Connecticut Evos
Old Sep 14, 2010 | 05:14 PM
  #2506
liam11's Avatar
Does it sound like losse metal flapping, or something caught in a bike spoke? Cause if so, let me know if you get it figured out because i have a similar issue lol.
Old Sep 14, 2010 | 05:28 PM
  #2507
qucifer's Avatar
No, not really. It is more of a clunk or thump, that has no perceivable relation to the angle of the steering wheel. Some people have described a failing CV joint as having a clicking noise when turning, but I don't believe I would describe my noise as clicking and i experience most of the noise while proceeding in a straight line.
Old Sep 14, 2010 | 06:41 PM
  #2508
ethan169's Avatar
Bryan try searching for a thread called "clunking front end noise" it's been around for a long time and has some information in it. I wonder if your experiencing the typical front end clunk that is common to the CT9A. Mine was persistent for about 8-9 months one time and then it just stopped. It was more audible when I was driving slowly over uneven road or a bump. As well as when parking, as in driving slow and turning the wheel. I want to say it's generally the front right that was more common.
Good luck.
P.s don't forget that the Evo (especially the Viii and IX) are very raw cars and some noise and weird sounds are common and considered normal... Nature of the beast I guess.
Old Sep 14, 2010 | 07:21 PM
  #2509
qucifer's Avatar
Good luck.
I saw that thread and it looked like a daunting read and the first few posts seemed to be referencing a different issue. I will commit some time in the not-so-distant future to getting through it.
I think the noise is coming from both sides up front, however i do believe it is more prevalent on the right.
Since you are local, can I steal a few minutes of your time in the next few days for you to confirm/deny it is a similar situation to what your car was doing?
-Bryan
Old Sep 14, 2010 | 08:00 PM
  #2510
DuderMagee's Avatar
right now I'm looking into what suspension\wheel\tire combo works
I have rpf1's 18x9.5 +15
I'm thinking a 255/35/18 tire
on swift springs
think it will fit with no rubbing?
or at worst I may have to roll the rear fenders a little?
Old Sep 14, 2010 | 08:13 PM
  #2511
ethan169's Avatar
Sure man. Shoot me a text or give me a call.
Old Sep 15, 2010 | 04:59 AM
  #2512
nperkins's Avatar
-Bryan
Clunks in the front end can be:
Swaybar Bushings
Blown Struts/Strut Bearings
Wheel Bearings
Brake Calipers sticking
Just to name a few things... Does it happen after a change in inertia (Tap the brakes firmly to nose the car down tap the gas firmly to nose the car up)? Does it happen after a change of direction (Reverse to forward). Does it seem rotational?
Old Sep 15, 2010 | 05:01 AM
  #2513
liam11's Avatar
on swift springs
I cant remember exact size on my car but im running 18X8's with like a 245/40 i think and my fenders were rolled and my Mud flaps sometimes rub on my tires with tight turns. I dont know if this helps or not but i can get more exact information for you after i get off of work thisafternoon and some pictures if you want of my wheel/tire setup so you can see what i mean.
Old Sep 15, 2010 | 08:44 AM
  #2514
qucifer's Avatar
Swaybar Bushings
Wheel Bearings
I had the swaybar bushings checked, wheel bearings, cv joint (called to confirm that), it isn't the calipers and I don't believe it is a strut because the noise is independent of suspension loading.
It does happen during a change in inertia, but makes the noise traveling slowly at constant inertia. It does make the noise after a change in direction also.
The noise does not appear to be rotational.
-Bryan
Last edited by qucifer; Sep 15, 2010 at 03:17 PM. Reason: Changed "does" to "does not" in the last sentence.
Old Sep 16, 2010 | 07:34 AM
  #2515
nperkins's Avatar
So when you are traveling slowly at constant inertia, how often does the sound occur? Is it when the road is smooth, when you hit a bump, anything like that?
If its change in direction (Forward to backwards or vice versa) it could be a wheel bearing (Trust me.. i've been there.. EVERYTHING pointed AWAY from the bearing, but it ended up being the bearing)... Could also be a bad motor mount, or control arm bushing... Or have you had balljoints/tie rods out? If they are over torqued that could do it..
Old Sep 16, 2010 | 08:59 AM
  #2516
qucifer's Avatar
The sound occurs fairly frequently, most often below 15mph. It definitely is related to a change in direction (loading) and a wheel bearing definitely sounds like it could fit the bill. The balljoints and tie rods haven't been touched, i am confident it isn't a motor mount.
I am willing to replace things preventatively at this point, and the wheel bearing sounds like a good place to start...
How much of a pain in the *** is that job? How much is the bearing? Given that I have very very little free time, am I better off paying someone else to do it?
Lastly, Noah if you are ever around Enfield (not including weekends) or if you feel like taking a drive to Stratford on Sunday (FCSCC AutoX), let me know. I would like a first hand opinion.
Thanks,
-Bryan
Old Sep 16, 2010 | 10:23 AM
  #2517
nperkins's Avatar
Not really in Enfield much...
This is how to remove the hub from the car which contains the wheel bearing... Not too hard to do..
https://www.evolutionm.net/forums/ev...b-bearing.html
I would do it a little different though... Instead of unbolting the strut & turning it around, i'd remove the bolts and use a slide hammer to pull the hub out as recommended in the service manual (Eliminates the need for an alignment after)..
Then you have the option of taking apart the hub assembly to replace the wheel bearing for a cost of $30-$80 (Aftermarket vs OEM) and you will need a hydraulic press, or buy a new hub/bearing assembly for $80-$200 (Aftermarket vs OEM) in which case you won't need the press...
Its also a good time to do longer wheel studs while you have the hub out.. On the rears you HAVE to pull the hub out with a slide hammer to replace the studs... On the front I was able to sneak them in without removing the hub on the rally car..
Old Sep 17, 2010 | 05:25 AM
  #2518
YShen15118's Avatar
Hey Fellas,
What's goin on with everyone? I haven't been on here lately - How was the Buttonwoods meet? I was supposed to come but I got sidetracked but another activity. We should have another meet soon - I know Ken's always up for a meet, because he loves reminding me how much faster his car is over mine.
Suck it, Ken. Just you wait til I get my Veyron...
Old Sep 17, 2010 | 05:34 AM
  #2519
ethan169's Avatar
Originally Posted by YShen15118
Hey Fellas,
lol nice. Veyron? Thats straight baller status dude haha.
Id be interested in doing something soon. I just got the Evo registered again. Unfortunately its now officially a flat lander vehicle .
Anyway we should meet up soon even if its like the last time i came out where we went to red robin in Newbritain. Im always down for some beer and grub.
-Ethan
Old Sep 17, 2010 | 07:20 AM
  #2520
DuderMagee's Avatar
hey guys whats up
anyone know what the best body shop in ct is?
looks like I need a little work done
