TeeJay's Quest For 700+whp Stock Block discussion thread
Old Oct 19, 2009 | 06:00 PM
  #361
projekX's Avatar
Originally Posted by scorke
It took the Northeast's finest evo tuner this long to figure out that a 3 bar map sensor ran out of resolution at 30 psi.....That is a bit worrying to me....
1Bar= 0 PSI on boost gauge
2Bar= 14.7 psi on boost gauge
3Bar=29.4 psi on boost gauge
Who and or why would you ever run more boost than the boost sensor is capable of reading?
When you do this you cannot account for the amount of boost the car is producing, not a wise idea.
Scorke
This long? How long do you think this has been going on? Your not going to find out if and what is going to happen until it does, ESPECIALLY with a motor so new to the industry. If it was the 4G63, i would see your point, but we are working with the 4B11, a motor very few have attempted to test.
The who would be myself and DG, the why is cause i can and because i want to. Thanks for letting it worry you, let me do the worrying
Old Oct 19, 2009 | 06:04 PM
  #362
Excalibur's Avatar
What codes did you get if you don't mind me asking?
I'm having my issues at only 25 psi on 91.
Old Oct 19, 2009 | 06:07 PM
  #363
projekX's Avatar
Ewww, hmmm, not sure on the codes. To be honest, i dont even remember seeing the Service Engine Soon light come on. I'll ask Charlie and get back to you.
  #364
scorke's Avatar
People have been modifying X's for a while now, running 30 psi on them for a while also, no?
Just saying, not exactly confidence inspiring if it is a 3 bar sensor!!!
Best of luck.
Scorke
Old Oct 19, 2009 | 06:17 PM
  #365
GUM EVO X's Avatar
Originally Posted by DG Motors
The car hits a brick wall as if the throttle closes and opens back up. You can still pull the car through this break up but never sounded like an ignition misfire.
Originally Posted by JC evo1
Ive had ignition problems that sound exactly like what your describing so dont rule that out yet.
My situation sounds exactly the same but it does not always happen... its like throttle closes then suddenly all power back pulling like a train. Tends to happen higher up the rev range. I am sure we are using the map sensor off an Apexi AVCR aswell I was thinking of trying another set of coils and if that dont change anything then go straight for the okada project items as they are apparently 4 times the ampage of stock.
Mine tends to do this and then the maf goes... since fitting my second brand new MAF it has not happened, i have the car with my tuner now for some map tweak and maybe bigger MAF tube, he will be looking into the ignition system etc..
Regards,
GUM
Old Oct 19, 2009 | 06:28 PM
  #366
Excalibur's Avatar
Also, what plugs are you using?
Old Oct 19, 2009 | 06:30 PM
  #367
projekX's Avatar
Best of luck.
Scorke
3 bar is stock, no? We were and are only going to change what needs to be changed to complete our task/goals for this project. Now that we know that the Stock Map Sensor isn't going to work for us, we will change it. This is about as minor as changing the plugs or even changing the oil. No Big Deal...
Old Oct 19, 2009 | 06:33 PM
  #368
projekX's Avatar
Regards,
GUM
AVC-R has a boost sensor, not a map. I think you mean the Apexi Power FC maybe? Good Luck with your situation, please keep us updated!
Old Oct 19, 2009 | 06:51 PM
  #369
projekX's Avatar
Stockers
Old Oct 19, 2009 | 06:53 PM
  #370
BlackTrack's Avatar
Order it UP! Let's gett er done and prove to shyt talkers, that all they talk. Sucks when these are supposed "professionals".
No one is **** talking you, DG or anyone else. We were just pointing out the fact that DG is using an excessive correction factor.
Best of luck with the car, no need to blow the engine though.
Old Oct 19, 2009 | 08:40 PM
  #371
Codevo's Avatar
Lol all I'm saying is that when it blows i hope someone catches it on camera, or at least has a camera near so we all can see the aftermath shortly thereafter.
My engine didn't look cool or do anything awesome when it blew up.
So i feel like i got jipped on that one.
Anyway good luck with the end product whatever it may be!
Old Oct 19, 2009 | 09:06 PM
  #372
monkey_187's Avatar
Codevo:
I see you got a lot of work done by Kevin and Denver, what kind of numbers is your car running. Can you send me a pm? I am looking at what it puts down with your type of mods, you have a list similar to what I am looking at.
Old Oct 20, 2009 | 07:05 AM
  #373
DG Motors's Avatar
Scorke
We have pushed stock and stock appearing turbos past 30psi on the stock ecu with no problems...This much larger turbo is more likely hitting the higher loads it should be hence our map sensor issue hopefully.
Old Oct 20, 2009 | 07:27 AM
  #374
blitz118's Avatar
Is the car going to be run at the track after it meets the dyno goal? The ETS X just went 10.8@133.
Old Oct 20, 2009 | 07:37 AM
  #375
GUM EVO X's Avatar
Spoke to my tuner today and he enlightened me on a few things regarding the MAP sensor.., thats not our issue so i will let you guys know when we get to the bottom of it. Keep the updates DG
Regards,
GUM
