Cooling Setups for Track Use
Old May 10, 2019 | 10:52 AM
  #76
Ayoustin's Avatar
I'm working on an air cooling conversion kit
Old May 10, 2019 | 11:37 AM
  #77
kaj's Avatar
kaj
Maybe this for OEM radiators?
https://stmtuned.com/products/mishim...diator-shrouds
or as a cheaper option?
https://stmtuned.com/products/flex-a...r-electric-fan
Old May 10, 2019 | 12:51 PM
  #78
Terror Rising's Avatar
I have that FAL 12-1/8" on back of my Koyo and other than it being a super tight fit with the WGA it's all good. I figured it was better than just a standard slim fan with no shroud and I haven't experienced any cooling issues with it.
Old May 10, 2019 | 01:08 PM
  #79
LetsGetThisDone's Avatar
Idk about the flex a lite, but one should avoid Mishimoto products. None of it seems to work as well as any pretty much anything else..
Old May 10, 2019 | 02:18 PM
  #80
kaj's Avatar
kaj
My stuff is all OEM style, so no worries for me. I have plenty of room with the OEM fan.. But extra room for the UICP and my hands would be great. Less weight = bonus.
Though something that looks aftermarket may affect me during smog time.
Old May 10, 2019 | 05:45 PM
  #81
ProPilot04's Avatar
Hey all. Getting ready to do the timing belt and water pump. Have an HPDE coming up at VIR and wondering if I should just run normal coolant (which is bad if it comes out) or run water for the track event?
Setup:
Radiator - stock
Radiator fan - stock
Radiator cap - stock
Thermostat - stock
Oil cooler - Stock
Oil Pan - Stock
Fluid - Currently stock, but asking... (Distilled water and water wetter or 50/50?)
Water temp gauge - stock
Power/torque - 305/305
Car is a 9MR
I do have beatrush undertray that I'm debating about running at the track. I generally would prefer to run it, but I'm worried I might cook my brakes... then again, it's nice protection and would probably help with cooling and "aero"
Flame away
Old May 10, 2019 | 06:24 PM
  #82
Just run coolant. If you're somewhere that it doesn't get super cold. You can run 75/25 + water wetter.
Old May 10, 2019 | 06:42 PM
  #83
kyoo's Avatar
i run coolant + one bottle of water wetter, havent had any issues
Old May 10, 2019 | 09:02 PM
  #84
ProPilot04's Avatar
Oh I'm not specifically TRYING to not run coolant... it's more the whole, if it leaks it can cause a serious incident on the track. I'd probably run the water for the track event and then drain it and run the normal 50/50...
How high or low do you guys run your overflow bottles?
Old May 10, 2019 | 11:51 PM
  #85
I leave my overflow empty for track days. If I don't the car will push coolant out of it the first session. Running 205* for 20 minutes grows the coolant quite a bit.
Old May 11, 2019 | 08:21 AM
  #86
kaj's Avatar
kaj
Another reason I use Evans
But in cars I use water: I agree water + coolant + water wetter. Works great!
Old May 11, 2019 | 12:13 PM
  #87
Evans is a pain in the dick. If you lose a hose you have to have a bunch of Evans on hand to fix it.
Old May 11, 2019 | 01:16 PM
  #88
Ayoustin's Avatar
I run straight water and like half a bottle of wetter. IIRC it calls for like an ounce of wetter per gallon of water.
Old May 11, 2019 | 02:28 PM
  #89
V.8MR's Avatar
I run straight distilled water, until its gets cold towards the end of the summer and then do premix Zerex "pink" coolant.
Old May 11, 2019 | 08:01 PM
  #90
kaj's Avatar
kaj
I do, two gallons. In an emergency, I toss water in add re-do later.
