Old Oct 29, 2019 | 06:07 PM
  #1081
heel2toe's Avatar
Originally Posted by V.8MR
We need pics or none of it happened.
Truth
Old Oct 30, 2019 | 10:53 AM
  #1082
Bee-Raddd's Avatar
Ill take some nicer photos tonight haha hard to get clean ones in the garage. Also need to make a longer start power cable which i can hide as its currently using the stock one which looks terrible
View this post on Instagram
Old Oct 30, 2019 | 10:59 AM
  #1083
Bee-Raddd's Avatar
Originally Posted by alpinaturbo
Looking forward to hear how Cusco rear LSD affects chassis, compared to RS rear LSD.
I had a cusco RS version LSD in the back of my AYC diff which i modified and removed all the AYC system and what not. It blew a crown wheel and i borrowed a stock RS diff to continue racing for the season,
The RS was quite understeery in comparism and didnt drive off the corner anywhere near as good. probably .5 to 1sec a lap slower depending on the track. The Cusco was just point and shoot on exit it was great. the RS diff tended to understeer alot more
In saying the Cusco was point and shoot i never got any oversteer or opposite lock moments on exit either i could just hit the apex open the wheel slightly and boot it and it would track where i pointed the nose. Ive just purchased another to go in my RS diff im setting up cause i liked it that much.
Old Oct 30, 2019 | 11:08 AM
  #1084
Dallas J's Avatar
Veteran: Army
One might say, if you don't have enough rear diff, the car will tend to push on exit throttle. If you don't have enough front diff, the car will tend to oversteer on exit throttle.
If you dont have enough of both, the car my snap understeer to snap oversteer in unpredicable ways. Ask me or Marshal how we know
I have the gymkhana rear diff and 1way clutch front on the way but its been slow waiting for new production runs from Japan. Front should ship next week and Rear 1-2 weeks later.
Old Oct 30, 2019 | 11:24 AM
  #1085
kyoo's Avatar
gymkhana rear diff? is that the super aggressive cusco 1-way with 55 degree ramps? and switching to a 1.5 rs?
Old Oct 30, 2019 | 01:31 PM
  #1086
Ayoustin's Avatar
I'm patiently waiting to see how everyone's diff adventures work out before I decide if I'm going to depart from my wavetrac lol
Old Oct 30, 2019 | 01:51 PM
  #1087
Bee-Raddd's Avatar
wavetrac center? see i dont want to swap my wavetrac ever because of their lifetime warranty hahah
Old Oct 30, 2019 | 02:00 PM
  #1088
Dallas J's Avatar
Veteran: Army
With the power you make, you should log your wheel speed. Front inside tire with high power on track can spin up a lot from what Dan at PA has told me. He's making the change to clutch front as well last I heard.
Yep, thats the rear diff Im running. High preload but lifting an inside rear on turn with high grip, high rear rates, and high caster will let me actually turn and car will put power down as Im adding power with the inside rear still unloaded.
Old Oct 30, 2019 | 02:21 PM
  #1089
kyoo's Avatar
i gotta say i was really happy with the rear diff after TRE fixed the osg, actually worked again - i want to say as well as the cusco had before it
Old Oct 30, 2019 | 02:40 PM
  #1090
Construct's Avatar
Did you ever have a TRE Maxlock setup? If so, how did the OSG and Cusco compare?
Old Oct 30, 2019 | 02:42 PM
  #1091
kyoo's Avatar
unfortunately i did not, no. it was i want to say almost 10 years ago that i got the cusco, it was before the tre maxlock was as widespread as it is today.
Old Oct 30, 2019 | 05:42 PM
  #1092
griceiv's Avatar
Thumbs up
If you dont have enough of both, the car my snap understeer to snap oversteer in unpredicable ways. Ask me or Marshall how we know
You know it's bad when the trick to going faster is by using less throttle on corner exit. the new diffs should be fun.
Old Nov 2, 2019 | 02:17 AM
  #1093
Bee-Raddd's Avatar
Well everything is done pretty much and cars ready for ecu pre wire and tune!
Old Nov 12, 2019 | 02:25 PM
  #1094
ViciousLSD's Avatar
HI gents,So I broke my rear axle. my weir lsd plate lost all of their inner tabs and 3 of the discs broke to pieces. Is what happened my LSD stopped working and therefore transferred all the power to 1 axle? There seem to be a hairline crack that was rusting away for a while now. can over torquing do that? oh well. anybody tried the "Insane axles"? I dont think i would want used axles
Old Nov 12, 2019 | 03:35 PM
  #1095
LetsGetThisDone's Avatar
That's is just what the weir LSD's do. The axle failure is likely unrelated.
