Philadelphia's Classiest Drunkards
Old Mar 31, 2010 | 04:16 PM
  #2461
PeteyTurbo@KHC's Avatar
Originally Posted by colonelfox
Lol. Surprisingly I am more and more the older I get. Ok just to get this off my chest So Idont feel like a liar I only put those numbers in because everyone seems to be seeing only a minor deviation between a real dyno and vdr. Ive owned a legitimate 423 whp gst and the evo feels way more powerful by a large margin. There are a lot of dsms with similar mods and this turbo putting out around the 450-500whp mark.
I know mine is around that area. Vdr was around 330 whp on the stock turbo 425 at 25 psi on the hx with a bit of tuning and with meth 30 psi and a more aggressive tune I got those numbers.
we still dont believe you! lol j/k
Old Mar 31, 2010 | 04:17 PM
  #2462
Originally Posted by chu
Fuel content tester.... http://www.fueltestkit.com/
i am not sure if this will work for testing e85, it was just an example
As soon as I can gather some samples I am having the chemist here at work test for ethanol content only, and I am going to do an evap test on the shell fuel to prove there is still a large amount of hydrocarbons in the fuel.
Old Mar 31, 2010 | 04:24 PM
  #2463
Kevin.'s Avatar
Old Mar 31, 2010 | 04:31 PM
  #2464
Originally Posted by Kevin.
okay, petrolium based dilutants in alchohol (ethanol) greater then .05 cross contamination percentage usually deemed acceptable as a result from any contamination.. I am going to try to have a full distilation done on this fuel at a specific temp that will leave me with the hydrocarbons that should not be there. It will be an easy test since diesel and its numerous additives has an endpoint temp much greater then E85, so all that will be left is the heavy crap thats not supposed to be there
before and after volume numbers tell the story
I also know the appropriate action path needed to be taken if this proves true and is not resolved.. I am really hoping they fix this because if not, no E85 for me this year
This is the phase seperation test I am doing myself to determine Ethanol content, hopefully from all the stations in the area:
http://iqlearningsystems.com/ethanol...ds/E85test.pdf
Old Mar 31, 2010 | 04:40 PM
  #2465
Mr. MR's Avatar
Can you check Allentown Turnpike E85? I have some at my house if you need a sample.
Old Mar 31, 2010 | 04:43 PM
  #2466
dek0026's Avatar
i can give you a sample of the stuff here if you want to run multiple samples.
Old Mar 31, 2010 | 05:58 PM
  #2467
chu's Avatar
chu
Mike, Allentown is pure goodness. Both Sandy and myself are running it now, and it is fine as can be. I'm currently on the TOM's batch, and the car feels fine also, pulling to 28psi without knock that I can feel! I'll do some logs this weekend.
Old Mar 31, 2010 | 09:12 PM
  #2468
bsander's Avatar
I'm at 113 with the meth and 780s at 30 PSI I think the 1400's will be a huge improvement and I won't feel stupid for running a risky setup.
Don't forget about another fuel pump too
If Chu and dan go to Atco I can guarantee good times. They have a BAR, thats right, beer and hard liquor, with tv's to watch the cars make passes on as well.. I make it a habit to walk around with a sixer of sly fox pale ale everytime I go. I hold on to the plastic thing like uncle eddie in "vegas vacation" with the busch pounders
we brought our own that one time. Had the cooler in the stands and everything
He'll be checking it tomorrow I think. I gave him a sample of the stuff I just bought last saturday. It should be good though, never fails that A-town station!!
Old Apr 1, 2010 | 05:29 AM
  #2469
chu's Avatar
chu
Lancaster County Pigs gave me a speeding ticket this morning. 60 in a 40 zone. The pig wouldn't have my merging excuse, from a two lane to one lane! Who the hell merges while maintaining speed?
Old Apr 1, 2010 | 05:33 AM
  #2470
Jeffroevoix's Avatar
take it to court, thats what I would do.
I've only gotten 1 ticket in PA, but it was 20 over in a double fine zone. Took it to court and the cop didn't even show
Old Apr 1, 2010 | 05:47 AM
  #2471
turbotekray's Avatar
i noticed this am, that my fuel pump is making a surging sound at idle , like you can hear the fuel through the lines outside the car almost sound like a lawn sprinkler. Has anyone else noticed this, car idles perfect and drives perfect.
Old Apr 1, 2010 | 06:09 AM
  #2472
chu's Avatar
chu
Mine sounds the same. Its not a smooth tone!
Old Apr 1, 2010 | 06:32 AM
  #2473
AlwaysinBoost's Avatar
thats why they're called a whine bro.
chu, that's messed up, but you were speeding bro. Just fight the ticket and I'm sure you'll get it reduced at the least.
Old Apr 1, 2010 | 06:42 AM
  #2474
always appear in court for a ticket. You will get a reduced offer 99% of the time off the bat.
Old Apr 1, 2010 | 06:44 AM
  #2475
dek0026's Avatar
i got one last saturday from a statie for 73 in a 55. i was actually doing a pull at the time for the fun of it and when i saw i lights i thought i was cooked
i am going to try to fight it to get out of the points. i don't care about the fine as much as i do the points.
