Wheatley's 6262 build
Old May 18, 2013 | 05:02 AM
  #676
LGshow19's Avatar
Any start up/idle vid? I wonder how loud the pump is?
Congrats again man lol
Old May 18, 2013 | 08:31 AM
  #677
Wheatley's Avatar
The pump is loud! I couldn't hear it over the exhaust though. No videos, it was 5am after 12 straight hours of work.
Old May 18, 2013 | 09:09 AM
  #678
LGshow19's Avatar
Lol... I guess ill see how loud it is when its in my trunk haha
Old May 18, 2013 | 10:02 AM
  #679
Wheatley's Avatar
Did you put a check valve in? Line pressure drops instantly FYI. Mine seems to start ok though. Took a lot of changes in my startup map
Old May 18, 2013 | 10:06 AM
  #680
LGshow19's Avatar
I have one filter. That is all. Ill have to check again because i modified my line from braided steel to black braided line.
Old May 22, 2013 | 10:00 PM
  #681
Wheatley's Avatar
I decided along with doing the -8 return line to a bulk head in the tank to also go ahead and run a regulator with a bigger orifice just in case. I ordered everything from summit and jegs late Sunday night. Everything came in Tuesday and took longer in the evening to finish up due to clearance issues with the bulk head and my floor under the seat. I finished it all up about 1am and had to fire it to make sure the base pressure was able to be controlled and it was!
Today rolls around and it rained on and off most the day. Worked until 7 and it cleared up finally. Started finishing everything up and tweaked the cold start a little more while it was still cold. By the time I had all the tools backed, car refueled and ready to go it started raining again! I was literally belted in the car getting ready to pull out. I had Aaron with the colt ridding shotgun so we decided to wait until it died down a little and take it for a spin in the rain anyways.
I took a ton of fuel out of the map in the vacuum side and it was still rich, this pump setup is ridiculous compared to the old walbro setup. Stopped to make an adjustment and for the time being am satisfied to safely drive it around. Still raining I wanted to get into boost a little to see where the boost comp tables were. Untouched it pegged the wideband full rich, no surprise really. I pulled a very large amount of fuel and it cleaned it up but still pegged full rich. It was hitting 25+ psi just blipping the throttle and blowing the tires off. Felt great to get back in it and take it for a spin!
Hopefully tomorrow it stays dry and I have good luck with clear roads to make some pulls to dial in the afr in boost. I generally don't worry about getting it perfect since the o2 feedback does a pretty nice job keeping it in line.
Little wet but no big deal, pump seems to clear fine btw.
https://www.facebook.com/photo.php?v...15477036139770
Old May 23, 2013 | 06:53 AM
  #682
LGshow19's Avatar
Congrats Wheatley.
Do you plan to dyno the car again? I know you mentioned you were going to leave it the same as last time.
Old May 23, 2013 | 07:15 AM
  #683
Wheatley's Avatar
I doubt we get in on time to dyno at buschurs. Honestly with this last minute fuel stuff I'm pretty strapped for cash.
Old May 23, 2013 | 08:27 AM
  #684
LGshow19's Avatar
I understand, buying all these an fittings and lines is no joke... then the pump.
Well good luck at the BR event.
Old May 23, 2013 | 08:45 AM
  #685
Wheatley's Avatar
Thanks, I'm going to need a ton of luck!
Old May 23, 2013 | 09:07 AM
  #686
badev0's Avatar
I feel like I do to. Mainly because I've had zero testing time prior lol.
Old May 23, 2013 | 10:53 AM
  #687
Wheatley's Avatar
Made a few more hits before the rain came back. I finally got one 100% wot pull at full boost. Felt pretty good. I really wont have anymore time to dial the car in tune wise. The street tires are useless but they are a few years old.
The car pulls hard left while driving, which is a new thing. I'm going to try and sort the alignment out today if I have time.
Old May 23, 2013 | 04:47 PM
  #688
EvoDan2004's Avatar
good luck man. i hope all go's well. i wish i could make the race.
also thanks for everything.
Old May 23, 2013 | 08:52 PM
  #689
5speedwtneed's Avatar
Best of luck! Car came along great
Old May 23, 2013 | 11:17 PM
  #690
Wheatley's Avatar
The pull has been corrected, the miss at 5400 rpm has been corrected. I still haven't launched the car or tested any of the other settings out but with some luck it'll go straight down the track and I'll be able to bang some gears. I didn't even get a chance to go through the gears. With the street tires it just blows the tires off in third making it pointless to try and do much.
The fuel map and boost map need some fine tuning but its all ready to load up tomorrow, hopefully I'll get a chance to make some adjustments there and practice seat time during qualifying lol.
No problem at all and good luck with everything! Hopefully see you at Shootout.
Thanks, a lot of hours and luck so far.
