Originally Posted by kyoo
makes sense.
going back to the evo, i still haven't gotten to further diagnosing the noise, but I am pressing forward with pre-crash plans, including swapping in a superpro steering precision bushing - i think the WL one is junk. While we're going to have the subframe down, I think im going to go BACK to the stock front sway bar - I haven't been crazy about the handling on the evo since the FSB, even with a larger RSB the front end never felt as responsive. The FSB was a result of all the talk about how for mcstrut, it can help maintain camber, and while that might be true I don't know if there's a ton of actual benefit there. thoughts?
For the FSB, did you up the RSB to match?
Got my diffs back. Now I can get back to assembly to put some miles on the new R&P, clutch LSD discs, and exedy twin before ripping in april. 500-1000 miles will be tough, I usually only put about 1000mi on the car in a full year which is all on track.
https://www.instagram.com/p/B7rlpi2Hsoz/
this bushing: https://www.maperformance.com/produc...-8-9-spf2489k?
not to fix noise, just wanted to replace the WL steering bushing. Separate from this, whenever we would align toe on the front end, it would move/kink the steering wheel so straight wasn't straight. everything else tight, so I'd like to redo this bushing as it's the only one that changed.
Yes, upped the RSB from WL's 24mm stiff to their 26mm med. It will still get loose, but IDK, I guess I just don't like the feel of the FSB? Technically it should have balanced out, but I think I could go soft on the 26 and go back to stock - current is the Tanabe hollow FSB.
makes sense.
When you have an option to modify both springs and bars, similar results could be achieved on both end of this and anywhere in the middle (going very stiff with springs and mild bars vs. heavy bars and softer springs). I think the final decision is usually done with the way individuals like their cars to behave. In any case, results are good when balance is right! When it is too stiff or too soft, it only means that you still have more work to do!
here's the same corner in both cars - it's a corner that you can't exactly trail in, and obviously i entered the previous corner differently in both cars, but:
https://youtu.be/gH9UAscUOYQ?t=78
https://youtu.be/VUz6aYhMWr8?t=68
driving can and is adjusted for this corner specifically and obviously not perfect driving but i feel like the evo should be able to turn through it a little better than the M3. It leads on to a big straight and I usually have to back off to get the turn completed there. maybe i'll switch back for a year to stock, and see how it feels. springs are 8/11 so i'm on the softer side but the balance feels pretty good for track.
You really don't have enough spring to warrant the bigger bar. Springs and bars are on of those things that need to be matched with each other. To far apart and they make the car weird.
I'm not even gonna read thru the above stuff. Unless you are trying to run very street friendly rates, stock front bar 100%. If you are running like 10k front springs then maybe upgrade it if you have too much roll.
Stock front bar and WL 24 or 26mm is a good option. The step from 24 stiff is exactly one step below 26 soft (I measured these numbers dangling weights from a bar on my car with an indicator)
Yeah, VW's are MAF based with a complex ECU I could totally see the ECU making boost comps for this stuff.
Maybe @razorlab knows?
Edited to actually tag razor because apparently none of the new VBulletin functions work on the garage talk app.
so yes, colder air, less boost for same calculated torque.
Same reason there are 20 new threads of “omg I hit boost cut, did I break thangs?!??” Every.single.winter.here
all the Bosch MED ecus (and most modern ecus) are torque based. Aka, completely different than mitsubishi.
Pretty much every modern ecu is load based. Load = torque. Load is just an arbitrary calculated number by the ecu based off spark advance, cam timing, cylinder air mass, fuel mass (or injector duty cycle) and affected by any multiplier tables for safety like barometric pressure, any measured temperature on the engine, or feedback from the knock sensor etc.
Here is a 3rd gear log from my VW if you are curious: https://datazap.me/u/razorlab/alltra...6&zoom=212-432
