (only alternator is crank driven)
As for moving the radiator to the rear, it brings with it a lot of other issues. For one, you are now creating two different high spots in the system. This requires being smart with how you implement the system, basically forcing you to adopt a "constant bleed" type setup, which is better anyway.
Old Mar 19, 2017 | 07:10 PM
  #116
More weight gone. Back and to keep some of you happy, front too.
Wise Fab wide stance/lowering powder coated aluminum spindles vs stock boat anchor cast versions. You also loose the stock backing plates, parking brakes, and related hardware.
All stock control arms, and tie rods will go away too, replaced with more Wise Fab, with spherical bearings instead of bushings.
Less weight, wider stance, sitting lower, much wider race tires, going to corner like it's glued to the track.
Now have to worry and try and figure out how we are going to get it on the trailer.
Attached Thumbnails Curb weight reduction-new-vs-old.jpg   Curb weight reduction-old-vs-new-4.jpg   Curb weight reduction-old-vs-new-2.jpg   Curb weight reduction-old-vs-new-3.jpg
Old Mar 19, 2017 | 07:20 PM
  #117
kaj's Avatar
kaj
I'm jelly
Old Mar 19, 2017 | 07:34 PM
  #118
Kidloco51's Avatar
Super Jelly. #someday
Old Mar 19, 2017 | 08:14 PM
  #119
V.8MR's Avatar
Love it
Old Mar 20, 2017 | 07:00 AM
  #120
killerpenguin21's Avatar
There seems to be multiple hub solutions all of a sudden. Wise fab and brypar and I think one other...might need to be my next move since I already have x control arms on the car.
