Old Jan 5, 2020 | 01:26 PM
  #1141
Bee-Raddd's Avatar
you should also be able to do stuff like remove ur window motors and everything in ur doors also as RS didnt come with electric windows. theres alot of weight inside there
Old Jan 5, 2020 | 01:46 PM
  #1142
kyoo's Avatar
i'm picking up the evo on tuesday - they have said everything has come together nicely, and pre-rolled the fender for me even before painting. 100 cell cat arrived 3-4 months later after i ordered it, so i've already got a mod waiting for it lol.
anything i should look over in detail when I pick up the car? I've got a list of things I'd like to check but want to see if I've missed anything.
Old Jan 5, 2020 | 02:03 PM
  #1143
Dallas J's Avatar
Veteran: Army
The weight difference of powered to RS isnt significant in the doors of the 9. The main weight difference IIRC is the steel to aluminum crash bar which my car already has being a 9 SE.
Old Jan 5, 2020 | 06:53 PM
  #1144
Bee-Raddd's Avatar
if it was me id gut the whole lot incl the crash beam and put the door cards back on as if nobody had been in there but i cheat like ****
Old Jan 5, 2020 | 07:09 PM
  #1145
Dallas J's Avatar
Veteran: Army
Lol, well theres a lot at risk when your car is at the top. And a lot of prying eyes to whats done to the car. Even stalkers to the posts I make here from what I've heard. So I make sure to keep things on the up and up, just try to be a good and respectable competitor worth chasing all while meeting new people who are willing to share some trade secrets with me
I did find the post earlier today on how much RS doors save over what I have, its 0.5lbs per door. For the effort, there is still quite a bit more I can do that even Im not crazy enough to go thru that effort for 2lbs for all 4 doors.
Old Jan 5, 2020 | 08:04 PM
  #1146
bboypuertoroc's Avatar
Veteran: Army
Winter "project":
Rebuild head. Timing belt decided to change itself while I was driving. Still haven't pulled head but pulled turbo and can see bits of valve in two cylinders and also entering the exhaust manifold. Planning on sending head to Curt Brown. Planning on sending my intake manifold as well for 65mm port and sending throttle body to mil.spec for porting and new seals. If there's damage to any cylinders or pistons I'll likely be building a 2.4lr to swap in as well. Also need to fix my exhaust now since the rear hanger gave out while I was pulling my downpipe.
Old Jan 5, 2020 | 10:35 PM
  #1147
kikiturbo's Avatar
Favourite european rally cheat was running evo 7 shells with e9 bumpers and hood, and calling it evo 9.... Since e7 shell is lighter it was a popular "mod". It did cause a lot of cars to be thrown out LOL.
Old Jan 6, 2020 | 09:18 AM
  #1148
Bee-Raddd's Avatar
Really? how are evo 7 shells lighter. thats a new one to me, what is it that makes them lighter? i would have thought 8/9 shell would be lighter due to the roof.
Reminds me i should weigh my car haha
Old Jan 6, 2020 | 11:52 AM
  #1149
kikiturbo's Avatar
I know, it sounds stupid... I will look into it more... but I know of several cars running illegal evo 7 shells in national rally and being caught..
Old Jan 6, 2020 | 12:06 PM
  #1150
Biggiesacks's Avatar
maybe the newer chassis had to deal with more crash test regulations, or something along those lines that resulted in more weight.
Old Jan 7, 2020 | 10:11 AM
  #1151
Bee-Raddd's Avatar
ahh actually could be the USDM crash beams etc? they add quite a bit of weight i believe. the JDM spec ones dont have front n rear crash beams on them
Old Jan 7, 2020 | 05:16 PM
  #1152
kyoo's Avatar
that's the only difference I'm aware of
​​what axles do you guys recommend for a 350hp car that sees autox and track days? the dss 900hp seems like Overkill, the only other option side from oem is their level 0 which seems like not enough
Old Jan 7, 2020 | 05:25 PM
  #1153
LetsGetThisDone's Avatar
The level zero is fine.
Stock axles hold 900hp so I find it funny they offer an "upgrade" for 900hp...
Old Jan 7, 2020 | 06:12 PM
  #1154
kyoo's Avatar
gotcha that will save some cash then. unless the level 2 will save an extra replacement down the line? they do see launches and heat.. wonder if they'll have a level 1 if I contact them
Old Jan 7, 2020 | 06:48 PM
  #1155
Dallas J's Avatar
Veteran: Army
I just sourced a full set of spare axles. Took a while and they're getting harder to find but they are pretty good.
