Philadelphia's Classiest Drunkards
Old Apr 5, 2010 | 05:02 PM
  #2626
steinvb12's Avatar
Originally Posted by robertg
yeah, anything would be better than this:
Dude, you better get those fenders rolled...fast! Mine was rubbing at first too, but yours looks even worse than mine!
Kam Specialties in Reading did mine. Give Bryner a call @ (610) 777-9702.
Old Apr 5, 2010 | 05:13 PM
  #2627
chu's brother's Avatar
Pictures from last Friday at the horse with Jimmayyy's car
Old Apr 5, 2010 | 05:34 PM
  #2628
AlwaysinBoost's Avatar
Originally Posted by PeteyTurbo@KHC
My car did that when it was stock lol.. Possibly the turbo is trying to supply too much air for the engine down low causing compressor surge.. is your BOV un-crushed? Try the pressure scource at the LICP or turbo outlet for the BOV and see if it helps.
I'm running a signal straight off the manifold, with no tee's, so it sees solid vacuum and boost. I will give another signal line a try and see if that works though. I'll have to switch the signal line between my MBC and BOV, but thats on biggie.
I don't think its compressor surge though, that would happen @ WOT. I've experienced that before on another car, basically the turbo is putting out more air then the engine can injest causing a wave of pressure to be sent back to the compressor. this problem only happens when the throttle plate shuts.
Old Apr 5, 2010 | 05:42 PM
  #2629
chu's Avatar
chu
Sounds similar to what happened to me after my second tune with the IX turbo. I was on the HKS SSQV at the time, and it would only happen when I give alittle gas to pass someone, and then let off, or try to hold the pedal steady. The car would buck and bov continuously go off.
Old Apr 5, 2010 | 05:47 PM
  #2630
colonelfox's Avatar
The old HKS does that horribly. The newer design before the current one seemed to eliminate that when I ran one. What did Jim lay down? A real number that is.
Almost forgot. I got the injectors today. They are not 1400CC Boschs. They're the 1600cc pintle style that doesn't work well. I also have to machine them to make them fit as the fuel rail end is too large and doesn't enter the rail far enough. Not a big deal with a lathe at work but I wanted to drop them in tonight. I don't have the time to sell and buy another set so I'm going to try them out while I look for a set that will work better.
Old Apr 5, 2010 | 05:52 PM
  #2631
BrandNew's Avatar
540 i think it was
Old Apr 5, 2010 | 06:59 PM
  #2632
illmatic165's Avatar
Originally Posted by BrandNew
540 i think it was
no it was 526hp
Old Apr 5, 2010 | 07:03 PM
  #2633
grillpt's Avatar
540 i think it was
wow!
I take it Jim is running e85 now?
Thats insane...
*just noticed Jim wearing the TMNT t-shirt... *
Marc, I don't know... that sounds like surge to me.
Old Apr 5, 2010 | 07:07 PM
  #2634
turbotekray's Avatar
ok so im having an ******* time finding the part number for the crank trigger wheel / plate or what ever the hell Mitsubishi calls it. so any of you guys awake can help me lol
Old Apr 5, 2010 | 07:11 PM
  #2635
chu's Avatar
chu
Not the crankshaft pulley right? MN149074
Here you go bud https://www.evolutionm.net/forums/ev...t-go-here.html
Old Apr 5, 2010 | 07:14 PM
  #2636
dek0026's Avatar
i wish i knew about jim going to khc on friday. i wasn't doing anything that day....would have been cool to make the trip....even though he is making 200 or so less than me.
Old Apr 5, 2010 | 07:18 PM
  #2637
bsander's Avatar
Good olde JimBone on the KHC dyno. Looked like good times. He now knows how it feels to get yelled at for going to fast
Old Apr 5, 2010 | 07:23 PM
  #2638
no i need the plate or blade behind it
Old Apr 5, 2010 | 07:25 PM
  #2639
chu's Avatar
chu
See if this helps
http://www.trademotion.com/partlocat...layCatalogid=0
Old Apr 5, 2010 | 07:26 PM
  #2640
DsB's Avatar
DsB
hahaha yea dan you shoulda came to E-Town with us. i know how it feels to do 3 runs and not even be noticed. hahaha
