Cooling Setups for Track Use
to be honest ive used chinese ****ty rads for years and the only time ive had them fail is when ive burnt a hole in them from a blown weld on my wastegate exhaust. Ive found for me at least cooling is almost not needed while on track as the air does a good enough job. its when you come in and stop it becomes a problem lol
*knocking on wood*.If someone comes up with an aluminum radiator and aftermarket fan that works better than OEM, I'll go that route. I'd actually like to ditch the heavy OEM fan..but it works, so... Or.. if there comes a point OEM is no longer an option for me, then I'd obviously be forced to go aluminum. In the mean time, I'm golden.
Same here. My radiator is original to the car. I run events with 100*+ temps. So far, not so much as a hiccup, though my cooling system never sees more than 5-7psi and I'm told pressure is what kills the plastic tanks. I do have a used OEM in the garage as back up. I bought it 5yrs ago and haven't had to use it, yet. WooHoo. Of course, with my luck... saying that...
*knocking on wood*.
Honestly ive been looking into this!
Weve tried keeping the fans on after stopping etc but cause the water doesn circulate the block water heat soaks, Electric water pump would be perfect. but where do u mount it and do you delete the mechanical pump etc?
STM delete plate: https://stmtuned.com/products/stm-ev...UaAo0zEALw_wcB
MAP sells one too as well as a few other evo specialty shops. As for a pump I'd look at Craig Davies, they're pretty much the biggest name in electric water pumps and they're over on your side of the Pacific.
