Philadelphia's Classiest Drunkards
Old Sep 8, 2011 | 07:55 AM
  #27496
dek0026's Avatar
I'm not going to shanadoah, Thai.
Also I sent a message pigeon your way but I think my wife shot it.
Old Sep 8, 2011 | 07:57 AM
  #27497
AlwaysinBoost's Avatar
Originally Posted by honda-guy
^ i didn't get your text, when did you send it?
holla back youngin
Originally Posted by grillpt
SWEET!!!
Did you ask for a perticular student?
I did not. Honestly, you'd probably be better off with someone who is faster than me/knows the track better.
^ damn, i ain't going if i'm stuck to instruct Dan. i don't want my student to have a faster car than me.
that doesn't leave you with too many options.
Old Sep 8, 2011 | 08:14 AM
  #27498
grillpt's Avatar
Originally Posted by chu
I asked for Mark already! Don't be a thief yo!
Is Marc bringing his tire warmer with him? If thats not the case, you need him more than I do.
I haven't seen your name on the reg list, did you sign up yet?
Old Sep 8, 2011 | 08:19 AM
  #27499
chu's Avatar
chu
Don't worry about the tire warmers. You'll be seeing oars out of my windows as Marc and I row pass you.
Old Sep 8, 2011 | 08:23 AM
  #27500
honda-guy's Avatar
LOL, camping will be so fun that weekend.
we can hunt for deers for dinner.
Old Sep 8, 2011 | 08:27 AM
  #27501
honda-guy's Avatar
tru dat, i'll just have to find a student with a miata or subie. miata will be so slow, so i can take naps in the car and subie would blow up after first session, so i don't have to instruct for the rest of the day.
Old Sep 8, 2011 | 08:41 AM
  #27502
^ truer words have never been spoken.
Old Sep 8, 2011 | 08:44 AM
  #27503
grillpt's Avatar
Did you sign up for Novice or Inter? I signed up for Inter, but they'll probably place me in Novice like BMW did.
Old Sep 8, 2011 | 08:46 AM
  #27504
a wise man once said; better to pass than be passed.
Old Sep 8, 2011 | 08:48 AM
  #27505
See tip # 10.
I thought it would be a good idea to put a little list together of some helpful tips to get you started on the right foot for your first track day. Here it is in no particular order:
1 - Wheel torque - general rule of thumb is to use the same amount of torque your engine makes on your wheels. I like to round up to 300ft lbs just to be safe.
2 - Air pressure - I usually start off around 55psi cold all around and go up from there as conditions warrant. The more pressure you run the less drag the tire makes and the faster you will go.
3 - Boost pressure - this is simple; the more the better. Run as much as you can cause you will need it.
4 - Watching your mirrors - since its a race you want to avoid pointing people by as much as possible. I have two methods I like to employ here. First, if someone is behind me and I don't want to point them by I just pretend like they aren't there. usually they'll get frustrated and pit-in after a few laps. If not, the second method I like to use is called 'the mechanical'. I use this when option 1 doesn't work. All you have to do is act like something is wrong with your car, typical excuses are "my hood was popped" or "i was getting low on fuel" or "my tires are shot". To really sell the sizzle after your session, I mean race, you should go up to the car who was behind you and tell them what happened so they know for a fact you only let them go by because it was a mechanical issue.
5 - if its your first time you should try and run R-comps cause they help you learn to go fast while you're still learning the track. If you don't have R-comps some bald street tires will work just fine. Bald street tires also help if you have to use #4 above.
6 - prepping your car. Try and install all the aftermarket parts you can BEFORE you go out to your first event. this will help you be a better/faster/safer driver and ultimately pass everyone else out there. Additionally, make sure you understate your mods if anyone asks so you can seem like a better driver than you really are. I usually tell people its a FWD lancer with a turbo kit.
7 - Brakes. If you have to use them, you should always make sure to have your braking zones be LONG, that way the car has plenty of time to slow down. I personally like to drag the brakes between turns. This accomplishes two things, first it will trick the train of cars behind you into thinking they need to brake (aka put more space between you and them) and also it will keep the pads and fluid up to optimal operating temp.
8 - throttle. You should be WOT as much as possible. when in doubt, go flat out is what they say.
9 - Suspension. the harder the better. If you have adjustable coils make sure they are set at max stiff. same with adjustable sway bars if you have them. you should also try and lower the car as much as possible to lower your CoG.
10 - better to pass than be passed. this is one that I just learned last weekend. basically all it means is that you should try to stay at least 1 or 2 run groups lower than you are qualified to run in. that way you will always be the fastest one in the group and never have to point anyone by.
11 - instructors - if you have to take one with you make sure they aren't fat, extra weight will slow the car down. I removed my seats to save weight and it also prevents anyone from riding with me or slowing the car down.
12 - driving on track. Try to focus on the section track directly in front of you, or even better if there is a car in front you should focus on that. Never take your eyes off the track or you might go off. You should also try and early apex every turn, this is critical to getting fast time because the shorter the distance from A to B the quicker your time will be.
13 - seating position. I like to sit low so my CoG is better. I'll usually crank the seat all the way back and keep one hand at 12 o'clock on the wheel and the other on the shifter. If you have a harness bar this might not be possible.
14 - shifting. the more you upshift/downshift the faster you will be, just like in the movies.
thats all I can think of at the moment, feel free to add more as you think of them.
Old Sep 8, 2011 | 08:49 AM
  #27506
grillpt's Avatar
Flashbacks of Monticello.
  #27507
grillpt's Avatar
I remember said wise man...
Old Sep 8, 2011 | 08:59 AM
  #27508
honda-guy's Avatar
flashback of pretty much any track days i've been to. if there are any subies on track, one is bound not to make the whole day.
Old Sep 8, 2011 | 04:07 PM
  #27509
B.J.@ToxicFab's Avatar
Yoooooo...Not sure how many of you guys have seen this....East Coast Mitsu. Owner's Day @ Camden, NJ...Oct. 8th...
http://www.facebook.com/event.php?eid=187202138020386
Old Sep 8, 2011 | 04:33 PM
  #27510
robertg's Avatar
I'm in...I like the raffles
